Old 02-25-2012, 10:43 AM
FAT CAT 2+2 FAT CAT 2+2 is offline
Default 65-66 B body dash pad compatability
What models have the same dash as the 66 2+2 catalina?
Wondering if 65's will work.Are they the same?
Old 02-25-2012, 11:28 AM
chiefpontiac66 chiefpontiac66 is offline
I'm not sure about non-a/c cars, but my 66 a/c dash pad was not the same as 65.
Old 02-25-2012, 11:54 AM
65WJ's Avatar
65WJ 65WJ is offline
the front lip is different. 65 is flat 66 is round. On the A/C cars the vent is in the middle for the 65 and on top for the 66. Other than that they are interchangeable.
patrick
Old 02-25-2012, 11:55 AM
stevep's Avatar
stevep stevep is offline
You can make them work, but they are not the same.
Old 02-25-2012, 12:52 PM
66bonne's Avatar
66bonne 66bonne is offline
I agree with SteveP. They are interchangeable. Since the Catalina pad only covers half of the top of the dash you should have no problem with fitting a 65 to 66 or vice versa.
If you have an A/C car then you need to use the a/c plenum that goes with that particular year.
Jim
Old 02-26-2012, 11:35 AM
Thanks guys!
So, there are no other models in 66 that are the same as the catalina/ventura/2+2.
Old 02-26-2012, 12:10 PM
65WJ's Avatar
They are all the same for all models with the difference in appearance listed in previous posts.
When removing there is a screw the protrudes through the firewall by the wiper transmission. It can be a real pita if you do not know about this last nut.
patrick
Old 02-27-2012, 12:24 AM
Thanks for the info.
