Old 12-31-2012, 11:30 AM
JohnJudge's Avatar
JohnJudge JohnJudge is offline
Default Special Order axle
Got a question.... I have an unusual 1970 Ram Air III, bench seat 4 speed GTO. It has a code 361 HD safe-t-track rear on the build sheet. Also has code 362 for special order axle. The rear in the car is the only thing non-original... how could I tell gear ratio from the factory? I am guessing either 3.90 or 4.33??
1969 GTO hardtop(warwick blue)
1969 GTO Judge Ram Air III
1970 GTO Ram Air III
1972 GTO 455(Feb.2006 HPP shootout)
1971 Trans Am (Super Stock)
2006 GTO ( Cyclone Grey)
1973 Firebird Formula
1979 Trans Am 4 speed
1967 Olds 442- Pinks All Out -Zmax 2010
Old 12-31-2012, 11:58 AM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Build sheet or PHS invoicing?
Old 12-31-2012, 12:02 PM
JohnJudge's Avatar
I have both.... Unfortunately, the build sheet is rough and missing that part
Old 12-31-2012, 12:08 PM
I want to say, 3.90:1.
Old 12-31-2012, 12:45 PM
bigborehunter bigborehunter is offline
If you believe the u joint shaft is original, careful cleaning of it may reveal stripe daub codes. These usually contain the gear ratio as well. Have to be careful what you use to clean the u joint shaft though. Someone will chime in here with suggestions.
Old 12-31-2012, 01:16 PM
JohnJudge's Avatar
Thanks for the info!
Old 12-31-2012, 02:03 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
What was the transmission code? If it was a wide ratio M20 that would rule out 4.33 gears. Pretty sure you needed the M21 for those.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 12-31-2012, 02:30 PM
factory speedo adapter present?
Old 12-31-2012, 02:38 PM
JohnJudge's Avatar
It is a M21 on the original build sheet
Old 12-31-2012, 04:10 PM
3.90 or 4.33 - both got the M21
3.55 was standard gear, and the break point for M20
Only the Buildsheet will tell which was ordered.
Same charge on invoice for either set.
Automatics were the only ones that got speedo adapters - and the Invoice would show a charge for the adapter.
From examples, about 90-95% of D-Port cars with Spec Axle have been 3.90
But 4.33's were just as available , just not as often chosen.
HD Radiator was requisite either way.
Which plant was it built at ?
I'll try to post a similar plant sheet that is easy to read and maybe it "might" could help make a better observation of your sheet.
Old 12-31-2012, 04:30 PM
JohnJudge's Avatar
BVZ, it was built at the Baltimore plant. Yes, it does have HD radiator too.
Thanks for your help!
Old 12-31-2012, 08:05 PM
muscle_collector's Avatar
why did the auto only get them??
Old 12-31-2012, 08:26 PM
Think it was due to more limited combos with their speedo gear sets.
All Auto D-Port with Spec Axle, and Auto IV (3.90 gear std) with or without Spec Axle , that i have invoices on - all show the adapter.
None of the Manual cars i have invoices on show an adapter with D-Port Spec Axle , or IV.
idunno what they did about that issue on 68 RA Auto cars.
maybe the adapter was issued - but at no-cost (?)
Old 12-31-2012, 08:28 PM
John, i'll post back in a while with one or more Bsheets from 70 Baltimore.
Old 12-31-2012, 08:49 PM
I think it had to do with the size of the drive gear fitting in the tailshaft.
Old 01-01-2013, 01:18 AM
Here's a Ram3 4spd 3.90
Ram4 Auto 3.90
Ram4 4spd 3.90
All are 70 Baltimore
Marked pertinents with Lime Green
3.90 code is X K
4.33 code is X M
Hope you have enough left in one of the areas to work with.
Holding up to a lamp with good reading glasses or magnifier can help too.
Name:	70 Judge Ram3 Blue-White Baltimore.jpg
ID:	307859   Click image for larger version
Name:	70 Judge IV Auto White Balti 2.jpg
ID:	307860   Click image for larger version
Name:	70 IV Judge Wht-Green 4spd Balti.jpg
Old 01-01-2013, 12:12 PM
Believe HFR is correct. Need to examine drive gears from never been messed with original Muncies in front of 3.90 & 4.33 of '69 or 70 G70-14 equipped GTO's.
Believe we will find the drive gear in 4.33 car is a 6 tooth. Its been over 15 years since went down this road, but that is what I ran across. An original 3.90 equipped car ought to be a little easier to find to confirm tooth count. 7 tooth, 8 tooth?
