Old 12-06-2011, 12:38 PM
lmf01 lmf01 is offline
Default Drive Shaft Questions
3 Drive Shaft Questions
1) Will a drive shaft that came out of a Saginaw fit a Muncie? I have a drive shaft that was used with the old Saginaw I have replaced with a Muncie and I am wondering if the output shaft will be compatible?
2) The Muncie and Engine sit +/- 1 inch further back (towards the rear wheel) then the engine/transmission was previously. Will the +/-1 inch render the drive shaft unusable?
3) Assuming 1 and 2 indicate that the driveshaft can be used will a drive shaft that is stock (at least appears to be) hold up the abuse a modified 455 will give it.
I realize these are broad questions and I haven’t tried to fit it yet. Just wanted to see if I could get the answers here prior to crawling under the car.
Old 12-06-2011, 03:54 PM
c sheeder c sheeder is offline
I bought a 65 GTO that had a saginaw 4 speed in it and I went to a muncie and I do not remember having any issues with the driveshaft or the yoke but that was close to 15 years ago
Old 12-06-2011, 04:38 PM
Txbobcat Txbobcat is offline
Same changeover on my 72 . It slid right in no changes at all.
Old 12-06-2011, 05:05 PM
As inexpensive as it is to have a new one made, it's a ton of assurance. New yoke, new joints, balanced, think I paid $240 for my last one. (steel). And I could have shopped it. That was with 1350s too.
Pretty certain munchies use a th400 type slip yoke. New ones are like < $50. And most likely available locally too. Maybe call a driveshaft shop just to get an idea of total cost?
Old 12-06-2011, 05:20 PM
hotrodrx's Avatar
hotrodrx hotrodrx is offline
My Pontiac buddy has a 66 GTO with a saginaw as a spare. He used it when his muncie was broken. No driveshaft issues. The muncie I believe uses the turbo 400 and the turbo 350 yoke. Newer muncies have the larger output shaft which would mate up to the turbo 400 yoke. 72 muncie I know. I just built an M22 in a 72 case with the large output shaft and it mates up to my turbo 400 yoke and driveshaft. Hope this helps. Bill
67 gto conv. cover car on gto buyers guide, numbers matching,
62 catalina siverleaf green
67 gto conv. M22 , stroker, roller 400, carlisle blue, parchment interior
65 stingray original condition numbers matching 327 365 hp
Old 12-06-2011, 05:27 PM
on early firebird & A-bodys through '69, I believe factory HD toploader 3 spd had its own length driveshaft. A Turbo 400 driveshaft in '67-69 Bird or A-body will be 5/8" shorter than same bodystyle with factory 2 speed or an early Muncie 4speed.
The Saginaw, Super Turbine 2 speed & early Muncie 4 speed all shared the same spline output shaft & yoke. Late Muncie 4 speed (original use 71-74) used the medium length Turbo 400 yoke. There are at least 8 different GM factory useage Turbo 400 yokes not including aftermarket yokes which accept Spicer 1350 u-joints. Shortest turbo 4oo yokes were used in late '70's Sevilles, longest in factory early BBC pickups, '70 Camaro's, & '70 Formula-T/A's. There is even an oddball med length T400 yoke used in '65 & 66 big Buicks. splines are different as is u-joint design.
Old 12-14-2011, 04:55 PM
Drive shaft did fit. Hope it holds up to the abuse.
Thanks for the info.
Old 12-14-2011, 06:42 PM
69Customs's Avatar
69Customs 69Customs is offline
HD toploader used same lgth driveshaft just different splined yoke. Had the ford spline.
