Old 04-23-2012, 12:52 PM
2manyT/A'S's Avatar
Originally Posted by Super Duty D View Post
2many,
I'm thinking valve springs..... could be carb though, you have a valid piont. Maybe I sould experment with the extra SR SD carb I have, just to be sure....
Any other thoughts...... anyone......
SDD
Those SD carbs are pretty HEAVY with all that emmissions CRAP on them....
Try one from a LATE 70's 301,they are bigger & should flow some better #'s than the SD carb.
Eye Candy......garage band?
Go full screen & turn it UP!
  #1302
Old 04-23-2012, 04:05 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Thumbs up
2many,
SDD
Good thought. The SD SR carb is nicely calibrated right out of the box. Check total timing and verify that the centrifugal advance is working as well.
Good luck!
Regards,
"455HO" Lloyd
  #1303
Old 04-24-2012, 01:25 AM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
Thanks for all the help 2many,
Your sarcasm is noted...... Got a better carb to lone me?
Just kidding with ya.....
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
  #1304
Old 04-24-2012, 12:13 PM
Norwood's Avatar
Norwood Norwood is offline
SDD
That SD carb was truly WICKED on my RAIII
  #1305
Old 04-24-2012, 07:48 PM
Right on brother! How is she running now with that super duper triple hippo carb that Cliff R set up for you? (or do you still the car have it apart?)
Speaking of that I just ordered the new accelerator pump from Cliff with the ethanol approved seals for my #'s matching carb for the 73 SD and wanted to take you up on your offer to help me install it. And, I could finally get your keys back to you!
Lemme know if you want your keys back! LOL. Holding them for ransom! Ha Ha !
Seriously, we could do the cave thing and maybe Brewster could just SHOUT orders at us while having a cool one......?
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
90 300zx TT 5spd.
  #1306
Old 04-24-2012, 09:18 PM
Norwood's Avatar
If we are gonna work on the car we need to send Brew out for a Pizza and then do it when he's gone...LOL
  #1307
Old 05-01-2012, 08:22 PM
Good luck!
Yep, The SD SR carb was just the ticket! She runs WAY better now.
Thank you everyone for the input, it got me thinking back to my initial direction and sometimes that is a good thing! Sometimes ya just can't see the trees standing in the middle of the forest.
My initial thoughts were that it was starving for fuel, but after checking timing, distributor advance, fuel pump and filter, I hooked up a vacuum gage and saw a bit of flutter so I started thinking valve train. Guess that is where I got off track......
Anyway I did observe that the air flaps for the secondaries were quite tight compared to the SR carb that almost seemed too loose; barley returned to closed when pushed. I checked the carb on my 74 Formula and they "felt" much lighter than the HO carb, but stiffer than the SR SD carb, so maybe I just need to adjust the spring tension on the HO carb. I will try that next I think
Only other thought is the two feed tube pressed in the the bottom of the air horn, perhaps one or both have fallen out. I here this can be a common issue.
Sorry for the long post, but I am thrilled that this may be the issue and will not have to start pulling the heads
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
90 300zx TT 5spd.
  #1308
Old 05-12-2012, 09:40 AM
1971455HO's Avatar
1971455HO 1971455HO is offline
Bump... sorry, had to go looking for it. I love reading it over and over.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #1309
Old 05-17-2012, 11:26 PM
165th's Avatar
165th 165th is offline
I just posted in the Super Duty Forum and suddenly realized I needed a 455 H.O. fix before I lost my bearings
PB, there is a great artilce from (I think) Pontiac Enthusiast... circa 2010 titled 'Out of the Shadows' that dyno's a '71 455 H.O. This would be a great article to link to your website and here too. Unfortunately I haven't been able to find the online version of it.
If anyone has it would you please post. Thanks.
  #1310
Old 05-18-2012, 03:49 AM
2manyT/A'S's Avatar
Cool Barn Find.....in my own BARN!
Almost forgot I had this one.....couldn't see it for all the sh*t I had piled on it!
First time out in the daylight for 7 years.
Started right up like it had been parked for 2 months & ran like a CHAMP! (try THAT one with a WOMAN)
Took it out for a run on Saturday.......455 HO with an M22.......what more do you need to say?
ID:	284881   Click image for larger version
ID:	284882   Click image for larger version
ID:	284883   Click image for larger version
ID:	284885   Click image for larger version
  #1311
Old 05-18-2012, 07:12 AM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
hence the name: 2many!!!!
  #1312
Old 05-18-2012, 09:32 AM
Formulabruce's Avatar
How cool, your own barn find! Looks nice!! what year is that one>?
  #1313
Old 05-18-2012, 09:59 AM
Norwood's Avatar
NICE....Maybe I should clean my garage out and see if I have something like that stashed
  #1314
Old 05-18-2012, 10:07 AM
Lloyd-TX's Avatar
Question
From what I can see of the thermal vacuum switch on the intake, it's a '71.
EDIT: studied that engine pic again and it's definitely a '71 - it's got the "east-west" mounted choke thermostat on the intake heat exhaust crossover.
Note to 2many: "you need to get out more", LOL.
Regards,
"455HO" Lloyd
  #1315
Old 05-18-2012, 02:06 PM
2manyT/A'S's Avatar
Tis a 71 and mostly original,notable exceptions being a 744 cam upgrade,vintage Flowmaster transverse exhaust,Radial T/A's & a set of vintage Ricky Ricardo seats.(AND 72 deluxe door panels....)
I've added the Honeycombs & rear bumper guards....but have original KR's stashed.
The original seats are in the trim shop getting repaired (as we speak) but I COULD really use a BETTER drivers door panel (71 blue deluxe),if anybody knows of one?
I've heard mixed reviews on the repop door panels & would prefer to stay with ORIGINAL for color match reasons,etc.
Can't WAIT to get my allowance tomorrow morning & I figure I'm going to spend MOST of it on GAS!
  #1316
Old 05-18-2012, 03:13 PM
FrankieT/A's Avatar
I was under the impression all 71's had honeycombs.
  #1317
Old 05-18-2012, 03:54 PM
2manyT/A'S's Avatar
If I'm remembering right......
Just checked my 71 selling facts,71 Trans am base wheels were 15x 7 Rally II's & the H/C's were a $37.00 upgrade on the T/A.
  #1318
Old 05-18-2012, 04:12 PM
Lloyd-TX's Avatar
2many is correct . . .
15x7, 14" center Rally IIs were standard fare on the 1971 Trans Am - a few very ealry cars had the "KN" coded wheels, while most were shod with KRs.
15x7 Honeycombs were optional.
All 1971 15" Honeys were equipped with the plain center caps and NO TRIM RINGS!
Regards,
"455HO" Lloyd
  #1319
Old 05-18-2012, 04:31 PM
goathead455 goathead455 is offline
Allowance day is early,I thought it was the last Wednesday of the month.
  #1320
Old 05-18-2012, 05:25 PM
FrankieT/A's Avatar
Can you guys tell me what the letter codes for wheels that were 15" rally II's and did Not take a trim ring. And, we're they '70 only? I know the profile of the wheel where the acual rim meets the center section is different on these wheels.
