Old 02-14-2012, 05:38 PM
Father&Son73T/A Father&Son73T/A is offline
Originally Posted by 2manyT/A'S View Post
Not a BAD looking car,but too many things wrong for 40K,I think.
http://www.fastlanecars.com/classic-...-8ae0b00f3990#
It must have taken a hit on the right side,as BOTH R fender & door are replacements.
Body color paint under hood & lack of wrinkle paint on steering wheel hub.
Bonus points for plastic lower valance.
I can't get over the "Baja 1000" look..
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #1262
Old 02-14-2012, 05:55 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
saddly, most that get new springs end up like that.
same as others, i wouldn't kick it out of my garage, but i would fix a few things;
paint the intake
unpaint the bottom of the hood
put on the right short spoiler end pieces
i like the chrome valve covers, but they are wrong
fix the pass door, not that hard
find a replacement aircleaner(i have an extra, but the parts place sells repos)
install driver side exhaust manifold heater shroud, and tube to aircleaner
does the 72 have or need the console clips for the seatbelts? not sure on that one.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #1263
Old 02-14-2012, 05:59 PM
njsteve's Avatar
njsteve njsteve is offline
Depends on if it has the early style seatbelts or the later ones (post Jan 1st of 72)
  #1264
Old 02-14-2012, 06:11 PM
thats what i was thinking, but the only 72 i have had was for parts several years ago.
72 base bird. except for bad quarters it was really nice. kept the white interior, 72 rust free doors, sold the front clip, then just stripped it down to a shell and junked it. used most of the 72 nuts and bolts to put a 73 TA back together.
FREEDOM ISN'T FREE
  #1265
Old 02-15-2012, 12:27 AM
165th's Avatar
165th 165th is offline
Hi Warbird, what did you ever do with the white interior? Was it standard or deluxe?
  #1266
Old 02-15-2012, 02:34 AM
it was standard. seats are in my spare room, door panels are in my garage attic. been thinking of using a 73 bird body i have to do a blue/white everyday driver.
FREEDOM ISN'T FREE
  #1267
Old 02-19-2012, 07:07 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Interesting story on this one off 72 "SCCA" Trans Am in current HPP.
http://www.google.com/imgres?q=1971+...k3fjRAQ&zoom=1
  #1268
Old 02-19-2012, 07:57 PM
SD73's Avatar
SD73 SD73 is offline
Very cool car! Thanks for posting, Parrish. My one druther is that column shift.
  #1269
Old 02-19-2012, 11:05 PM
The Boss's Avatar
The Boss The Boss is offline
That car is KILLER in Red.
And go racin' in the street.
  #1270
Old 02-20-2012, 02:40 AM
giles's Avatar
giles giles is offline
The last TA Nats I attended was in '07. A guy had a beautiful 71 white blue interior, no option TA. Literally the PHS invoice was blank. It was an automatic car so with no console it had a column shift. The owner (and I think it may have been a 1 owner) said it was ordered new to be drag car, so no options.
Now that car was Cool!
  #1271
Old 02-20-2012, 07:03 AM
FrankieT/A's Avatar
I'm partial, that's the car I copied.
  #1272
Old 02-20-2012, 08:06 AM
bossbirdta's Avatar
i think this be Her......They do look a bit Odd with the selector on the Tree.
ID:	275525   Click image for larger version
  #1273
Old 02-20-2012, 08:15 AM
Brewster's Avatar
Brewster Brewster is offline
I dont care for the bare hump look, it just aint right!
  #1274
Old 02-20-2012, 08:36 AM
165th's Avatar
Now now.... As you know beauty is in the eyes of the beholder!
  #1275
Old 02-20-2012, 01:37 PM
OVERULD's Avatar
OVERULD OVERULD is offline
X 2, and a rare column shift and less than 6K on the clock for good measure. Amazing car.
BJ
  #1276
Old 02-22-2012, 10:38 PM
PONTIAC-ONE's Avatar
PONTIAC-ONE PONTIAC-ONE is offline
455HO...7F6 head questions.
From the info I gathered, looks like I will need a HO specific rear upper A/C compressor bracket, do the '73-'74 SD's use the same bracket and does anyone re-pop them?
Can a non HO bracket be altered to work? (I don't have any brackets or the Compressor yet so I can't check)....anyone have a good pic of this bracket?
Thanks.
2 sons, 2 Firebirds. 1971 Formula 455, 1972/w 455 HO added.
1974 Formula 400 "retired", parts car now.
  #1277
Old 02-22-2012, 10:51 PM
Barry Martin (Sonic Motors) had the bracket repro'ed, they are just '71-72 HO application. Before he had the repro HO rear brackets stamped I used to mod one of the Pontiac Dport rear braces with sections off another GM application bracket, cutting, grinding, welding, grinding, priming, little bodyfiller. lot of time involved.
Upper dipstick tubes are also different than D-port. PY had the '72-74 roundport version done, & its cheap. '71 HO's are another animal. A/C application 71 HO A-bodys & F-bodys were actually different from each other, as well as the dipstick.
  #1278
Old 02-22-2012, 10:55 PM
bossbirdta's Avatar
Originally Posted by PONTIAC-ONE View Post
455HO.....anyone have a good pic of this bracket?
Thanks.
here ya go......
  #1279
Old 02-22-2012, 11:19 PM
Thanks guys, I found Barry Martin's ebay page, Sonic Motors.. so I'll give him a call. Trying to put the A/C back on this car has turned into my own little nightmare but I'll get it done.
  #1280
Old 02-22-2012, 11:33 PM
165th's Avatar
Here's some pictures of Sonic Motor's repro bracket next to an original one. The repro is virtually identical, and would be undetectable in my opinion to an original.
ID:	275899   Click image for larger version
ID:	275900   Click image for larger version
