Old 03-23-2011, 01:08 PM
nz049b nz049b is offline
Default Which trim rings fit 15 x 7 Rally II
I'm interested in purchasing trim rings for my factory 15 x 7 Rally II wheels from Summit. They sell a 2" deep, 2.5" and 3"...Which one is correct for the factory 15 x 7?
Has anyone purchased these before? Quality OK?
Old 03-23-2011, 07:59 PM
marshallbeach marshallbeach is offline
Just piggy backing to this post.
I have the same question for 15 by 6 Rally II's, but from any source.
Thanks,
Old 03-24-2011, 12:44 AM
1978 T/A's Avatar
1978 T/A 1978 T/A is offline
If you're not going for 100% original I say do a 3". They will fit flush with the face of the wheel.
This is what a 2.5" looks like on a 15x7
1969 Verdoro Green GTO
#Matching 400 + .045, 4.21 Ohio Forged Crank, SD 290 KRE heads, Torker II, OF Cam, Etc...
1978 W72 Marty Blue T/A GONE
Old 03-25-2011, 08:10 PM
Is that your GTO? If so, how much room (gap) do you have between the trim ring and the rim face? Also, what size tire are you running?
Old 03-25-2011, 08:37 PM
1978 T/A's Avatar
Yes it is my car. There is about a 1/2" gap. I used to run 3" rings in all 4 corners and they would sit flush with the face of the wheel. I am running a 235/60/15 in the front.
This is a picture of the old 3" rings.
Hope it helps!
Old 03-25-2011, 09:20 PM
Thanks for the quick response!
Out of curiosity, do you still have the 3" rings? If so, would you sell them?
Old 03-26-2011, 07:39 PM
3" Is definitely the way to go....Thanks for the advice
Old 11-13-2011, 09:31 PM
Lemans51 Lemans51 is offline
where did the 3" rings come from?
Old 11-14-2011, 04:16 AM
android 211 android 211 is offline
A budget solution is to look for '74-'77 Cutlass with 15" SS wheels in the junkyard. Their trim rings fit properly and Olds sold almost half a million Cutlasses some years. Delta 88s in that era also used the same trim ring with a different center cap sometimes.
Old 11-16-2011, 10:55 PM
Thanks, but I am looking to buy new. My problem is the 15X7 are deep 3". I am only finding 2-2.5 inch trim rings that resemble a pontiac beauty ring.
So basically I am looking for specific info directing me to the trim rings. The web sites like wheel vintiques don't give depth for some of their products.
Thanks for your help.
Old 11-18-2011, 03:09 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is online now
I also would like to know where to get the 3" trim rings. Anybody?
Old 11-29-2011, 04:26 PM
1978 T/A's Avatar
I found my set off Ebay. I was actually quite impressed with the quality and the seller was top notch. Two of the rings were scratched, so I sent the sell an email and I had new ones in a matter of days.
Old 11-29-2011, 10:33 PM
Are these the ones? http://www.ebay.com/itm/GM-CHEVROLET...sories&vxp=mtr
Old 11-29-2011, 10:47 PM
1978 T/A's Avatar
http://www.ebay.com/itm/15-x-8-Chrom...#ht_937wt_1110
I have a 2.5" in the front and a 3" in the back. But this is the seller I bought from and I was happy my purchase. Hope it helps.
