Old 05-31-2012, 07:02 PM
Held for Ransom's Avatar
Default 1973 Trans Am air cleaner base
People have claimed the bases are the same between the '73 and '74. I'm sure the decal is located in different places. Does anyone have a picture of a '73, showing it? Also, does anyone have a picture of the vacuum hose clips (or a count of how many)?
Old 06-05-2012, 05:20 PM
I'm not too shocked no one answered. Seems only a few really do. It is a shame.
Decal is in same location on the '73 and '74 units from what I can find.
The reason I was asking is because of this eBay auction...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=150826616193
I believe this to be a '73-4 Formula, std. 4-bbl, not a shaker, air cleaner base.
New owner is going to be upset, unless this is the going price for just the base on these.
Old 06-05-2012, 06:14 PM
When I first read this, put going through '73+ Bird aircleaner bases on my list of things to do. Mike. you do not want to know how many I have stacked & boxed away. Off to another doubleheader.
Old 06-05-2012, 10:09 PM
blue71ta's Avatar
blue71ta blue71ta is offline
Mike,
how do the Formula 4 bbl air cleaners differ from the T/A units? I always assumed they were the same, except for the lid...
Old 06-05-2012, 11:06 PM
The positioning of the hole for the breather required different crankcase vent tubes. The decal was in the wrong place for a TA/Formula SD base. Seller avoided me with dimensions to verify. Probably why there was no lid. I think $181.77 is high for a Formula air cleaner base. But an OK buy for a TA/Formula SD base.
Old 06-06-2012, 01:57 AM
Formulabruce's Avatar
Old 06-06-2012, 03:58 PM
Bruce, that's a '75 or '76 unit.
Old 06-06-2012, 04:41 PM
Brewster's Avatar
Brewster Brewster is offline
Mike is this the shaker your looking for?
Old 06-06-2012, 04:53 PM
73brewstersd 73brewstersd is offline
I'll answer that for Mike and most men.... YES!
Old 06-06-2012, 04:56 PM
form74's Avatar
form74 form74 is offline
I bet those shake really good
Old 06-06-2012, 05:19 PM
Would that be 1 shaker or 2?
Old 06-06-2012, 06:07 PM
ok thxs, I had it marked 73 and it looks like most 73TA bases I have seen.. oh well
Old 06-06-2012, 08:02 PM
SD73's Avatar
SD73 SD73 is offline
HfR knows his stuff much better than I do, but I'm guessing he's noticed the side of your base has provisions for two connections, where as the earlier 73/74 just have the one square hole.
Old 06-06-2012, 08:05 PM
No. But that is an original shaker, see how it sits off center.
Old 06-06-2012, 08:11 PM
Pepi's Avatar
Pepi Pepi is offline
I'll take it for my Formula
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 06-07-2012, 04:38 PM
Father&Son73T/A Father&Son73T/A is offline
Thumbs up
Think those carb needles need "adjusting"?,,,,,,,,,
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
Old 06-11-2012, 07:31 PM
Another shot at it...
Old 06-11-2012, 09:34 PM
Not for a Firebird, that I can tell.
Old 06-12-2012, 12:51 AM
wondered about the debth of the "dish"
I have more LOL we will see....
Old 07-03-2012, 09:27 PM
With the holiday tomorrow and it being too hot to do anything too strenuous, I thought I'd revisit this. Please correct with exceptions. For people shopping eBay, learn here on what questions to ask...
4 barrel Firebird/Formula/Trans Am base will have almost no gap (approx. .16”(1 dime and 2 pennies)) between center hump and straight edge when you lay it across the top. Sensor and carb. vent hole should be across from, not next to, each other.
1973
Has three welded clips for vacuum hoses.
Hole for screw to hold fresh air duct is circular and only on top side.
Sensor is black.
Air flap pin exits to the right.
Trans Am PN decal (Keep your GM car all GM) is located between snorkel and indent.
Measurement between snorkel and air breather hole is 15”.
Formula PN decal (Keep your GM car all GM) is located between air breather and indent.
Measurement between snorkel and air breather hole is 14-1/2”.
1974
Went to four welded clips.
Sensor went to painted black.
Air flap pin exits to the left.
1975
Hole for screw to hold fresh air duct went oval on both sides.
Added a hole in side for vacuum switch.
ID:	289828   Click image for larger version
ID:	289829   Click image for larger version
ID:	289830   Click image for larger version
ID:	289831   Click image for larger version
