Old 05-01-2012, 10:37 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
This is great news. Congratulations on hopefully becoming a GM licensed vendor. A lot of guys have been counting on you. if I understand what you wrote, you are stating $408.00 for stripes only? I have a white car and I've been interested since you started. Mine has whatever brand Ames sells. I think their PG. They look good, but, I'm sure Mr. Norwood would spot any flaws from across a parking lot LOL. I do need some help or advice from any of you. Who... is good at installing these? I had to buy two sets because my restoration guy didn't have any experience with early birds that have stripes. He got it right the second time and he probably would again, but I'm just asking for any good techniques, details or tricks on installation, especially on making the transition down through the shaker opening. How hard is it to remove them after being installed for about 6 months and not hurt your paint? Any Ideas guys.
But, to confirm my answer 165th, if you finally got them looking right, yeah, I want a set of stripes for a white car.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #162
Old 05-01-2012, 10:50 PM
666 the legend's Avatar
666 the legend 666 the legend is offline
When I did my stripe hood..from what i remember..I folded the stripe down the center.. not too sharp... but just enuff to make it lay on top of the center body line...and I just used couple dabs of soap and water..
  #163
Old 05-01-2012, 10:54 PM
and on stripes..you can also do the..HINGE Technique.....thats when yah put the decal where yah want it...put tape on the corners to hold it down...and then yah put a long piece of tape across the center........and yah pull up half the decal..peel the backing paper...carefully cut the backing paper with razor... wet decal and car.......and lay that down...then when done....pull up the other half and do the same.......thats so everything stays in place...
  #164
Old 05-01-2012, 11:07 PM
Old 05-01-2012, 11:08 PM
Old 05-01-2012, 11:11 PM
Old 05-02-2012, 12:26 AM
165th's Avatar
165th 165th is offline
Great, thanks for noting your interest! The sales price will be for a full kit, including all the stripes, nose bird, letters, 455H.O. and plastic squeegee for application.
Regarding removal, there is a product 3M makes that can be sprayed on decals to aid in removing them without harming the paint. I'm not sure what it is, but I guess I may need to know that!
Regarding application of the new stripes, I am also now an official distributor of Rapid Tac products. I will be offering their 4 oz spray Rapid Prep and Rapid Tac for those of us who are doing one time installs. Soap and water, water with alcohol... all those techniques are good inexpensive "techniques" of wetting the surface for application, but the amateur may not get it right.... So that's why I believe in the Rapid Tac products. Since this is an expensive one time shot, you might as well stay with the best.
Watch this video:
http://www.youtube.com/watch?v=qMo2A...layer_embedded
and it should give you some confidence it can be done. Here is their website:
http://rapidtac.com/
I'll have pricing and availability with the stripes later this month.
Finally, regarding placement, I like how KeePat did it. You can see his application tricks on the sticky on the top of this board. The Rapid Tac folks are using a grease pencil to make match marks which is also a good tip.
666, can you post a picture or two of your technique?
  #168
Old 05-02-2012, 01:15 AM
Nor-Cal 70T/A's Avatar
Nor-Cal 70T/A Nor-Cal 70T/A is offline
I'm still in for a set of blue stripes for a white car, as soon as your first run is ready.
BTW, mine is Polar White not Cameo, but that doesnt matter does it?
-Larry
  #169
Old 05-02-2012, 01:16 AM
A Schab A Schab is offline
What kind of shelf life will these decals have?
  #170
Old 05-02-2012, 06:41 AM
1970TA's Avatar
1970TA 1970TA is offline
I'm in for a set of blue for my white 70.
  #171
Old 05-02-2012, 06:56 AM
comanchefirebird comanchefirebird is offline
Count me in for a full set of blue stripes for my 70 Polar White TA
Thanks,
Steve
  #172
Old 05-02-2012, 07:14 AM
165th's Avatar
-Larry
The shade of white on the car will not matter. The blue stripes will be exactly as the NOS stripes, so the blue is an aqua/blue color. Very pretty and a strange one off color, but not close to Lucy Blue. Some here have indicated a Lucy shaker looks fine next to the blue/green stripe.
Does anyone have an original paint shaker to weigh in on the color the shaker was originally?
The shelf life should be 40 years or so, similar to the original stripes, however, if extended shelf life is anticipated, I recommend they be removed from the shipping tube and stored flat and inside in a cool dry place. This is needed primarily for the transfer paper and backing paper (see my rants on this topic in other parts of the thread) more so than the decal itself.
  #173
Old 05-02-2012, 07:16 AM
165th's Avatar
Thank you NorCal, 70 and Comanche, I have you down!
