Old 06-21-2013, 02:54 PM
Don Keefe's Avatar
Don Keefe Don Keefe is offline
PY VIP
Default Small Bore = Big Power Cheap?
I have been thinking about this combo for a while and I think that there is a lot of power to be had cheap with a turbocharged 350 Pontiac. Here is my thought: the early blocks have a lot of cylinder wall thickness and the small bore will greatly reduced head gasket issues. They are also as cheap as landfill.
Forged pistons for these engines are now readily available and the valve shrouding issue shouldn't be a significant problem in a forced-induction situation. You could mess around with valve chamfers but I doubt you'd even need to.
I think a '72 350 with the 1.96/1.77 valve combo would be a great start. Add the aforementioned forged pistons with some cheapo forged rods, stock crank and an 067 or 068 cam you'd have a pretty stout foundation. Round it out with a Tomahawk intake, Holley carb and a set of Ram Air III exhaust manifolds and I think that you'd be well on your way to 600+ horses with the right turbo. I think a BW S475 would be a good choice, provided the exhaust turbine wasn't too big.
Has anyone tried anything like this?
Founding Editor-in-Chief, Poncho Perfection 10/1/15-12/31/24)
Contributing Editor: Collectible Automobile (1999- )
Author:
"Grand Prix: Pontiac's Luxury Performance Car" (4/27/07)
"How to Restore Your Pontiac GTO" (7/15/2012))
"Pontiac Concept and Show Cars, 1939-1980" (3/25/16)
"Pontiac Performance 1960-1974: The Era of the Super Duty, H.O., & Ram Air Drag & Muscle Cars” (10/15/24)
"Leave the gun, take the cannoli."
Old 06-21-2013, 05:01 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
I have not tried it but have thought of it many times... specially after looking at the 350 deck next to a 455 block. Massive amount of sealing surface along with very beefy casting everywhere.
Locating stock logs that you could flip forward like I did on my S15 would be a smart move.
600 horses on low boost setting...
Old 06-21-2013, 06:38 PM
69FIREBIRD76MM's Avatar
Default 350 under boost!
I think Jeff -aka-- 69turbobird---was running a 350 stock and got it to run 11. e/t ---1/4 mile, but i am not 100% sure, I am too lazy to look for his post--look for him and I am pretty sure you will find more info...he sells turbos, turbo headers and relate items...
Old 06-21-2013, 11:05 PM
I think you could get 700 hp out of it on pump gas if you intercool it and maybe add a water/meth kit... just be sure you got strong pistons/rods and maybe better main caps. (splayed 4 bolt)
Old 06-22-2013, 12:01 AM
70 bird's Avatar
70 bird 70 bird is offline
An s475 would work great. I have one on a 351w it starts to spool around 2200 and about 10psi at 4000.
Old 06-22-2013, 09:27 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Sounds like a very workable combo to me, but turbo and cheap don't really go together. LOL
Once a turbo spools you have huge torque so a 600 HP turbo engine is going to do a lot of work.
I think it was Firechicken that had a 068 cam and went mid 10's, but don't remember at what C.I.
Old 06-22-2013, 09:42 AM
ponjohn's Avatar
ponjohn ponjohn is offline
I'd prefer two smaller turbos so you have boost just off idle.
Old 06-23-2013, 09:33 AM
Donovan Donovan is offline
I thought the same thing but unfortunately the bolt pattern is asymmetrical. Needs to be fabbed.
Old 06-23-2013, 02:06 PM
RUDOLFSSON's Avatar
Sorry for the confusion..... Use a RH log on the left side and the LH on the right side... If you have a big pile of Pontiac logs and big chassis chances are that you might get lucky with some manifolds.
Old 06-23-2013, 05:49 PM
Some Pontiac exhaust manifolds are center and/or near center outlet. No big deal makin a u and going back up or if goin fwd meetin under the pan somewhere(ala single exhaust crossover or if twin turbo makin an x under the pan) If motor mounts werent in the way long branch manifolds could be swapped side to side(fwd facing vs rear facing) Ram air logs arent bad either.
Old 06-24-2013, 10:15 AM
rohrt rohrt is offline
subscribbing
Old 06-24-2013, 11:51 AM
johnta1 johnta1 is online now
Don, you could always go twin turbo and make some power.
Twin turbos
Old 06-24-2013, 10:54 PM
Would have been neat to see you use them John... Not a bad deal either. 1200+ in your dragster is serious fast... Sub 7's at 2000 lbs... Heck a 3200 lb door car could go bottom 8's with them.
Old 06-26-2013, 10:21 PM
Don Keefe's Avatar
PY VIP
I'm not so sure I would want boost down that low as the engine will be going in a mostly stock '66 A-body chassis. I would like to make sure the tires are firmly planted before the boost comes on. This will be a street car that will see a few trips to the track per year.
While it will certainly be easy to make more power with a larger bore engine, I am looking for a durable stock block combination that won't have an appetite for head gaskets, yet will have enough power to get a full-bodied car into the 10s. I think it is doable.
Author:
Old 06-27-2013, 12:53 AM
David Holmberg's Avatar
The problem is (other than getting it to the ground) going into boost kills your MPG. I know this isn't a high mpg build but...
You want it to start building boost just above your normal cruising rpm.
Old 06-27-2013, 07:27 AM
Don Keefe's Avatar
PY VIP
That is exactly what I was thinking of perhaps getting a converter that is just loose enough to build boost against while power braking at the starting line. Being in boost all of the time would also make for a very difficult car to manage on the street.
Author:
Old 10-09-2013, 10:51 PM
Alex_F Alex_F is offline
Took the first test drive tonight in my 1970 turbocharged 350 Lemans wagon. It is going to be fun!(once I finish installing body panels) Pulled really hard for a completely stock 350, buying up parts to build the replacement engine currently Forgive my horrible video editing skills.
http://www.youtube.com/watch?v=MXUd1TmB2Vk
Old 10-10-2013, 09:47 AM
RUDOLFSSON's Avatar
LOL.. all stripped down and hammering the country roads.... I like your style!!
Old 10-14-2013, 12:56 PM
Don Keefe's Avatar
PY VIP
Love it- please send more photos/videos!
Author:
Old 10-16-2013, 07:51 PM
Thanks! I won't have anymore videos until later this fall when I get paint and some body panels on it. I could not resist taking it out for one blast down the road . I will start my own thread when I get some better pictures and have time to write down more details of the build. Highlights of the build are cheap Chinese gt45 turbo, completely stock 350(for now), lots and lots of fabrication and using parts the way they were never intended!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
