Old 12-20-2011, 06:05 PM
Todd1035's Avatar
Todd1035 Todd1035 is offline
Send a message via AIM to Todd1035
Default Anybody run an acumulator here?
I was wondering if anybody has run an accumulator in their race car before? I'm putting one in my car this spring. Where is the best place to plumb one in the block? Filter housing, top of the block? Thanks...Todd
Old 12-20-2011, 08:19 PM
modzx99's Avatar
modzx99 modzx99 is offline
i ran mine to top of block with #10 an line have accumulator in car to get to the valve easy
Old 12-20-2011, 08:26 PM
Torment's Avatar
Torment Torment is offline
I drilled a hole in top of the factory filter housing bisecting the passage going back into the block - the upper one. I tigged an aluminum male -10AN fitting on and plumbed the accumulator to it. Be sure to use a filter with anti drain back so the oil goes to the motor and not to the pan.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 12-20-2011, 10:09 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I had mine set up this way at first, but I split a stainless AN line and pumped a couple of quarts of oil into the car--not a pretty sight. Fortunately, I was in the staging lanes, not going down the track when the line let loose. The rules don't allow the lines in the car anymore. I moved mine into the engine compartment. It's a PITA, but I'm too cheap to buy an electric valve. I do still use the hole near the distributor with a 10AN line.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 12-20-2011, 10:27 PM
Probird's Avatar
Probird Probird is offline
Ours is plumbed into the remote oil filter housing. There are in and out ports on both sides. One side goes in and out to the engine the other side goes in and out of the accumulator.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 12-21-2011, 07:43 AM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
I believe it is the way to go...we had one in my brother's 66GTO...Wheelstander(Jeff Verdi's car now)... it was nice to pre-oil the engine after the car had been sitting, and when it was doin the big wheelstands, it was nice to know that it wouldnt run outta oil with the rear bumper on the ground...hehe,,,, i need to get one for my car
we had his plumbed into the top of the block...
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!!
Old 12-21-2011, 06:07 PM
rompn63's Avatar
rompn63 rompn63 is offline
Mine is set up the same as Probird. On the War Chief I made an adapter the goes between the oil filter housing and the block.
Old 12-21-2011, 08:27 PM
Old Man Taylor's Avatar
I tapped mine directly into the block where the oil filter adapter housing would have bolted on.
Name:	Oil Lines 2007-0825 008 small.jpg
ID:	267750   Click image for larger version
Name:	Oil Lines 2007-0825 009 small.jpg
ID:	267751   Click image for larger version
Name:	Oil Lines 2007-0825 010 bright small.jpg
Old 12-21-2011, 09:56 PM
aaronman aaronman is offline
Both mine are plumbed into the back of the block by the distributor. You need to have a check valve installed in the system to prevent it from back flushing the oil filter when it dumps.
Old 12-22-2011, 12:06 AM
rompn63's Avatar
Taken from the accusump instructions.
Check Valve #24-280 Can be used in systems with external oil lines to ensure that oil can only flow in one
direction; has 1/2" N.P.T. female threads. While the check valve is helpful, it is not absolutely necessary as in most
cases the oil will not back feed through the oil pump
Old 12-22-2011, 03:18 AM
jm455ho's Avatar
jm455ho jm455ho is offline
Would you please explain where and how you install this check valve.
www.hobracing.com
