Old 09-29-2013, 05:45 PM
dmorg1's Avatar
dmorg1 dmorg1 is offline
Default Which V8
I came across a 67 convertible for sale local to me. It's pretty rough and does not have the original engine or auto trans.
Other than the Build Sheet or a PHS package is there any way to determine which V8 engine this car originally came with?
I have the VIN and Trim Tag codes.
Thanks,
Dave
68 GTO
68 GTO Convertible
68 LeMans
68 LeMans Convertible
68 Tempest Convertible
79 Firebird
Old 09-29-2013, 06:15 PM
BILTIT's Avatar
BILTIT BILTIT is offline
First search i did in google found this.
http://www.transamworld.com/1genvins.php
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 09-29-2013, 06:36 PM
dmorg1's Avatar
Derek,
That was one of the many sites I had checked but from what I can see the VIN will only distinguish between 6 and 8 cyl. engines.
Dave
68 GTO
68 GTO Convertible
68 LeMans
79 Firebird
Old 09-29-2013, 06:50 PM
68tpls400 68tpls400 is offline
If "3f" is on the trim tag, then the car was a 400. Other than that and the code for i6, that's about it. If it is a v8 code and does not have the 3f, then it would be a 326. This only applies to '67 model year.
Old 09-29-2013, 07:20 PM
dmorg1's Avatar
Well no 3F on the tag. The tag looks like this.
139 05B
ST 67-22467 LOR 3139 BODY
TR 254-2 R-1 PAINT
W2W
From what I can gather,
Standard Parchment int.
Buckets w/o headrest
Reg. Red with Ivory top
Not sure what the W2W designates. Does anyone know?
Thanks,
Dave
68 GTO
68 GTO Convertible
68 LeMans
79 Firebird
Old 09-29-2013, 07:57 PM
wovenweb's Avatar
wovenweb wovenweb is offline
The W in the first group represents:
W = Tinted Glass Windshield
The 2 W is for the PowerGlide transmission. The 2 denotes that it is Group 2.
W = 2-Speed Automatic Tranny
If you scroll down to the bottom of this page you will see all the codes listed by group:
http://www.firebirdgallery.com/67codes.htm
Old 09-30-2013, 08:56 PM
dmorg1's Avatar
Thanks for all the info it's a great help.
Now I just need to decide if I really need another project car.
Dave
68 GTO
68 GTO Convertible
68 LeMans
79 Firebird
Old 09-30-2013, 10:25 PM
Squidward's Avatar
Thanks,
Dave
Sounds like someone already got rid of the 326/st300 for you, which I would say is a good thing.
Old 10-01-2013, 07:41 PM
dmorg1's Avatar
The original engine and trans not the only thing they got rid of. Most of the interior is gone, all of front sheet-metal is off but he has another front clip for it.
The engine in there now is a 69 350 with 47 heads (not sure if it will even turn) but it does have a nice thermoquad and interesting aluminum pontiac logo valve covers.
Dave
68 GTO
68 GTO Convertible
68 LeMans
79 Firebird
Old 10-02-2013, 03:11 PM
Squidward's Avatar
Funny! 69 350 with 47 heads is what currently resides in my 67.
Old 10-02-2013, 03:52 PM
sts sts is offline
>Sounds like someone already got rid of the 326/st300 for you, which I would say is a good thing.<
If I could add to it, the car needs a 400 or larger Pontiac replacment engine. Do it the right way. If it's not a numbers-match small-bore engine, the correct way to get the most resale value is 400 or larger engine.
