Old 03-07-2013, 06:08 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Originally Posted by Bentwheelbob View Post
BJ,
Inline Tube is now selling the 4" studded head bolt for $4.95 each. See the Ebay link below. Motorcity Musclecar is their Ebay store.
http://www.ebay.com/itm/1968-74-Pont...dee104&vxp=mtr
Regards,
Bob
Thanks Bob!
  #1422
Old 03-07-2013, 06:23 PM
OVERULD's Avatar
Quick question: If I remove the bolt currently in the head at that position to measure it and/or to replace it once the new one arrives, do I need to be concerned about a head gasket leak at that point later on or can I just remove it, replace and re-torque it without affecting the seal on the gasket? What is the torque value for that bolt by the way?
BJ
  #1423
Old 03-07-2013, 06:50 PM
Just take it out and replace.
Torque to 90 ft/lbs
  #1424
Old 03-23-2013, 03:46 PM
bird72's Avatar
bird72 bird72 is offline
HO exhaust manifolds.... arrrghhhhh...... after spending $140 having one repaired (pro welded) we found small cracks on the other one! I give up on old iron manifolds that have seen years of heat.... Buying some oversize RA Ent. new ones...... I cry uncle! Cool garage hangings they will be (the old ones)..... arghhhh.....
72 Bird
  #1425
Old 03-23-2013, 03:51 PM
bird72's Avatar
Also decided for my new done HO heads, to do the bottom end right.... was going to freshen up the low mile 4 bolt bottom end I have, as it is low miles, but decided to get some good rods to replace factory. Pro balance and do it right. Hopefully my forged pistons are fine for re-use, should be. Any rod recomendations?
72 Bird
  #1426
Old 03-23-2013, 04:23 PM
njsteve's Avatar
njsteve njsteve is offline
You can check out what I used for my engine:
http://forums.maxperformanceinc.com/...695444&page=32
When we balanced them, it turned out they were all within weight spec and needed no additional massaging for weight matching. Very nice set of rods.
  #1427
Old 03-23-2013, 10:11 PM
Formulabruce's Avatar
why rods? Stock rods are good for 6,000 and 450 hp..., ( the 1970 455 370 HP engine had over 10:1 CR as I recall.. STOCK Rods) put new rods and then old heavy pistons back on?
on a stock, to mild build stock rods are fine, and the >> cheap forged rods <<<< ( SCAT,CAT) always need more balancing and resizing.... Buy some lightweight pistons and spend money on balancing IM (HO) !
  #1428
Old 03-24-2013, 04:37 AM
bird72's Avatar
I have TRW forged now and they should be good, about 5K miles on them, well, see. This short block was balanced before and runs very nice with D port heads now.... rods though? Kinda a Just Cause deal, same as 4 bolt caps I fitted, studs would have been smarter and cheaper. Yes stock rods with good bolts are fine, what I have now... the HO heads I am putting on are off a 72 TA a guy has here locally, now he runs an aluminum set up non stock. The original HO engine he broke a rod, cracked the block, while flogging it so there is one TA that will never be number match again. And it was 450 HP ish build, so stock rod failure happens with full tilt use occasionally.
72 Bird
  #1429
Old 03-24-2013, 07:24 AM
njsteve's Avatar
I see the forged rods as insurance. And they were comparatively priced to having the old factory cast set completely redone and buying new rod bolts, too. Forty year old cast iron can have unseen stress flaws just waiting to find the most expensive part to take with it. (your matching # block). The rod set I got was perfeclty weight matched right out of the box. On my prior HO, i did reuse the forged pistons that the prior builder installed. It worked out fine, as they didnt need any further massaging for weight, since they were previously balanced.
  #1430
Old 04-05-2013, 05:45 PM
1972 HO Engine Complete
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
  #1431
Old 04-07-2013, 11:07 AM
bird72's Avatar
so anyone need a nice, blasted clean drivers side 72 HO exhaust manifold (no cracks)? It is useless to me since I am buying oversize new pair. I will keep the bad passenger one as a cool garage ornament.... if anyone could use I would trade for ? or go cheapo....
72 Bird
  #1432
Old 04-07-2013, 11:13 AM
PB's Avatar
PB PB is offline
I have a leak on my drivers side....dunno yet if its a crack or not...I'm interested ....how much you looking to get? Sent you a pm
Pat Brown
  #1433
Old 04-08-2013, 09:34 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
WOW!
I don't believe that I've EVER seen a 455HO engine for sale anywhere that is this complete!
Regards,
"455HO" Lloyd
  #1434
Old 04-12-2013, 03:26 AM
1972 FORMULA 455 HO , Original Orange/black roof...repaint. On the 'Bay
BUILD SHEET
LINK>>>>>>> http://cgi.ebay.com/ebaymotors/RARE-...orcev4exp=true
  #1435
Old 04-12-2013, 07:59 AM
Brewster's Avatar
Brewster Brewster is offline
Allot of options and cool color combo for sure. Like the video but no action? kept it mellow.
  #1436
Old 04-12-2013, 08:00 AM
The Boss's Avatar
The Boss The Boss is offline
Sundance is code 65 isn't it?
And go racin' in the street.
  #1437
Old 04-12-2013, 08:51 AM
1971455HO's Avatar
1971455HO 1971455HO is offline
I want it...but then, I want 'em all.
Eddie
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #1438
Old 04-12-2013, 09:24 AM
Lloyd-TX's Avatar
Thumbs up
Sunny O is indeed code 65 on the cowl tag, and "Z" on the invoice.
Nicely optioned '72 HO Formy! Tilt Formula wheel, gauges w/ tach, Y99, both consoles, KR Rallys, Safe-T-Track, and so on . . .
Just like what I'd have ordered, minus the cordova roof, add the factory spoiler and change to the "tuxedo" guts.
Looks like it's not TOO far gone to be salvageable . . .
Regards,
"455HO" Lloyd
  #1439
Old 04-12-2013, 10:52 AM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
cool car! love the options. note the ubiquitous D80/611 is NOT on the list...
  #1440
Old 04-12-2013, 10:54 AM
Lloyd-TX's Avatar
Yup . . .
Regards,
"455HO" Lloyd
