Old 05-21-2012, 03:20 PM
666 the legend's Avatar
666 the legend 666 the legend is offline
Old 05-21-2012, 03:39 PM
so basically...Paint the grill FIRST..then just place the template over the grill and paint the argent...and WAH...LAH...!!
  #183
Old 05-21-2012, 03:42 PM
Pepi's Avatar
Pepi Pepi is offline
I can't see the pictures
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #184
Old 05-21-2012, 03:59 PM
why do I keep having this PIC problem..?? I can see it but know one else can..What do I need to do to fix this problem..lol..WTF...lol
  #185
Old 05-21-2012, 04:06 PM
Pepi's Avatar
IDK...I have very little computer knowledge, just enough to get into trouble sometimes
  #186
Old 05-21-2012, 04:10 PM
njsteve's Avatar
njsteve njsteve is offline
I did use heavy paper to mask the grill area. And since the left and right are mirror images of each other, I only had to make one mask and then just flipped it to use on the other grill. The problem is that the silver will mist around the edges from the overpressure of the spraycan. So the masking tape was needed to seal the grill edges more tightly.
  #187
Old 05-21-2012, 04:11 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Quit uploading pictures on sites that doesn't allow everyone to have viewing access.
  #188
Old 05-21-2012, 04:25 PM
Gotcha...Thats my problem..Thanks..
  #189
Old 05-21-2012, 04:57 PM
Formulabruce's Avatar
Originally Posted by murphc4 View Post
Did you just buy the standard kit from them that says it will cover about 33 sq ft? I was thinking of putting this on the roof and in the doors as well. Also, do you just put the carpet directly over this, or still use an under lay?
Sent you a PM ( people do you use on the doors, I used the plastic water shields with the 3m sticky string
  #190
Old 05-21-2012, 05:19 PM
The Boss's Avatar
The Boss The Boss is offline
Originally Posted by njsteve View Post
I'm putting in new tar paper insulation and carpet. The old carpet was a replacement and it wasn't trimmed properly when installed. Plus it smelled oily from the rust proofing goo. The head liner needs to be replaced as it is the wrong material and was most likely done when they installed the new GM quarters back in the 1980s.
Good - any plans to bring it to the PY open house? I'd love to see it.
And go racin' in the street.
  #191
Old 05-21-2012, 05:31 PM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
"Give A Mouse A Cookie"
I assume you have kids & read the book :-)
Car is looking good!
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
  #192
Old 05-21-2012, 05:34 PM
njsteve's Avatar
I will probably bring it, that is if I can get it all titled and registered by then. I got in touch with the NJ DMV today via the telephone (a feat in and of itself), and yes, the title application for any foreign purchased vehicle has to be processed through the mail at their headquarters in Trenton. I sent the whole package of original forms, docs and a check, off today via certified mail. Hopefully it will make the 20 mile trip through the US Mail in the next few days. Once I get it titled I can then get the plates pretty easily.
  #193
Old 05-21-2012, 05:36 PM
The Boss's Avatar
Cool - great news!
  #194
Old 05-25-2012, 09:31 PM
njsteve's Avatar
Default Pressure washing time, Part Deux!!!
So, 7 years and 3 days after this:
It's cleaning time again!
I set the car on some truck jackstands to get it in the air as high as possible and then soaked the underside with purple stuff cleaner diluted with 2/3 water.
It then donned the Tyvex suit and face shield (much better then the raincoat I wore back in 2005). I then spent the next 8 hours pressure washing the underside. I think the key to getting the undercoating off this time was using hot water. I ran a heavy duty garden hose through the window and hooked it to the washing machine hot water feed. It worked great!
Half way through the day I ended up pulling the aftermarket exhaust to get a better angle on the floor boards.
  #195
Old 05-25-2012, 09:38 PM
njsteve's Avatar
Here are some preliminary shots while the car was still wet. That hot water worked well on the 40 year old undercoating. I definitely was a smart idea to get a full face shield. When the 3000 psi hot water hits the undercoating it tends to blow it off in chunks that fly back at you. The black you see on the frame rails is the original black overspray, though it looks kind of grey when wet.
The undercoating came off the tank nicely to reveal the original date stencil.
Original vapor cannister hoses in place (unclamped as originally installed at the factory)
  #196
Old 05-25-2012, 09:42 PM
njsteve's Avatar
The floorpan. Gotta get rid of that white paint on the driveshaft!
  #197
Old 05-25-2012, 10:16 PM
Pepi's Avatar
cleaned up nicely.
  #198
Old 05-25-2012, 10:43 PM
Really looks great Steve! I noticed the part numbers on the springs showed up well.
Guess youll be getting another beer Glass from Pennsylvania??
Its amazing how the floors look so good and the rear frames dont, seen this on my 71's
Another win for the purple stuff, hot water, pressure washer and NASA!
  #199
Old 05-25-2012, 11:50 PM
njsteve's Avatar
Actually I think those are aftermarket springs. Ill get a better shot tomorrow but I can see thay have a "Made In" stencil the rest of which is covered by the spring perch and the part number doesnt look GM.
I need the rear springs that Norwood put on his car to make it sit an inch or two lower.
  #200
Old 05-25-2012, 11:55 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
Wow! Nice work. The car has such a cool look, even on jackstands!
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
