Old 05-21-2013, 02:07 PM
Firebob's Avatar
Firebob Firebob is offline
Default 69 Ebrake
Anybody got pics of both sides of a 69 E brake or maybe just the pull rod? I have 2 extra units but they must be 68s because there is no way you could bolt them in and the handle would clear the bottom of the dash on my 69.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 05-21-2013, 08:52 PM
trmjr1 trmjr1 is offline
I have a couple '69's on my workbench at home. I can get a pic for you Thursday if nobody else posts one before then.
Tom
1969 Firebird 400 Convertible
"We have got but one life here. It pays, no matter what comes after it, to try and do things, to accomplish things in this life and not merely to have a soft and pleasant time." - Theodore Roosevelt
"Light travels faster than sound. That is why some people appear to be bright until you hear them speak." - A father's words of wisdom to his children
Old 05-21-2013, 08:53 PM
Sport69 Sport69 is offline
Default E-Brake
Do these help? Hanging on the left.
ID:	323826   Click image for larger version
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 05-21-2013, 10:39 PM
Firebob's Avatar
Sport,
That first one does help. At least I can see what happened to mine. It seems mine was broken right where the pull rod connects to the unit. Everything behind(or forward) is gone. My handle has always just hung down and laid on the pedal because there was nothing to hold it up.
Tom, I could still use a little closer view of the pull rod if you can get one.
Robert
Old 05-23-2013, 11:29 AM
FASTASSBIRD FASTASSBIRD is offline
Bob, It could also be a Camaro version. They are different even in 69
Old 05-24-2013, 12:14 AM
Firebob's Avatar
I have two spare 68 version units. They are exactly the same as the one in my 9 except for the pull rod configuration.
Robert
Old 05-25-2013, 09:04 PM
Robert - see if these pics help.
Name:	DSCN0724 (800x600).jpg
ID:	324209   Click image for larger version
Name:	DSCN0725 (800x600).jpg
Old 05-27-2013, 01:07 PM
Firebob's Avatar
Thanks for the pics. It looks like it's just going to be easier for me to make a bracket to hold the front of the handle up than to try and remake the whole pull rod. It's really not worth buying a whole new unit to r&r just so the handle stays put. The easiest solution is usually the best right?
Robert
