Old 01-03-2013, 05:38 PM
Daniel Barton Daniel Barton is offline
Originally Posted by Daniel Barton View Post
Okay, as you can see you stated the real level of work done to their heads, so that means that you need to remove the price of porting the intake which is 2500.00, remove the cost of the Jesel rockers which is 1595.99, remove the cost of the Isky EZX .904 lifters which is 1220.00, remove the titanium valves which is 2003.52 and of course remove the cost of the triple valve springs, titanium retainers, keepers, spring locators and valve seals as they are not "work", also there is an option on the quote to remove the old seats, make new copper seats, install them and do a competion valve job, which by the way neither Jeff nor Jack have is an additional 1225.00 but would require you to remove the cost of the first valve job. Hope this helps clarify.
Please feel free to point out where Gaby stated that it would cost 12000.00 in work, because that is what you said, you stated the level of work. The only thing that is in fact a fact, is that your fact is not true! I have the quote...
Life is hard, it's even harder if your stupid- John Wayne
