Old 08-21-2013, 12:21 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Hey Mark,,, Now that its aligned with the ports,,Tig it back together & have the top decked & you are good to go!!!!
BTW,,,are you up past your bed time???
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #882
Old 08-21-2013, 01:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Darn- I was REALLY hoping you had some of those 'trumpet' pipes to trade...
Anybody here into metal spinning?
  #883
Old 08-21-2013, 04:05 AM
Drag Star Le Mans's Avatar
Originally Posted by mechanickeith View Post
2 2barrels side by side!
You want twin two barrels plus Nitrous? Setup Roger Manson ran years ago.
ID:	334066   Click image for larger version
ID:	334067   Click image for larger version
DragStarLeMans
  #884
Old 08-21-2013, 02:08 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Heh, that is cool. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
  #885
Old 08-23-2013, 01:02 PM
marks73ta's Avatar
I haven't rewritten any songs in a long while. The theme was getting stale. But I heard this the other day and I had to do it anyway.
Lunatic fringe
http://www.youtube.com/watch?v=_9tOR4On8Uk
Pontiac Fringe
They know we’re out there
We’re not hiding
And they’re no longer laughing
They can hear us coming
We hear no more laughter
They’re wise to us this time
They know what we’re coming after
Pontiac Fringe
In the street lights dim gleaming
This is open season
But they won’t win this war
And they’ll have to blame someone
For they’re own confusion
And they’re gunna cry this time
‘Cause they’re not good at losin’
They can hear us comin’ comin’
Noooo, they’re not going to win this time
They can hear our power
Up and down the Main streets
Pontiac Fringe
They all know you’re out there
Can you feel they’re resistance?
When we loose our Thunder.
Mark L
  #886
Old 10-06-2013, 01:59 PM
marks73ta's Avatar
Well, the weather has finally turned the corner and it is now a workable temperature again. So I've made the plunge and am installing the radiator in the trunk. I bought a -16 AN used hose with fittings off of E-Bay. Bought 1 inch copper (expensive) 10 foot tube and several 45 and 90 degree fittings to run the water from the rad to the front of the motor. This is the radiator support for the trunk.
I've also decided to build my tilt front end without the hood. Just the fenders and grille. In a stock '63 there is a big by large front filler panel that closes off the upper grill area from the back of the grill to the top of the radiator. I looked into chroming it but they wanted $160 to do that. I took it to a powder coater and for $45 it will be sandblasted and coating in a semi-gloss black. It should look good behind the grill without a hood.
I also bought some polished 2.5 inch Stainless Steel tubing to build my up pipes from the headers to the turbo. I'm using Heddman shorties, cutting off the outlet flanges and having V-Band flanges welded on. And the same flanges added to the tubing. Then I'll be able to locate where the tubing will take me to locating the turbos. If the tubing allows, I'm going to mount the turbos along the firewall, compressor inlet towards the motor and the exhaust exit towards the fender. The turbos will exit into a 3 into 4 inch cone expansion and into 4 inch 90 degree elbows, taking the exhaust just inside the fenders (much like gasser wheel well headers) down to the bottom of the frame to another 90, then back along the rocker panel pinch welds. Then out in front of the rear tire. Letting the turbos be the mufflers. We'll see how that all turns out.
Mark L
  #887
Old 10-06-2013, 03:14 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Good to see you back at it, Mark. It is nice in our Arizona garages again.
Jim
  #888
Old 10-06-2013, 06:51 PM
Engine-Ear's Avatar
Also glad you're back it, Mark.
Not having much (well, ANY) experience with turbos (OK,except for when I was 17 and my dumb, drunk self thought the braided hose on my friend's Turbo Regal looked cool so I grabbed it), I got lost in your plan description... so I will just sit back and wait for updates.
BTW, what are your daytime highs and evening lows like in Glendale today?
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
  #889
Old 10-06-2013, 07:03 PM
"BTW, what are your daytime highs and evening lows like in Glendale today?"
64 low, 92 high ,,, Nice time of the year!! Swap meets & car show season is coming right up!!
