This may be the only picture I took.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
So how do you get the rod to the pump after the pan is installed?
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
been there done that. no fun...
If you've got LOTS of time someday, I'll try to explain how the center carb's power valve is also now externally adjustable on that engine- with the air cleaners in-place! Not to mention the remote idle-mixture knobs of the center carb...
Im a dealer for Titan and can get you a little better price than buying direct.have too have it drop shipped or shipping back and forth to Alaska would eat that up.
Marty |
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
That was my son's post above, but I can tell you that the pan needs more room at the rear. We did it with a BFH and had a hard time with the pan sealing to the rail. I think that you can now get pans specifically made for a Titan pump, so I'd ask Titan if you are thinking about ordering thier pump.
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. [email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
For the price of a Titan why not run an external belt drive pump? Makes it really easy to prime the engine and gets rid of the cam twisting caused by running the oil pump off the back of the cam.
The Titan pro billet pump is a really good oil pump toriington bearings on the inner drive gear. we've been using the same one since the 90' before they even made onefor a pontiac, with no wear. it's really just a ford one with a different adapter.
Yeah, when you stretch the back of the pan with your BFH it pulls the front toward it and you have to double up on timing cover piece. Marty |
Has Mark Luhn come out with his geroter Pontiac pump yet. Have to get my ducks in a row for the engine I am building.
