Old 02-25-2012, 07:54 PM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
Attached are the pages for 70-74 starters and all the Part #'s
As you can see, some of the internal parts change the like the Coil Field #8, Armature #10, Switch #17 and Stud lever #22 for the starter #'s I listed previously.
I" 95 % sure the HO and SD starters were "Hi-Torque", but not sure about all the applications listed. The exploded diagram shows the copper buss bar of the Hi-Torque,
but that may change with the different Coil field #'s. Just my assumption, perhaps others can add to this.
My guess is someone changed your solenoid because that's what they had that looked similar and would bolt up correctly.
I put these up as high res files so they could be printed and still be read.
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
