Old 04-21-2010, 07:23 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
Default Wow
Here are a few pics of some wild force fed machines...
ID:	203969   Click image for larger version
Old 06-12-2010, 08:04 AM
7secjudge's Avatar
7secjudge 7secjudge is offline
Our GTO best et 7.80@175mph at 3350lbs 60' 1.17 on m/t et street tires with a light tune up of 20% over driven. no it's not poncho power it was a 540 bbc sorry chebby lol.
Ron
Old 06-12-2010, 10:14 AM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Here's one from "Po Boy Racing"! LOL Darn near stock bottom end real Pontiac 400 too!
Engine combo in Signiture W/ an ICE brand plate style kit. I bought the kit used for $100 3-5 years ago. IIRC The date on the bottle is maybe 1985? lol I'm still working out the jetting stagger, but it does work. Hoping to widdle the ET/MPH down to 10.99 by the end of Summer. Building a new stronger engine for next season may.may not use the nitrous on it. JD
***Add 100 shot to 3.70 setup:
Calc. DA 2028'
11.66 @116.33 1.71 60'
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 10-11-2010, 10:29 PM
BrandX's Avatar
BrandX BrandX is offline
535 ia 2
4.5 stroke all pontiac crank
6.8 eagle rods
ross pistons
out of the box 365 version high port heads
victor intake with a single steve johnson fogger
1150 holley
2 inch mad dog headers with magnaflow 3.5 inch mufflers
th400
4.29 gears
On a 38 jet with a 30 fuel and 5 lbs flowing with 12 degrees total timing the car went 5.35 at 132 so far. Crappy 1.29 60 foot. I am confident the car will run 5.2s with this tune up. The car is also 3525 lbs at race weight.
www.MidwestStreetCars.com
Butler Performance
Quillen Motorsports
Don Dial Race Cars
Old 10-11-2010, 10:50 PM
lemans411's Avatar
lemans411 lemans411 is offline
best pass so far . 9.89 @ 137 mph 1.41 60 ft. 4220 race weight
67 lemans 535 ia2 with a homebuilt 91mm turbo blow thru setup
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
Old 10-13-2010, 05:42 PM
4RSFEDGTO's Avatar
4RSFEDGTO 4RSFEDGTO is offline
1967 GTO .040 455 6x's mild hydraulic roller 3000 stall 3.73 gears. 3560lb with me in it. 12.14@115mph on the motor 11.45@125mph on a 150 shot.
Old 01-26-2011, 12:21 AM
misaac misaac is offline
64 Tempest wagon .060 455 96dports UD RAIV 112lsa 3.23 gears 4000lbs with driver 12.85@104 on motor, 11.32@119 on 180 shot
http://www.youtube.com/watch?v=XGf_pe66mOE
http://www.youtube.com/watch?v=obtS3SlbE6Y
Old 05-31-2011, 10:20 AM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
1967 GTO E head 467. 3000lbs best time old motor 9.33 @144 200shot spray only in 3rd gear.
New AllPontiac motor installation In Progress
Old 08-05-2011, 02:25 PM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
Originally Posted by flamedabone View Post
You guys have seen pics of this heap before, but whats one more???
I drive this car EVERY SINGLE DAY rain, snow or shine. Her 1/4 mile times come from a nostalgia race I drive to 1300 miles away in Joplin, Missouri.. She has more in her, but I am afraid of having to walk home..
11.30s@120+
See ya, -Abone.
Nice photo, Jeff....I was there for the 10.98 blast [and all the others] ...in summer heat. And he drives it from S. Carolina to Joplin..races it and drives home. No back-up truck, trailer...just a nice drive in the summer.
Roll around in the excitement
Old 04-24-2013, 11:45 AM
vin63's Avatar
vin63 vin63 is offline
2900 lbs, 8-71 on a 8% nitro mix. Slowest 60-foot ET of the weekend. (was in the 1.00s 60-foot the prior test passes that weekend).
1963 Tempest Convertible
Pontiac-Powered Funny Car:
400 block, Littlefield 8-71 blower, Enderle injection,
custom blower intake, three-disc glide clutch, three-speed Lenco
Old 06-18-2013, 08:06 PM
vin63's Avatar
Test and tune prior to the Saturday Night Nitro event at Famoso. No. 7 hole out the entire pass (checking into an intermittent points box issue)
Old 06-19-2013, 08:30 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Vin63, what does the car weight?
400 Pontiac block, cool!
Old 06-19-2013, 10:21 AM
vin63's Avatar
With the funny car body, it weighs around 3300 lbs with me in it.
Old 06-19-2013, 11:24 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Great job, Vince. It inspires me to keep at it with my Tempest. Too many irons in the fire!
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 12-26-2013, 03:07 PM
4RSFEDGTO's Avatar
Default Update!
Same car and engine with a Vortech YSi 10psi and TRZ suspension [email protected] with a 1.49 60'
Mike Bright
Special thanks to Mark Luhn at Luhn Performance for all the help
Old 12-26-2013, 08:38 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Post #30 says 2900#???
[email protected]. 3460#s
Old 12-27-2013, 11:57 AM
vin63's Avatar
Because this is how the car was configured at that Pontiac Heaven/Nostalgic Show-n-Go event…note that the car was run as an altered - no funny car body.
http://www.youtube.com/watch?v=8wUn82-L3Lo
The Following 2 Users Say Thank You to vin63 For This Useful Post:
  #38
Old 12-27-2013, 02:15 PM
King of the stock blocks IMO... until recently Vin was also running an N crank from a 400 too... with RPM over 8500 and Nitro. Truly impressive... Most calculators show power at these weights well in excess of Vins stated power numbers.
I applaud him for taking the path few would follow!
The Following 2 Users Say Thank You to BruceWilkie For This Useful Post:
  #39
Old 01-06-2014, 06:02 PM
cgeise's Avatar
cgeise cgeise is offline
Update - 6.60 at 215
  #40
Old 01-13-2014, 03:48 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
ET? Many ten-second full-pulls...
Yeah, it's only for 300 feet- but haulin' 14,000 pounds of transfer sled!
MPH? Too bad tire speed doesn't count for much- about 110 in this photo, 123 with the hemi.
