Old 05-08-2012, 06:11 PM
OldS-man OldS-man is offline
Default 62 Tempest trim tec tip
this is the trim piece that goes on roof by the rear 1/4. I remember reading on here
about the clips that hold this part on are hard to locate new.
so this is what I did...
went to NAPA and got these plastic clips. Had to trim them some. Put
a little silicone sealant in the hole to help keep water out. And being plastic
they don't chip the paint when installing them.
they fit tight to the body like the stocks ones.
just thought it might help someone......
Old 05-08-2012, 09:59 PM
Keith Seymore's Avatar
The picture is a little blurry (or my eyes are a little blurry) -
Are those a "Christmas tree" type fastener?
K
'63 LeMans Convertible
'63 Grand Prix
Old 05-08-2012, 10:05 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
That is cool. Next time I'm messing with that area THAT's what I'm going to do. Great Idea. John
Old 05-08-2012, 10:17 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Looks like the plastic push pins used for door panels on different cars. Great idea!! Trim the sides down a bit & slide them into the stainless trim. Should work just fine.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 05-09-2012, 07:18 AM
GaryK's Avatar
GaryK GaryK is offline
Thanks! Great idea!!
Old 05-09-2012, 09:30 AM
beemergary's Avatar
I've trimmed a few of those metal butterfly clips to do the same thing. Those plastic ones look easier too take off and may want to fit tighter. GOOD JOB
Old 05-09-2012, 04:20 PM
yes the picture did turn out a little blurry,its not your eyes.
they are the Christmas tree type . I just looked threw their clips
section. The have a small dome to the top.
Hopefully I will never have to remove them. But shouldn't be to bad.
May have to "GENTLY" pry away from body just far enough to get a razor blade
and cut the head off.
when installing them I made them fit tight by trimming just enough off
to force it into the trim and then use a wooden paint stick to push
the clip into location.
Glad you liked it.
