Old 09-02-2012, 12:28 PM
blue71ta's Avatar
blue71ta blue71ta is offline
love that Sandlewood; nice job
  #282
Old 09-02-2012, 11:32 PM
I worked on the doors today. The glass was crap so I had ordered new tinted glass for both doors. I got my new door panels from legendary last week and they included new felts for the window guides so I installed them. They are peel and stick but I didn't trust them to stick, so I glued them on.
ID:	296287   Click image for larger version
ID:	296288   Click image for larger version
ID:	296289   Click image for larger version
ID:	296290   Click image for larger version
  #283
Old 09-02-2012, 11:43 PM
While I had the door glass out I installed the sound/heat insulation to the door skins. I first cut them into strips about six inches apart (photo 1), then I was able to slide them between the door skin and the brace by pushing them down from the top, (photo two). In order to keep the stuff from sticking halfway down the door, I cut the backing paper about 2/3 of the way down, leaving the bottom part with the backing paper still on. I then slid the insulation behind the brace. Once I got the top to stick, I pulled the bottom part up and removed the lower portion of the backing paper, then stuck the insulation to the door skin. Photo 3 shows the first piece installed and photo 4 shows how it looked when done. I was able to get about 3/4 of the inside of the door done.
ID:	296292   Click image for larger version
ID:	296293   Click image for larger version
ID:	296294   Click image for larger version
  #284
Old 09-02-2012, 11:53 PM
Along with the felt for the window guides, Legendary also included two other felt pieces with the new door panels, (photo 1). I didn't notice where these went when I had the driver's door apart, but when I pulled the passenger door apart, I noticed the forward vertical window track had a felt piece on it, so it was different than the drivers door. Then I remembered my original passenger door was full of bondo, and I had replaced it with a 71 door when the car was in the body shop. Photo's 2 and 3 , show the differences between the 70 channel (no felt) and the 71 (with felt). I don't know if this has been documented on the 1970 specific parts thread. If not, we might have another addition to the list. Also, my car is a Norwood car, and the 71 door I installed was from a Van Nuys car, in case that matters.
ID:	296296   Click image for larger version
ID:	296297   Click image for larger version
  #285
Old 09-03-2012, 04:53 PM
I installed the passenger side roof rail weatherstrip and adjusted the door glass, then installed the door panel. I had painted the armrests with the same paint (light sandlewood/tan) I had been using on the rest of the interior trim, but I was unhappy with how it looked on the armrests. The interior fabric is not a flat tan, it is "mottled" (I don't know if that is the correct spelling). Anyway, when I painted the armrests they looked too light. My interior guy said it's because sandlewood is actually two colors, and he knew a vinyl repair guy who could match it, so I had him do the armrests. It's still not exact, but it's much better than it was.
ID:	296430   Click image for larger version
  #286
Old 09-04-2012, 10:04 AM
OVERULD's Avatar
OVERULD OVERULD is offline
Man, those sandlewood interiors look awesome but everyone I see appears to be different shades/combos. I think yours looks good.
BJ
  #287
Old 09-05-2012, 09:39 PM
Default Interior
I am about 99% done with the car. I have an appointment Friday morning to have the front end aligned, then I start hanging some miles on it.
ID:	296676   Click image for larger version
ID:	296677   Click image for larger version
ID:	296678   Click image for larger version
ID:	296679   Click image for larger version
  #288
Old 09-05-2012, 09:41 PM
More interior pictures.
ID:	296681   Click image for larger version
ID:	296682   Click image for larger version
ID:	296683   Click image for larger version
  #289
Old 09-05-2012, 09:45 PM
Here are some exterior shots to show the ride height. The fuel tank is 3/4 full in these pictures. I still need to have the spare tire mounted on the rim, which will add a little weight, but this is probably how it will sit. A tad high for my liking, but it will have to do.
ID:	296686   Click image for larger version
ID:	296687   Click image for larger version
ID:	296688   Click image for larger version
ID:	296690   Click image for larger version
  #290
Old 09-05-2012, 10:06 PM
damannhw's Avatar
damannhw damannhw is offline
Chris, I've been watching the thread for awhile now, and let me say you're car looks incredible ! The detail is amazing, I would reallylove to see it in person. Now enjoy the drive time
'70 Formula 400
'64 Tempest
David
  #291
Old 09-05-2012, 10:46 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
congratulations Chris, the car looks incredible! Ride height looks great to me as it sits. You should be very proud!
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #292
Old 09-05-2012, 11:15 PM
tabob tabob is offline
Bravo! That is one realy nice formula!
