WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Exterior Tech
93-02 Exterior Tech Hoods, Stripe kits, T-Tops, Convertible, Ground effects, etc...
Old 05-15-2012, 01:21 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Default The Dreaded melted fog light
So I was in the process of replacing my fog lights when I tried to pull out the bulb only to notice that the place where the bulb is held has melted.
LAME.
I have come up with a game plan to fix this and get some higher wattage bulb (H3) in the stock housing.
ALSO after doing some research I found a place that sells LED replacements for the stock 880 fog lamp
http://www.superbrightleds.com/vehic...irebird/48/524
The LED replacements produce less heat and will not melt the fog IMO, you could probably even jump up to a 893 bulb and or the 50W version and get more wattage but no to little heat because of the LEDs and no filament
Anyways back to fixing the melted fog light.
First thing I am going to do is remove the melted portion (pictures to come)
Then I am going to buy some cheap metal housing driving lights and hack them up to use the back and where the bulb mounts.
To connect the different style bulb I am going to cannibalize the base of the burnt out 880 bulbs and solder the H3 bulb connectors to those 880 bases, that way I dont mess with the stock wiring.
So as this project progresses I am going to posts pictures.
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 06-08-2012, 02:23 PM
Cammer-6 Cammer-6 is offline
I have a 97 thats not a TA and put Hella driving lights in the holes and they work great
looks pretty good too.
here it is in the middle of 2 more of my 4th gens,both of which have since been sold
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-21-2012, 10:06 AM
So finally uploaded the pictures:
Here are my foglights
note how the warped/melted place where the bulb should go
I marked off where I wanted to cut it
Then I cut it with a razor saw for plastic
Old 06-21-2012, 10:08 AM
Here is the foglight that I bought at Pepboys for 19 bucks for the pair.
I am going to cannibalize the rear portion of the housing
I mark where I want to cut it with a file, also note how the place where the bulb goes is similar in size and shape
So I cut it with my dremel
then I cut the sides off so it will mate up with the stock foglight cleanly
Old 06-21-2012, 10:10 AM
After I get the replacement piece all filed and clean, I fit check it. its pretty damn close to perfect
So out comes the JB weld (max temp rating of 450 should be good enough)
And one is done.
here is a comparison
Old 06-22-2012, 01:53 PM
just curious if theres not one thats got a glass and metal housing that could be used for this
Old 06-25-2012, 04:46 PM
the problem with the LT1 Trans Am lamp is that the housing is plastic (Im assuming there is an aluminum lining inside for the reflector, but its super thin), but the lens is glass so the glass is good, but the plastic isnt.
the LS1 Trans Am lamp is plastic/plastic and both melt.
I have seen some Hella replacements that are metal and glass, but they are $150+
Old 06-25-2012, 11:31 PM
I have seen some Hella replacements that are metal and glass, but they are $150+[/QUOTE]
did you see the Hellas in mine?
I love the light those put out.
Only danger is that if you run them too long and turn them off you cant see for a second until your eyes readjust.
Old 06-26-2012, 01:19 PM
Only danger is that if you run them too long and turn them off you cant see for a second until your eyes readjust.[/QUOTE]
nah I havent, did you post them here?
Old 06-26-2012, 05:47 PM
second post
Old 06-27-2012, 09:03 AM
oh, you were talking about the square ones?
Old 06-28-2012, 09:20 PM
no actually they are the F form and look like cat eyes.
the amount of light they put out is phenomenal,even with the stock bulbs.
they come in 2 versions fog or driving
Old 06-29-2012, 12:05 PM
still not sure what you are talking about.
Its this picture right?
and you are talking about the fogs on the red one in the middle?
or another one?
because if you converted to hella on the others I am really interested, since they are basically the same fog on the LS and LT versions, just the bracket is longer
Old 07-08-2012, 07:57 AM
yes the oval ones on the red car
Old 07-09-2012, 01:14 PM
oh they are oval, I see, from the picture I had thought they were square
Featured Vendors
Advertising Info
