Old 04-01-2013, 12:05 PM
1966geeto 1966geeto is offline
Default Poor mans frame off resto..
So the pieces are starting to come together I finally got one of the last pieces finished and it came out great for a back yard job blasted with HF 100lb unit ground and sanded until my arms fell off epoxy primer last night 3 coats chassis paint this morning hope to roll it under car Tues and get going on reassembling.Under body blasted and epoxy finished with 2 coats zerorust and top coat satin chassis black all new body mounts and correct bolts. Rear end went from a 2.93 posi to a 3.26 gear complete o/h longer wheel studs installed for disc conversion.Hope to make some noise soon just to get the adrenaline pumping again my father son project turned into just dad allot of work for this ol man yeah he bought a Mopar so he's on his own haha anyway just an update..thanks to all who chimed in not done yet.
Name:	resto paint 001 (Small).JPG
Name:	resto paint 002 (Small).JPG
Name:	resto paint 011 (Small).JPG
Name:	resto paint 004 (Small).JPG
Name:	resto paint 012 (Small).JPG
Old 04-01-2013, 01:01 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Looks great
I am the Thread Killer!
Old 04-01-2013, 01:13 PM
webfoot's Avatar
webfoot webfoot is offline
Nice job. Every frame off resto should be called "poor man's", because they all MAKE you poor.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 04-01-2013, 06:51 PM
68GTOSCA 68GTOSCA is offline
Default No Cheap Restorations
2X
That the truth - no such thing as cheap restoration. Between the parts, tools, air compressor, paint guns and my manhours, I should of built an other house. At least I would rent the house.
Sean
Old 04-01-2013, 07:37 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Looks great! Keep posting progress.
Leo
Old 04-04-2013, 10:32 AM
Judas Judas is offline
Amen to that!
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward."
Old 04-04-2013, 03:16 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
I like the idea of holding the frame in the air with engine hoist.
Old 04-04-2013, 03:30 PM
geeteeohguy's Avatar
I like that too. It's a new one on me, and it makes sense. Lots of great ideas on this forum!
Jeff
Old 04-04-2013, 07:22 PM
Another set back never paid attention to the rear springs went to install them and discovered they were out of a 67 bwahahah WTF so off to PY to order springs going to use the vert 66 springs to raise the rear just a bit anyone need a freshly painted set of 67 springs...The eng hoist has served a multitdue of uses lifted the body up with it to set it on 4x4s..
Old 04-05-2013, 09:39 AM
gto406 gto406 is offline
Love it, the low-buck way represents the 'true shade-tree' aspect of this hobby!
I too used an engine hoist (2 of them in fact) to lift my body off the frame. When you don't have a hoist, this is a very safe way to go (assuming you use good attachment points (e.g. cowl, and rear bumper mounting points) and block it correctly.
Keep up the great work!
Old 04-05-2013, 11:35 AM
webfoot's Avatar
I also used an engine hoist to lift the body off my ragtop. I used the seatbelt holes to attach the chains and used cinder blocks as ballast to level it out.
-Jeremy
Old 04-05-2013, 12:40 PM
2002Z4CSS's Avatar
Looking great. All of the prep work paid off.
1971 Pontiac GT-37
Old 04-05-2013, 08:05 PM
I also used cement blocks and 50lb dead weights to balance car ass heavy lol...
Old 05-03-2013, 05:06 PM
Default Some progress
Getting down to the bits and pieces good progress last week..
Name:	brake pic 001 (Small).JPG
Name:	brake pic 007 (Small).JPG
Name:	brake pic 002 (Small).JPG
Name:	brake pic 003 (Small).JPG
Name:	brake pic 004 (Small).JPG
Would have the frame back down but brake lines holding me up
Old 05-03-2013, 05:38 PM
Txbobcat Txbobcat is offline
You got it looking pretty sharp
Old 05-04-2013, 10:12 PM
Birdguy's Avatar
Birdguy Birdguy is offline
I had to get a little creative myself. All I had to do was drive the trailer under it to get it to the sandblaster. As we've all discovered, you figure out how to get it done with what you have.
Old 05-05-2013, 09:00 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Nice work and doing it in house. The engine crane being used to hold the frame is a great idea.
Old 05-05-2013, 03:36 PM
Default More bits and pieces..
One man band gotta get creative some more bits and pieces decide to re-shoot the interior and pieces did not like the way it came back from the body shop also Amazon hose in Tampa Fla solved my brake problem..Hope to drop drive train in Tues forgot to paint drive shaft..Thanks for all the positive comments.
.Click image for larger version
Name:	new int paint 011 (Small).JPG
Name:	new int paint 002 (Small).JPG
Name:	new int paint 005 (Small).JPG
Name:	new int paint 010 (Small).JPG
Name:	new int paint 006 (Small).JPG
Old 06-06-2013, 03:52 PM
Default 4 hours later
Name:	eng pics 011 (Small).JPG
Name:	eng pics 007 (Small).JPG
Name:	eng pics 017 (Small).JPG
Name:	eng pics 023 (Small).JPG
Name:	eng pics 025 (Small).JPG
Some progress today dr header was a bitch by myself nothing to attatch the starter cable protector to guess I will fab one up.What do you guys think about brake line really close to header do you think it will boil the fluid.Getting there baby steps..
Old 06-06-2013, 03:56 PM
2002Z4CSS's Avatar
Looking good!
1971 Pontiac GT-37