Keith Collier
Tech advisor
POCI.org
  #890
Old 10-07-2013, 12:12 PM
marks73ta's Avatar
Matt, so great to see your "likeness" pop up. I miss all my good friends back there and going to Gus's. The weekend car shows there are getting off the hook now. Don't worry about the turbo thing. I wished I knew what I was doing, might be done by now, LOL. And yeah, don't go grabbing anything located around a turbo after it's been run.
Keith is right. The thermometer on my back patio this morning was 60 at 7:00 am. Highs in the low to mid 90's but they are predicting 74 as a high I believe Friday. I'm all over that, LOL. Hopefully getting my headers and pipes back today. I'll be better able to mock it all up and get pics to better explain it all.
Mark L
  #891
Old 10-07-2013, 07:05 PM
charlie66's Avatar
Wow! I 'd like to try that on my 4 cyl. cool manifold!
My Half AN Injun.....
  #892
Old 10-08-2013, 02:16 AM
marks73ta's Avatar
(PSSST Charlie, I have half of a Tunnel Ram---just sayin')
Markus Anonymous.
  #893
Old 10-10-2013, 12:51 AM
marks73ta's Avatar
Finished the radiator mount and the top shroud piece. I made a 1/2 by 1/2 square tube surround for the radiator opening, made a flat sheet metal top with the opening to match the radiator opening and bent the sheet metal around the 1/2 by 1/2 tube frame. Next I'll make sides from the top down to the trunk floor and use foam to seal it all in. The dual fan shroud bolted/sealed up to the bottom of the trunk floor will then pull all of the air thru the radiator and out under the car. I still have to take the trunk lid to the guy that will put in the louvers.
I also bought 2.5 inch polished stainless 180 degree tubing and had the welder that I go to weld on the V-Band flanges.
This how it will install and come up over the frame to the turbos. The second set of 180's will get cut in half and the now 90 degree bends will get welded back on in as "S" shape to match up to the turbos. The pic shows the header installed with the first tube coming up. The second 180 is just setting in the flange. I have to take it for cutting and welding yet.
I have a Crusie/Car show this weekend so I hope to get that front grill filler panel from the powder coaters by tomorrow.
Mark L
  #894
Old 10-10-2013, 08:07 PM
marks73ta's Avatar
A quick side note here. When I found this '63 Cat I was looking to find a '60. I thought a '60 Catalina would have made the perfect Gasser type street freak. But I found the completely rust free '63 and just had to have it.
I found a pic of someone's '60 Catalina built as a mild Gasser, not sky high or over the top. Just the way I intended to build one. I think it looks so darn "tough".
I also have this Pro-Street example.
I just love the looks.
Mark L
  #895
Old 10-10-2013, 08:53 PM
I like the white drag car.
Jim
  #896
Old 10-11-2013, 02:07 AM
marks73ta's Avatar
Hey Jim, it's got a straight axle. But not too radical looking otherwise, pretty much what I wanted to do with a '60.
Mark L
  #897
Old 10-11-2013, 11:30 AM
The funny thing is, when I was building and driving 32-48 Fords, we installed dropped axles, because the "straight" axles left the front end too high.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #898
Old 10-13-2013, 04:21 PM
marks73ta's Avatar
Trailered the Catalina to the big city wide Cruise on Central Saturday. I was very pleasantly surprised at the interest the '63 garnered. Almost every person walking down the aisle stopped to study the car. There were times when there were 5-8-10 people all around the car. Many pics were taken. Really felt good. These are some pics of the Cat.
The cruise was great also. I give a BIG shout out to the Police department. They required that the event owner install temporary fencing/barriers along the street to prevent anyone from accidentally falling into the street during a burnout. Then they stepped back and let the guys/gals have their fun. As long as the burnouts stayed stationary and did not try to do a funny car type burn out, everyone was left alone. Big props to them.
Mark L
  #899
Old 10-13-2013, 05:21 PM
Merrik66 Merrik66 is offline
Your car is killer. I've followed you progress from time to time. It's great to see your at this point! I absolutely love the 63 cat, I've had mine for about 7 years now and even though it's not a cosmetically pretty car it gets looks none the less. I look forward to getting a turbo build in mine but the only mod is in the drivetrain. You have such a cool rig!
  #900
Old 10-13-2013, 06:09 PM
Car looks great!
