Old 02-13-2013, 02:05 PM
Tom Hawkins Tom Hawkins is offline
Default Wanted: Aluminum rear brake drums for a 1965 GTO
Wanted: Aluminum rear brake drums (with steel insert) for a 1965 GTO. 9.50" inner drum diameter, 2.00" brake shoe width and a 4.75" lug diameter pattern. Please contact Tom at (334) 380-6760.
Old 02-13-2013, 03:38 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Who makes such a "rear" aluminum brake drum for the 65 GTO?
Old 02-13-2013, 03:41 PM
General Motors
Old 02-13-2013, 03:46 PM
Tinindianworkshop's Avatar
Tinindianworkshop Tinindianworkshop is offline
Default drum
GUY ON PY HAS SET FOR SALE WITH BACKING PLATES $100 JUST COUPLE DAYS AGO
Old 02-13-2013, 03:50 PM
Thanks, I'll look for them.
Old 02-13-2013, 08:03 PM
60sstuff's Avatar
Originally Posted by Tom Hawkins View Post
General Motors
Ok, so they must be GM after market or from another A body size car that would fit a 65 GTO rear? THX.
Old 02-13-2013, 08:19 PM
geeteeohguy's Avatar
Mid 1980's Buick and Olds G-bodies (RWD Cutlass and Regal) used the aluminum drums on the rears. I used to see them at junkyards fairly regularly. The price was minimal, like $5. They are still out there, and still cheap. Not the right part number, but hey.....
Jeff
Old 02-14-2013, 10:53 AM
I'm concerned with functionality, not the correct part number. Thanks Geeteeohguy, I'll look in the local scrap yards. Nice car, by the way.
Old 02-14-2013, 10:54 AM
Were these aluminum? I haven't found the thread.
Old 02-15-2013, 02:23 PM
AZgoatguy AZgoatguy is offline
Geeteeoguy is right in that aluminum drums were found on the 80's rwd Cutlass and Regal. These drums must have been an option because most of the cars came with the standard steel drums. The only ones I found were from the early to mid 80's and they have the metric bolt holes, not the earlier smaller sae holes. My 1981 Cutlass was sae and my 1985 Cutlass was metric on the lugs. They are 4 3/4 and the hub thickness is a good 1/4 inch, and the neat thing is that they are finned just like our GTO rear steel drums are. The part number is cast inside the drum and is 1255496 and the 'do not exceed' measurement is in metric.
Old 02-15-2013, 03:22 PM
AZgoatguy,
Thanks for the info. Do you know where I can find a set?
Thanks,
Tom
Old 02-15-2013, 05:35 PM
Ken K Ken K is offline
Good luck finding a set in a wrecking yard now. Everyone knew about those aluminum drums 15 years ago, you could find them then. If you find a set, you can use a rat tail file to enlarge the hole so it fits on the older rear ends.
Old 02-16-2013, 12:50 AM
Hey Tom,
I think I have an extra pair buried somewhere. Will dig them out and check them over tomorrow and get back with you.
Gary in Tucson
Old 02-16-2013, 01:42 AM
FrankieT/A's Avatar
Last set of aluminum drums I took off came off a mid '80's Chevy Caprice. That was about 2 yrs ago. The rest of the ones I have I took off 71 and 72 cutlasses. I acquired those in the late seventies. The ones off the caprice the center hole was a little tight. The older ones slipped right on. My cars are F bodies.
Old 02-16-2013, 12:42 PM
I have a spare set, $100 plus shipping. PM me if interested and I will send some pic's
They could also be found on FWD Riviara's and Eldorado's of the same era.
Old 02-16-2013, 10:18 PM
Hi Tom,
I did find the extra pair that were buried in my shop. Will send you a PM with a description and photos.
Gary in Tucson
