Old 11-17-2013, 12:47 PM
Judge273's Avatar
Judge273 Judge273 is offline
Rain or snow on Friday? Hope they are wrong as today is better than predicted so far...I will go late after storms with Joe!
Mike/Illinois
  #142
Old 11-17-2013, 02:09 PM
Judge273's Avatar
Spoke too soon as it a nasty storm as predicted, hope our friends in Peoria area are okay. Washingon IL got hit hard already and it isn't done.
Mike/Illinois
  #143
Old 11-18-2013, 07:59 PM
70RAlll 70RAlll is offline
[QUOTE=Bentwheelbob;5065165]
Originally Posted by YNOBIL View Post
Took some outside photos but it's rainy and overcast here today. Keep in mind my filler cap was painted with paint that was mixed using my original mint valve covers.
Bill,
So which do you think matches more closely?
Here's a couple pictures comparing the OER #5 to the OEM paint, and another picture that compares OER #5, OEM and Tiemann #4. The difference between the OER and the OEM is pretty subtle. It is definitely a shade or two lighter, but that may just be lot to lot production variations.
I got your samples in the mail. Thanks.. I think of the samples you sent, OEM and Tienmann are the closest. I still like OEM best, but it appears this discussion will end up being personal preference vs actual definitive results. I guess we can all agree some colors are way off, but this is such a strange green blue color, it is quite difficult to get dead on. OEM makes some of the best colors in the industry. Expensive yes, but as we see here, they do considerably better job than most $15 can paints do at color matching. I have mentioned this a few times, will again.. I don't quite get all the discussion about the 3 can minimum or the cost when we are talking about 20k++ restorations vs <$100 of engine paint..Just seems misplaced to me.. Anyway, BWB thanks for the test.. personally..I would leave it be now and stop taking new colors to test.. I believe we have concluded which colors best match..
  #144
Old 11-18-2013, 08:04 PM
Well, I tried taking pictures but the flash must have washed everything out. They all looked like the same hue. To my naked eye against an intake manifold, I thought OEM may be the closest. But, my thermostat housing is a different looking blue and comes closest to the Tiemann paint. Did the '72 housings have no flat spot on the side unlike the '74s, which did (I know they look nothing like a '70)?
My report, none were a match.
HFR I don't believe the 72 thermostat housings had the flat spot.I know 1971 did not..
  #145
Old 11-18-2013, 09:27 PM
Held for Ransom's Avatar
Thanks Bill. The differences in color between the cast iron intake and the aluminum housing were significant so it had me questioning it (I'll probably pull the housing anyway to see if the original thermostat is under there as I don't remember it ever being changed out).
  #146
Old 11-19-2013, 02:51 PM
YNOBIL's Avatar
YNOBIL YNOBIL is offline
Sample # 6 "OER" arrived today. Tiemann still looks the closest to mine. Since my memory is fading as my age goes up, I've already put all 6 samples in my trunk before I can forget to bring them.
Bill Nawrot (Wino Bill)
1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019
Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot
HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/
YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU
1967 GTO Conv
  #147
Old 11-27-2013, 03:04 AM
transam1972 transam1972 is offline
Default OER engine blue
I received my OER engine paint and in 2 days I was able to reshoot the top and front of my engine..for me, I definitely like it more now(formerly AMES,then Plasti Kote)..and it is right there with a close match to the other top picks..if an engine is out of a car you can do what you like..in the car and an unexperienced painter..OER gives me a shot at dancing with the big boys
  #148
Old 11-27-2013, 10:41 PM
72TAMAN's Avatar
72TAMAN 72TAMAN is offline
Not sure if my eyes are playing tricks on me put if I look at the two pictures of the rad cap on post 137 it does not look the same ,stroll down to post 137 and have the two pictures on the screen so bottom and top of pictures and the top one looks darker and if I look at the picture in the post 146 the cap looks lighter in color. I guess you have to see the samples in person to see the right color of samples or the right color of cap.
ANDRE
1972 TRANS AM , UNDER RESTORATION
http://forums.maxperformanceinc.com/...d.php?t=656067
1972 FIREBIRD FUTUR PROJECT
http://forums.maxperformanceinc.com/...d.php?t=674551
1978 TRANS AM (PARTS CAR) MAYBE
1971 LEMANS T37 (PARTED OUT)
1976 TRANS AM (PARTED OUT)
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #149
Old 11-27-2013, 10:54 PM
YNOBIL's Avatar
It's the same oil filler cap. #137 was taken on an overcast day and #146 on a sunnier day. Even in person different lighting changes my opinion of which looks closer. At MCACN most thought OEM, OER, and Tiemann were all acceptable.