72 TA 4 speed
76 TA auto father/son project
  #293
Old 09-06-2012, 01:14 PM
RAFormulas's Avatar
RAFormulas RAFormulas is offline
Looks great Chris! Congrats!
Steve
1970 Formula 400 (YS) M40 (67-Castillian Bronze / 215-Deluxe Medium Saddle)
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD*
  #294
Old 09-06-2012, 10:19 PM
Best sandalwood interior I have ever seen, hands down!
Awesome work, Chris.
  #295
Old 09-09-2012, 12:36 PM
72Formula's Avatar
72Formula 72Formula is offline
Torqula has to go in my "Really, really like" columm.
Drive her with pride, Chris!
  #296
Old 09-09-2012, 06:26 PM
LeighP's Avatar
LeighP LeighP is offline
beautiful.....the colour combo is stunning.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #297
Old 09-13-2012, 04:20 PM
Matt T Matt T is offline
Just read the last few pages with all the interior work. You know I never knew how the 70 shoulder belts were supposed to be stored. At first I let them hang straight down until I learned (painfully) that they could get caught in the door jambs. After that I always just tucked the belt behind the hook and stuck the end above the sun visor--there was no trace of any elastic on the belt when I bought it in 1988.
Now the fun question: Since you are about done, would you care to share what this "not full resto" has cost? Mine definitely needs more bodywork, but I always planned to do it myself. My interior is mostly done (console carpet seats and headliner) from 1990, although the dash could use repair, and the formula wheel and door panels need help. I like to see numbers because I get discouraged when I see magazine "budget" cars where the budget is $30k. I think I could approach mid teens, but maybe I'm completely unrealistic.
If you are one of those who don't keep track (for sanity sake) or want to keep it private, I understand.
Matt T
Pawtucket RI
Waiting restoration:
1970 Formula 400 owned since I was 16, still runs (I think)
1971 Camaro (in pieces)
  #298
Old 09-15-2012, 10:13 AM
Thanks to all for the compliments, they are appreciated. I've been driving the car around for about a week now and it runs pretty good. I keep reaching for fifth gear, but then remember I didn't go with the five speed. When I add the posi I will probably change the rear gear ratio to a 3.31, or maybe even a 3.07. The 3.55's are too low for this engine.
It sure is nice having all the pieces on the car, I can actually walk through my garage now.
  #299
Old 09-15-2012, 10:36 AM
Default Cost
Matt,
My receipts total $24,253.42. That includes the purchase price of the car ($2800.00) and the cost to title it in my name ($300.00). However, the receipt total is not an exact representation of the true cost of the build for a number of reasons:
1. Some of the items I used in the build were parts I had (In stock). For example, the air cleaner, carb, distributor, seat belts and some other small items were parts I had, and therefore did not have to pay for.
2. I have a real good friend who is also in the hobby. We swap parts all the time and never pay each other. The rebuilt alternator and some other stuff came from him. Sometimes I swapped items that came with the car and sometimes I swapped stuff I already had, so there is no way to put a value on what it cost me.
3. Horse trading, it's part of our hobby. Sometimes I would buy some parts, use some on the build and sell the unneeded ones, thereby getting my original investment back and make the parts I used "free" to me.
I did not include the cost of any tools I had to buy, but I did include the cost of sandblast material and things that I had to buy specifically for this build.
In some areas I spent well and got a lot of value for my money, (I only paid $4000.00 for the body and paint work, and this includes stripping the car to bare metal.) That is a hell of a deal, at least where I live. In contrast, other areas wound up costing way too much, (the exhaust for example).
Regardless, I think the figure of $24,253.42 is pretty close. Some people on this board might think that is way too high, while others who have done very high quality restorations will laugh and say, "Is that all?" Personally, I think the number is too high, I never set out to do a "restoration" and I still refuse to refer to the car as being restored. NJSteve's Trans Am and Keepat's cars were restored, mine has just been "fixed up."
As a side note to anyone who would use my cost as reference in deciding whether or not to buy a builder as opposed to buying a done car, please consider that the car I started with was very solid. I did not need to replace any floors, quarter panels, the tail panel, etc... The window frames were pristine as well. If any of these areas would have needed attention, the cost would have gone up considerably.
Regards,
Chris
Old 09-15-2012, 10:42 AM
165th's Avatar
165th 165th is offline
Wow, driving a completed restoration... and room in the garage..... What a great feeling that must be.
As many have said, that is one awesome car and color combo. Congratulations!
