Hi I have a reasonably stock 455. I just picked up a st of 6x 4 heads to replace my big chamber 4x heads (unported). I typically run 14.2s with the stock 3.08 gears in my 68 lemans. Im running a stock cam as well. I have a lunati bracket master 2 cam on the shelf. Its 292/292, 230 @ .050, and 490 lift. Im just tring to pick up a little et, and gain a rougher idle. On the same token, I dont want to over cam it? If its too much cam, I might just bolt on the 6x heads with some roller rockers, and gain some compression. Any opinions greatly appreciated.
Btw i also have a performer, a performer rpm intakes, and 2200 stall converter.
1968 pontiac lemans 400. 13.16@102/8.5:1 /6x-4/lunati bm 2 cam/ 3500 stall/3.55 gears. |
230/230 @ .050 is low risk in you 455 goals. See 12.2 ET signature on 89 Octane. Stars, idles without fouling, sounds right, runs hard.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
awesome! The 6 x heads i picked up came with screw in studs, guideplates, good valvesprings, roller rockers. I think with the stock pistons and 6x heads i will be around 9:1 cr. way better than 8 to 1. I have been researching the bracket master for a pontiac , but couldnt find too many opinions on it.
I run the bracket master II in my basically stock 30 over 400. Runs 12.7s in a 4000 pound lemans street car with mild converter and 3.73 gear. I shift at 5200 with stock rods and pistons. It has a nice thump at idle to. I have used it in two separate 400s and am happy with it.
I all so run it in my car , works well .
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19 http://www.youtube.com/watch?v=6PaHbLnszS0 http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109 http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60. |
cool. Im happy to here this. I am planning on keeping the 3.08 gears.
I ran that cam in a 400 in a 3400lb car with 3.73 gear on pump gas and ran consistent 7.70's in the 1/8 with a best of 7.67. Has a nice sounding idle and performs pretty well.
what heads were u running?
I was running 62's with a clean up on the runners and gasket match to the Fel Pro 1233 intake gasket, Performer RPM intake and a 750 Holley double pump carb.
