Old 12-29-2012, 03:08 PM
gata79 gata79 is offline
Default Frustrated. Any ideas?
More problems. 535 IA II WP HP Heads. We got the engine rebuilt and in the car. It cranked but would not run. Get a nice vroom and it cuts off. Adjusted the timing but still wouldn't run.Thought it may be the carb,A 1050 I rebuilt. Changed to a 1250 rebuilt by a reputable local company,no difference. Checked compression on all cylinders,they were good. Traced all the wiring down didn't find anything. Put an HEI in it and bypassed the electronics, no change. Cam was degreed. It doesn't backfire or anything. It sounds like it's going to run but it loses rpm and shuts down. Any ideas?
Old 12-29-2012, 03:18 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Fuel pressure, volume? Sounds like it cuts off when bowls run dry. Did you check the pump, pick up and lines?
Old 12-29-2012, 03:22 PM
GTO Dan's Avatar
Also check the wiring to see if you are getting consistent voltage to the ignition.
Old 12-29-2012, 03:25 PM
slowbird's Avatar
slowbird slowbird is offline
After engine shuts off is there fuel in the carb? As its dying if you pump the throttle does anything happen?
Old 12-29-2012, 03:31 PM
sounds like dizzy is 180 out. how about that?
Old 12-29-2012, 03:47 PM
SupergasDil's Avatar
Sounds like you are losing power when you let off of the key in the start position. Possibly a bad coil ?
Old 12-29-2012, 04:01 PM
dammen8's Avatar
dammen8 dammen8 is offline
That was what I would guess... Or maybe rf noise from somewhere knocking out the ignition right after first fire...
3500lb 10.5" tire. [email protected] with a poor 60'
Old 12-29-2012, 04:06 PM
fsted fsted is offline
vacuum leak.
Old 12-29-2012, 04:15 PM
Good fuel pressure, doesn't run long enough for the bowls to run dry. I tried another coil but nothing changed. then tried bypassing the coil and other electronics with the HEI(powered from battery),no key it's a frame car but still should have constant power the way we did the HEI. If we pump the carb it will run a little longer,but still dies. It would backfire if 180 out wouldn't it? It sounds good for the short time it runs.
Old 12-29-2012, 04:19 PM
does it sound retarded ?
sound advanced?
old fuel?
water in fuel?
HYD lifters needing pumped?
Old 12-29-2012, 04:26 PM
I feel retarded with all the trouble I've had with this engine. Fuel system cleaned,new fuel,solid lifters. Hard to tell but maybe retarded.
Old 12-29-2012, 04:38 PM
Has it ran long enough to set timing?
Advance the distributor a couple degrees and see what it does.
What's the valves lashed at?
Possibly too tight?
When it starts, try running it at a fast idle or more?
Gasoline I take it?
Probably something small, really.
Old 12-29-2012, 04:52 PM
Gasoline. Hasn't run long enough to set timing,but we did the usual TDC number one then move in small increments till it cranks. I think the lash was .024
Old 12-29-2012, 05:58 PM
63 tempest's Avatar
63 tempest 63 tempest is offline
Check your voltage on your battery low voltage will not give enough spark to your ignition or msd. Sometimes bad cells on battery and not enough voltage to run your ignition on your msd box
Old 12-29-2012, 06:30 PM
Sorry I forgot. We did that too, and got a new battery.
Old 12-29-2012, 06:38 PM
Hooter's Avatar
Hooter Hooter is offline
Sure it's not 180 out?
67 Bonneville ragtop
Old 12-29-2012, 06:44 PM
That would be my guess...
Old 12-29-2012, 06:45 PM
At this point I'm not 100 percent sure of anything, but won't it pop and backfire if it's 180 out?
Old 12-29-2012, 07:52 PM
BEFORE you second- guess the cam timing chain installation,
set the card idle screw to a high idle. THEN TRY a 2-person effort to keep it running with pedal effort, and even starting fluid shots, and quick dizzy twist to attain "running".
Basically anything it takes to achieve warm-up, with constant monitoring of OIL PRESSURE, and thermal gauge(s).
Guessing: rehone or more causing rings to need re-seated?
Old 12-29-2012, 08:09 PM
No...it can act much like it is now.
