Old 02-26-2013, 10:39 AM
97ramsst's Avatar
97ramsst 97ramsst is offline
Default Value of 69 Judge Ram Air III/4spd - NOM - PHS Docmented
We picked up a 69 Judge a few months ago (yes its real...we have the PHS.) Its a carousel red, black int, RAIII, 4spd, with the HD rear end and with a hood tach...non AC car. Its in decent shape but needs restoring...it has minor rust in the usual places...front fenders and hood. The engine is not the original block (I believe it is the correct code but not VIN matching) but the heads, intake and carb are all correct. The car will crank and drive in the yard but it has been sitting for 23 years so I wouldnt even attempt to drive it on the road.
I am considering selling the car as is vs restoring it...we already have a 65 Tri-power, a 69 Ram Air IV GTO we just finished and are in the middle of a Ram Air III we need to finish and a anther 65 in paint as we speak, so this one just really isnt a big priority I dont guess. My question is to the right person, what ball park is this car worth as it sits if we descide to sell it? All the ones I have seen sell have been restored.
Old 02-26-2013, 10:56 AM
tom s tom s is online now
FYI,I paid 16.5 I believe a couple years ago for a car in much the same condition but the hood was not buckled.The only drive train parts not as born with was the block and starter.Correct carb,dist numbers matching trans etc.The car is gold so im sure the orange would bring more.Hope that help some.Tom
Old 02-26-2013, 12:20 PM
GTOnly70's Avatar
GTOnly70 GTOnly70 is offline
Looks like a worthy project. Are the hideaways original or were they added later (pretty rare to see them on a Judge)? I'd ballpark it at upper teens, maybe $20k.
Old 02-26-2013, 12:29 PM
97ramsst's Avatar
The hideaways are original.
Old 02-26-2013, 01:48 PM
SOM Firehawk 02 SOM Firehawk 02 is offline
Default PHS Documents
Robbie,
Per your request, here is the PHS Documentation showing that the car is a real Judge, 4 speed, Carousel Red, Black Interior, Hide away lights, 3:55 H.D. Safe-T-track Rear end.
Here is the link to the PHS documents: http://imgur.com/AYoY4JR
the build sheet lists the following.
4 speed trans
Radio - P/B
Belts-Deluxe
Console
Pwr Strg With Tilt
Glass-??/R-AL
Saf-T-TR-HD
Mirror-remot
Tack-Hood-HT
Rally Gauges
Disc BRK PWR
The Judge ($337.02) What a deal!!!
G70x14 RL FG
Thanks,
Ken
Old 02-26-2013, 04:54 PM
69 DAYTONA's Avatar
69 DAYTONA 69 DAYTONA is offline
...my guess, $15-18K
Old 02-26-2013, 05:26 PM
dxeven's Avatar
dxeven dxeven is offline
A couple of items on PHS: Hideaways aren't on PHS. Lamps-CRNG is for Cornering Lamps, which aren't present on car in the pics. Power Strg - W/T doesnt include Tilt, W/T stands for Wide Track, I believe. Tilt was a separate option.
I do like how this car is optioned. Too bad original block is gone. I would say it's worth
$16-18k.
Also just noticed it picked up a wood steering wheel along the way that isn't on PHS.
Old 02-26-2013, 05:38 PM
1969 Ram Air 1969 Ram Air is offline
Cornering lamps are kind of odd on a Judge anyway, with the Judge sticker and the lamps in the same area. Mid to high teens is my guess on the value.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 02-26-2013, 10:37 PM
Other than the cornering lamps and the RedLine tires its optioned almost like the early Pattern Cars.
The fenders have been changed and the cornering lamps deleted.
Most don't want them anyway on a Judge.
Hide-Aways are usually always a welcome addition.
Power Steering Wonder Touch
Glass Soft-Ray ALL
Tach Hood Mount
Unknowns that would need to be known to give better value estimate :
is Ram Air Induction complete from the functional hood scoops to the lower carb pan - and still functional. (about 1k variable)
code and date from block (1-2k variable)
all stamped data on carb (2-3k variable)
codes and dates from heads, intake, distributor (more $ variables)
body build date on cowl tag
4spd VIN verified
3.55 posi verified as still intact (500-1000 variable)
condition of trunk lid (500-1000 variable)
condition of dash pad
all these things separate the 15k cars from the 20k and 25k NOM cars.
Old 02-26-2013, 10:43 PM
Wouldn't hurt to check/post all the date/code stampings from around the valve stems of the Rims. Looks like they might could still be the originals.
Everything like that can help the value.
Old 02-27-2013, 12:10 PM
flyingn's Avatar
flyingn flyingn is offline
looks to me the car hit something and the whole front end was replaced(removing the corning lights and adding hide aways) because it looks to me that the front end paint faded at a different rate then the rest of the car
Old 02-27-2013, 12:30 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
To me it looks like the fenders and quarters both match up with similar patina. The passenger door looks brighter than the rest if anything. Might be the lighting or angle of photo. The stripes look the same and line up., I'd say it's all original.
Looks like a great Judge project! As far as value, I would say $15-17 as it sits now. Running and road worthy, probably add $2K to my estimate.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 02-27-2013, 01:38 PM
Judge273's Avatar
Judge273 Judge273 is offline
Looking at the body and the sheetmetal in particular. If it is as solid as it looks that is a big bonus to the value. Having matching trans and factory rear too a bonus. Interior looks to be original and dash not cracked.
Nicely optioned CR 4 speed Judge still very desirable has to be 18-20K car as I see it...
MSU car too!
Mike/Illinois
Old 02-27-2013, 02:29 PM
flyingn's Avatar
Then how do you explain the missing factory corning lights?
Old 02-27-2013, 05:38 PM
pacekar pacekar is offline
if i didnt have one i would be making a deal with you. i like it
Old 02-27-2013, 10:09 PM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Glass Soft-Ray ALL
Tach Hood Mount
4spd VIN verified
Concur with BVZ - neat car, but still lots of questions to answer on what original equipment it still has. As for the body, how are the quarters, wheel houses, trunk pan, floors, etc, is the frame tweaked/bent (i.e., how bad was it hit in the front), what does it look like under the hood, etc. Somewhere around $15k is a good starting point, IMO.
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 02-27-2013, 11:50 PM
GTO JOHN's Avatar
you might be right then. after all im no expert.
John
Old 02-28-2013, 09:48 AM
The Boss's Avatar
The Boss The Boss is offline
We ask these questions all the time and what we should really be asking is "What would you pay for it?"
And go racin' in the street.
Old 02-28-2013, 10:38 AM
hobi hobi is offline
Default VALUE
The problem is its to late its not 1987 anymore people if you really wanted to know value on these cars you would have asked HURSTCOLLECTOR before he passed away. They are worth what someone wants to pay end of story quite asking the same old question
Old 02-28-2013, 11:49 AM
bulletpruf's Avatar
Who is/was HURSTCOLLECTOR?
