Old 01-02-2012, 01:38 PM
archerytony's Avatar
archerytony archerytony is offline
Default best pontiac performance engine book?
Who makes the best pontiac engine building book I mean complete with bottom end specs strokes and so on? I see books for sale on line but I have been burned before when I cant see what it covers if I need carb info I will get a book on that if you get what I mean
Old 01-02-2012, 01:43 PM
60man's Avatar
60man 60man is offline
NOt sure just what you're lookling for but a good start would Jim Hand's book on Pontiac's....
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 01-02-2012, 02:01 PM
a good complete book if there is one
Old 01-02-2012, 02:05 PM
johnta1 johnta1 is online now
A Pontiac Service Manual?
(for year of your engine)
It has just about every spec you need for the car and engine.
Rocky Rotella's book is good for a How To book also:
How To Rebuild Pontiac Engines
Old 01-02-2012, 02:15 PM
T Syron's Avatar
T Syron T Syron is offline
Paul Carter was working on a new book but I have not heard if he had finished it yet.
http://www.pontiaczone.com/forum/sho...130#post396130
The book I'm writing about engine building
Well, I'm getting close on my book. I feel I have covered engine building from picking a good core to prep work to understanding how the machining processes are completed, and assembly. I still need to edit and insert pictures and finish the last chapter of final assembly.
My question to the board is this:
Is there something specific anyone would like to see explained in detail in an engine building book?
I think I have covered it pretty well but you know how it is, when you do something over and over everyday, it becomes second nature and sometimes we find ourselves thinking that certain things are common knowledge and I may forget to mention it. I feel I have included far more stuff than what you will find in your average "How to build and engine" book.
Please feel free to ask for anything engine related as I'm writing this book for other peoples benefit, not my own, so I feel it only right to ask input for what you would like to see or learn about.
Thank you for any input!
Paul Carter
Carter Cryogenics
www.cartercryo.com
Koerner Racing Engines
www.koernerracing.com
Home of the Koerner Flat Roller Lifter
I was wrong once. That was when I THOUGHT I made a mistake!
Your mind determines your limitations!
Tom
Old 01-02-2012, 02:30 PM
sounds cool sounds like what Im looking for I would like it to tell what I need to do to keep my motor together for the way I like to drive it. diff levels would be nice to see and combos of strokes too. I have had my 400 done 3x and its knocking again less than 5000 miles I have done motors in the past myself with better luck than the shops I have done them with. I think alot of things have changed since some of those old books were written great for their time lots of new parts out there and diff fuel too
Old 01-02-2012, 03:30 PM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
Thumbs up
If it is a how to book with the most up to date info go with Rocky Rotellas!
Ace
Am I glad I got out of the business I was in? HELL YEAH!!!
Old 01-03-2012, 07:05 AM
Tim Corcoran's Avatar
You may not find one single book to answer all your questions. Books are cheap, you might want to read several books, even books that are not specific to pontiacs can give you good insight.
Tim Corcoran
Old 01-03-2012, 04:27 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
Quote by Archerytony: "I have had my 400 done 3x and its knocking again less than 5000 miles I have done motors in the past myself with better luck than the shops I have done them with."
Not as much has changed as you would think. Use of the "old books" shouldn't result in "knocks" any more than a newer book would.
___________________________________
"Objects in mirror are closer than they appear"
Old 01-03-2012, 07:25 PM
Thats my point not all engines are the same
Old 01-03-2012, 07:36 PM
If you have that many problems, probably best to change machine shops?
One thing that may need to be remembered/known is that if it's a newer stroker crank, they need the right bearings if they have bigger radii on the crank journals.
Old 01-03-2012, 10:04 PM
Pontirag Pontirag is offline
Both Jim Hands book and Rocky's are an excellent start, Osterstocks HO books are an interesting read as is Angels and MCCarthy's.
I for one will certainly be looking forward to Pauls book
Tim Corcoran also brought up a good point about books on performance in general.
Old 01-04-2012, 01:12 AM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
I enjoy Power Secrets by Smokey Yunick. Not Pontiac specific but a very good read.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 01-04-2012, 01:21 AM
Agree think you got the best covered there.
Old 01-04-2012, 08:21 AM
rad400 rad400 is offline
X2 on the books
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 01-04-2012, 02:10 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
I have Hand's and Osterstocks HO books which are still available new for less than they want for used ones on ebay Like the HO books as they seems to be more detailed in performance mods and assembly. The full size port templates are great as well but.... Everything out there now is pretty well based on the old blocks and heads. Would like to see a book using the new parts, blocks & heads, and power adders that are available to us now.
Old 01-04-2012, 05:42 PM
EXACTLY Thanks now we are getting what I mean. I talked to paul great guy I am on his list for when its done sounds like it will be a winner
Old 01-04-2012, 05:45 PM
I am on Pauls list when its done yes there are alot of gen books out there
Old 01-04-2012, 09:13 PM
No one book is going to do it all.
I think that the Hendrickson/Olsterstock (HO Racing) books started the process.
Then others added to the mix, with some mistakes, but at least they were right 99.999% of the time, LOL.
Then the "Modern" books came out: Cliff's Book, Jim's Book, Rocky's Book, and there will be other books.
Very hard to say the "best pontiac performance engine book".
All have moved the knowledge base ahead greatly, IMO. Collect everyone you can find, sort out the key information, and go from there.
Tom Vaught
Old 01-04-2012, 09:18 PM
Sick of such books & catalogs. My needs are:
A durable Torque-Spec sheet (been using the MOTORS page, back page of a HO Racing manual, and one of the popular PMD Books Tq spec pages, depending on which I find when needed.
A book on Head flow, with the simple equations put to Excel.
