Old 04-19-2012, 07:38 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Talking
If you're throwing the old shocks out, I'd use vice grips to hold the shaft up top while you loosen the nut. That's just me though.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #3282
Old 04-19-2012, 09:19 AM
73brewstersd 73brewstersd is offline
Thanks Bob, thats actually what I did but the nut was acting as if it were welded to the stud. I stripped that top part off with the vice grip. I am throwing these away, they arent original equipment so I'm not interested in keeping them.
  #3283
Old 04-19-2012, 09:23 AM
Did all Super Duty's come with Positraction? I only ask because last night I "accidently" got on it. It was pretty smokey when I came back to that position, I then noticed only 1 wheel was creating that smoke. I'm not sure if I have a problem...
  #3284
Old 04-19-2012, 09:46 AM
Wink
All T/As came with posi, especially the dutys.
Bob Woodard
Brighton, MI
  #3285
Old 04-19-2012, 09:52 AM
I might have a problem then. Thanks for the info.
  #3286
Old 04-19-2012, 12:48 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Exclamation
But NOT the SD Formy's - isn't that crazy? Seen more than one SD Formy invoice w/o G80 . . .
Regards,
"455HO" Lloyd
  #3287
Old 04-19-2012, 01:16 PM
Talking
I rarely speak about the little brother! LOL
Let the thrashing begin!
Bob Woodard
Brighton, MI
  #3288
Old 04-19-2012, 01:23 PM
I definitely have the G80 option, I'll have to have this looked at, I just probably have something wrong. I do think it's wierd that a SD left the assembly without posi. It seems like they'd all have the G80 option.
  #3289
Old 04-19-2012, 03:12 PM
formula kid formula kid is offline
Talking
As I remember all Trans Am' s were factory equipped with posi. All other firebirds regardless of engine it would have to be ordered.
  #3290
Old 04-19-2012, 03:56 PM
Lloyd-TX's Avatar
Question
A bit off-topic for this thread, but as I recall there WAS a model year or two that G80 was optional the 2nd gen T/A. 1976 comes to mind . . .
Regards,
"455HO" Lloyd
  #3291
Old 04-19-2012, 04:04 PM
Lloyd-TX's Avatar
Worn out clutches in the diff. Not at all uncommon on a 40 year old car . . .
Next time you want to smell tire smoke try brake torquing that diff. "Brake torquing" increases the diff posi clutch pre-load and helps to make both tires spin . . .
Regards,
"455HO" Lloyd
  #3292
Old 04-19-2012, 04:46 PM
Held for Ransom's Avatar
For the front shocks, I just place a deep well socket with extension on the nut and bend it back and forth until it snaps.
  #3293
Old 04-19-2012, 11:54 PM
74 SD455 Formula 74 SD455 Formula is offline
Lloyd,
I did'nt know that until now.I thought the same way that all SD's came with a posi,but I just looked at my original widow sticker and "whammm" there it is Safe-T-Track- diff. $43.00 option.
  #3294
Old 04-20-2012, 11:22 AM
Where can I find the proper part number for the clutch plate assembly? I've searched online, I feel like I cannot find the same answer twice. Any suggestions from you experts? I really appreciate the help guys!
  #3295
Old 04-20-2012, 11:46 AM
Lloyd-TX's Avatar
The clutches ARE most likely available for that differential, however . . .
It's NOT a real easy job to replace them, I'd recommend replacing the entire posi diff.
My .02 . . .
http://www.ringpinion.com/b2c/PartsL...=211&BrandID=7
Regards,
"455HO" Lloyd
  #3296
Old 04-20-2012, 04:56 PM
johnta1 johnta1 is online now
Well....
Couldn't let PB have all the fun.
Had this site (among a few others):
455 SD
  #3297
Old 04-20-2012, 06:39 PM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
Default About time...
Well....
455 SD
I like the front page! Glad you picked a Buccaneer SD! As we all know, they are the faster ones,
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
  #3298
Old 04-23-2012, 07:27 AM
Brewster's Avatar
Brewster Brewster is offline
Faster, is that why they call it arrest me red?
  #3299
Old 04-23-2012, 07:41 PM
Norwood's Avatar
Norwood Norwood is offline
Bob, I understand but that really dosen't make sense...
  #3300
Old 04-24-2012, 01:33 AM
That's because he is all MOPOOR now, oops, did I misspell ?? Sorry Bob.......had to do it !
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
90 300zx TT 5spd.