1967 GTO Conv
  #150
Old 04-01-2014, 11:39 AM
Pepi's Avatar
Pepi Pepi is offline
BWB do you still have any samples left?
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #151
Old 04-01-2014, 01:21 PM
Bentwheelbob's Avatar
Pepi - I'll look and see what I can dig up and let you know by PM. In my opinion, it's pretty much narrowed down to three paints. For rattlecan paint you have two choices - OEM and OER. OEM is a 3 can minimum at about $70'ish per can. It is darker than the OER and a little more green. The OER is $16 per can with no minimum. If your going with bulk paint gun applied then the Tiemann is it. Each has it's proponents. In this thread from post 139 on there is a pretty good comparison of these 3 paints. I have just noticed, however, that at that point the paint fumes must have been overwhelming me and I started to refer to sample 5 as OER and the unnumbered sample as OEM. The order should have been reversed. I did not test the VHT.
On the pictures below of the Black Car, the engine was painted with OEM by NJSteve, and I reshot the valve covers with OER to freshen it up. You can see that the intake is slightly darker with more of a greenish cast.
  #152
Old 04-01-2014, 01:28 PM
Pepi's Avatar
Okay, thanks. I don't know if I'll need the samples. I am going to have the wife pick up a can of DE1610 by dupli color tonight and test it against the oil cap. all I have to paint is a water pump. Don't want that to stick out too bad. I suppose I could call the engine rebuilder or the shop he worked at almost 20 years ago and ask them what they would have used or if they have anything laying around that I could use to match up.
I'll let you know if I need the samples to see what matches the paint color they used. Like in that other thread I posted in, I always thought the original was more greenish than what the engine got repainted in. For a while there I thought it got painted the earlier '73 color instead of late '73. But now that I look at it more, it doesn't appear that light/powder blue.
Thanks,
Pepi
  #153
Old 04-01-2014, 02:45 PM
YNOBIL's Avatar
Thanks,
Pepi
Pepi, Do you still have your old water pump? I've posted this before. For an extra charge "Carquest" will send back your original pump and have it rebuilt and returned to you. You'd probably have to tell them not to strip off the paint.
1967 GTO Conv
  #154
Old 04-01-2014, 03:04 PM
Pepi's Avatar
Thanks, actually this pump had been replaced, and it doesn't fit with any date codes. I don't remember the vane impeller whether it was large, small, shaved vanes, the gap a bit big I do remember that. Thanks to another fellow member, I got one with the right date code, large 8 vane that hadn't been shaved down, but the whole thing was rusty. So I had that rebuilt with good clearance with the divider plate. So that is what I need to paint, it had been bead blasted to clean up all the rust.
Thanks though for the information about carquest.
  #155
Old 04-01-2014, 03:11 PM
Pepi's Avatar
Just looking through a catalog and the OER paint looks like it will be the match. I'll check out the DE1610 tonight and if not I guess I'll order a can of OER to paint the pump.
So Bob, I will not need those samples. Thanks though.
  #156
Old 04-01-2014, 08:51 PM
Pepi's Avatar
Just got done painting the pump with the Dupli color DE1610. Not too bad, whether it is because it is fresh paint compared to the oil cap which is 18 years old and 6000 miles on it, but it looks a little greener that the oil cap, but more of what I remember the engine having before rebuild and repaint. It is going to be so low I hope it doesn't show difference too bad once pump is installed.
  #157
Old 04-01-2014, 08:56 PM
weranc55's Avatar
weranc55 weranc55 is offline
I used the oer paint. Lays out nice and not super glossy.
  #158
Old 07-22-2015, 04:43 PM
firstyearta's Avatar
firstyearta firstyearta is offline
So my car was built the 4th week of December 1972 (1973 Formula). So what is the correct color to use... 1972 blue I am assuming. My understanding is that was used through 3/15/73, correct? Or am I confused.
So, as of this date, what is my best bet for a correct color match?
http://i27.photobucket.com/albums/c168/firstyearta/67side.jpg
  #159
Old 07-24-2015, 12:37 AM
OER.
  #160
Old 12-31-2015, 08:22 PM
So I ended up going with the OER K89210 and I'm really not sure about this shade. I understand it has a greenish hue to the blue but to me these is almost no blue to this color at all, it basically a teal green. I know it's tough to judge paint colors over the internet, but does this look right?[IMG][/IMG]
