Old 11-20-2011, 10:29 PM
gtorich gtorich is offline
Darby i have an old one from 10-10-2007....if you do a search under "Street pro mufflers" it comes up......as usual i can"t seem to get it into this thread.
This is with a 455 crower 60919 cam 2 1/2 pypes with X over and street pro mufflers, this also has a tri power on it.
New set up is the same 455, except 290 cfm alum heads by sd along with their OF cam.
Maybe someone with more "Puter" savy than me could post it in this thread.
Rich
Old 11-20-2011, 11:07 PM
http://s223.photobucket.com/albums/d...running003.mp4
Ok, played around with this, hope it works
Rich
Old 11-20-2011, 11:31 PM
psw's Avatar
psw psw is offline
How about a comparison before and after blocking the intake manifold exhaust crossover. Some have said there is an audible difference.
Engine is 1971 455 overbored to 462, 6X-8 heads running about 9.75:1 CR, Comp Cams Magnum 280, 800 cfm AVS e-brock carb on a P4B. Exhaust is Hooker Competition Headers, 1.625" x 28" into 3" collector, 2-1/4 inch exhaust pipes back to Dynomax Super Turbos, no H-pipe, no X-pipe.
First link is the way it sounded before I blocked the intake manifold exhaust crossover:
http://www.youtube.com/watch?v=Fmccth_JWeQ
The second is the same but with the intake manifold exhaust crossover blocked:
http://www.youtube.com/watch?v=Pd3Dm...eature=related
Not sure if I can hear any difference.
Old 11-21-2011, 12:04 AM
Rich
Whoa, can"t believe i got that to work. LOL
Forgot to mention, Dougs headers on the vid, before i got the alum heads i was running 6X-8 heads with a mild port job.
Old 11-21-2011, 02:22 AM
grrr421 grrr421 is offline
Has a better rumble than mine You win.
Old 11-21-2011, 03:31 AM
ahnuld's Avatar
ahnuld ahnuld is offline
Mine is in my signature, at time idle was high and exhaust leak at header. TRi y's, tripower-not stock at all, 3 inch with thrush welded mufflers. Have electric cutouts but there closed in vid.
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
Old 11-21-2011, 01:08 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Here's my 67 Firebird with hooker headers and flowmaster exhaust.
http://youtu.be/XyMRq8ne_WQ
Old 11-21-2011, 05:52 PM
grandville455's Avatar
Rich
That sounded pretty tame rich!.. That was other cam and heads right?
Darby
M/T 275/60 ET SS Drag Radial
Old 11-21-2011, 06:00 PM
Pretty quiet once cruising or even getting on it. Love the inside very nice!
Darby
Sounded bad ass doing the burnout and then taking off!!
Darby
Old 11-21-2011, 07:21 PM
Darby, that was with the 6X-8 heads and Crower 60919 cam............I now have the 290 SD alum heads and the "Old Faithful" cam.........kinda odd but it doesn"t sound too much different than my old set up
Maybe i need to get some different mufflers instead of the street pro"s
Rich
Old 11-21-2011, 07:38 PM
ahnuld's Avatar
actually at car shows its one of the loudest, i set car alarms off 3 lanes over just idling down the road, my neighbours say they like me and hate my car, so i say job well done.
Old 11-21-2011, 08:47 PM
form74's Avatar
form74 form74 is offline
Ram Air 2 1/2 inch Manifolds, 2 1/2 inch exhaust with x-pipe and Goelrich Mufflers, Crower 60919 Cam.
At Idle
Down the track, will look for a better one.
Youtube link at the track
http://www.youtube.com/watch?v=UW30Q2lZ9Zs
Another Idle
http://www.youtube.com/user/formula74
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 11-21-2011, 10:05 PM
ta man ta man is offline
Another one...http://s668.photobucket.com/albums/v...onepics265.mp4
Old 11-21-2011, 11:35 PM
Originally Posted by ta man View Post
My buddy might but its a 540 BB Chevy in a 70 Chevelle.
Did u find out if he has a video of this? I know its a chebby, but still should be close in sound somewhat
Darby
Old 11-22-2011, 01:38 AM
jwcfbd's Avatar
Thanks.
Old 11-22-2011, 06:56 AM
I should get talking to him soon..he hasn't talked to me since I ran a tenth quicker than him...lol His is pretty loud..not sure what he has for mufflers..they may be spintechs?
  #38
Old 11-22-2011, 08:18 AM
Okay cool, I am working on this 3 1/2 X that came with the car with bullets just to see how they sound on it lol, got some welding to do to add some width to it as my headers are wider, hope to have video thursday of it?
Darby
  #39
Old 11-23-2011, 10:10 PM
mogeo's Avatar
mogeo mogeo is offline
First is idling, then my son revving it up, then with the electric cut outs open. The sound gets distorted with the electric cut outs open because its too much for the mic:
http://s942.photobucket.com/albums/a...t=100_0660.mp4
Next is me light throttle pulling away (not enough room):
http://s942.photobucket.com/albums/a...t=100_0659.mp4
400 .30 over
10.75:1 16x
212/224 112 LSA
Edelbrock/ Holley 770 vac sec.
LBMs hogged out to 3" with 3" collector, 3" dumps, NO "X" (yet), to 2.5" mandrel bent tubes with tails and 2 Magnaflows.
Rich
  #40
Old 11-24-2011, 05:44 PM
Sounds good, what magnaflows? Here is mine with a 3 1/2 X and 3 1/2 Bullets, I had to cut the X cause the headers that were in this car were Hooker super comps, and they were narrower than my Hustler's with those adapters, anyway after trying to figure out where to cut it and how much to weld back in etc so i could get it as close to the rear of the trans as possible, cause that's How it will be in spring. I ended up with a 1/4 gap at the top of the drivers collector ,cause the bullets were hitting the bottom of the floor by tunnel, this was just to hear how it sounded it with them, I will change it or just get a New X I haven't decided yet, But it sounds good! When I revved it the smoke is from dumping trans fluid down my carb from before to store it, and the mic kinda gets muffled when it is revved up too. This was just a test tho as its 50 here today !! Turn up the volume! . It's put away now til spring
Darby