  #174
Old 05-02-2012, 09:25 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Talking
Original shaker color on a white car was Lucy Blue. It DID NOT match the stripe color. This was documented by an original owner of a 71 that had to repaint his shaker due to a stone chip. The correct color match was Lucy Blue.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #175
Old 05-02-2012, 10:42 AM
RAIVJUMB's Avatar
RAIVJUMB RAIVJUMB is offline
I will take a set for a white car. I have the original paint shaker for the car as will and have posted a pic of it on here before and can attach that if needed, but what the prior post has stated i believe to be correct as the shaker is a dead on match with my Lucy blue GT-37. Mark
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
74 SD T/A Admiralty Blue Auto
others that reside in the barn too
  #176
Old 05-02-2012, 12:11 PM
Norwood's Avatar
Norwood Norwood is offline
And me too....
  #177
Old 05-02-2012, 02:37 PM
MixedMuscle MixedMuscle is offline
i would like to get on the list for a set for a white '70 if it is not too late to do so.
thanks,
Gerry
______________________
70 T/A RAIII 4 spd
69 Firebird 400 Cvt
  #178
Old 05-04-2012, 12:07 PM
Scott455HO's Avatar
Scott455HO Scott455HO is offline
As I stated earlier, I'm in need of a blue hood stripe only for a cameo white 71 car. Let me know when you have a price please.
"Look out for number 1, don't step in number 2." Rodney Dangerfield, Back to School
71 TA 455 HO
  #179
Old 05-16-2012, 07:40 AM
165th's Avatar
Thank you Bob and Mark for the reminder the shaker is Lucy Blue.
The inks have been matched perfectly to the NOS colors. The blue/aqua stripes is dead on. I can't believe they did that.
The white on the black/white stripe is not bright white. It's leaning to, but not quite Cameo white. Of all the different colors of white I looked at, when viewed on the Lucy Blue framed in black it really didn't matter hardly at all. It looks very very nice!
Thank you Mixed Muscle and Mark for your interest. Never too late!
Some have asked for individual pricing, and I will sell them in that manner in order to be as flexible as possible. I will update everyone with individual pricing just as soon as the licensing is done done.
Still looking at selling late the week of May 21 or the week of May 28.
Closer!
  #180
Old 05-28-2012, 12:06 PM
165th's Avatar
What started out as an endeavor to create an individual set of high quality stripes for my Trans Am’s has turned into an opportunity to provide full stripe kits to the Pontiac Nation. The first post on this thread was just over a year ago, which is a testament to how difficult this project was. Of course, looking back on it may makes sense, as during my due diligence, I could not think of a car ever produced that has more surface area covered by decals and stripes! This is probably why it was so important to me to get these right in the first place.
I can also assure you it would not have come to be without everyone’s support on this forum! I have thanked many of you on here before but it needs saying again and again… Thank you for your input, NOS samples, technical advice and encouragement. The stripes are in production with a projected delivery date the week of June 4.
Sales: Starting today I will begin accepting orders for the stripe kits. I created a website to support the sales effort. You can purchase stripe kits by visiting the following website:
www.TransAmStripes.net
When purchasing, if you would please tell me your PY handle in the “Special Instructions” section of the checkout that will help me manage the requests that have been coming in on this thread.
If you are interested in individual stripes there is a link to email me with your specific needs I’ll provide pricing for individual parts with my response.
Please note that orders taken over the next couple of weeks will not be filled until the week of June 4 at the earliest or as late as the week of June 11. If you would prefer to wait until the kits are in hand that will be ok too. I’ll keep everyone posted when the inventory is available. Also keep in mind I tried to balance the production run with the interest, so the total number of kits made is somewhat limited. If you’ve expressed an interest it may be best to purchase now to ensure product from this initial run is available.
Also linked on the website is an opportunity to purchase Rapid Prep and Rapid Tac application fluids. TransAmStripes.net is an authorized distributor of Rapid Tac and I have these products in inventory. I have been using Rapid Tac for application of the proofs, and I highly recommend using it for this one time application of these stripes. Shipping is separate because I will not ship any fluids in the same packaging with the stripes.
After the initial sale of these kits over the next several weeks, Performance Years will take over sales of for the PY members. I’m also coordinating with PY to have a set of stripes available at the upcoming open house June 14 – 16. www.TransAmStripes.net will remain up as well however.
GM Licensing: These stripe kits are GM Licensed! In the last few weeks, production had been held up until there was certainty the kits would be able to be GM Licensed. As you may imagine since this is a seemingly low production item the cost of of licensing per unit sold would have been too great. So, in order to keep the product affordable TransAmStripes.net has teamed up with Stencils and Stripes Unlimited as an authorized distributor of GM Licensed products. Stencils and Stripes will retail these kits as well.
Thank you in advance for your continued interest in these great stripe kits!
