Old 12-02-2013, 12:17 PM
chaz069 chaz069 is offline
Default 80T/A Door Wiring Routing? In or out?
Does anyone have a pic of a bare door with the wiring exposed? I have power windows and locks. Does the harness run inside the door with nylon clips or on the inside shell? Just painted the car and forgot where to run the door wiring harness. Thanks chaz069
Old 12-02-2013, 01:05 PM
Which wires? I'll take a picture of my 81 tonight.
The lock actuator wires run inside along the crash support bar bottom held by about 3 clips.
Old 12-02-2013, 07:03 PM
Default Wire harness 80 T/A door
There are three small harnesses. Door lock actuator (2 wire), power window motor (2 wire),and the power window switch (5 wires). Thanks for your help. chaz069
Old 12-02-2013, 09:59 PM
Here you go. Painless Wiring also has some pictures in their instructions for their power window/locks harness. They add 4 relays for the windows. This was one of theirs I added in .
ID:	345259   Click image for larger version
ID:	345260   Click image for larger version
ID:	345261   Click image for larger version
Old 12-03-2013, 05:22 PM
Next time I'll take pics. Thanks for the pics. chaz069
Old 12-04-2013, 12:05 PM
Those help or you need some others? Door panels are still off.
Old 12-04-2013, 08:46 PM
They worked. thanks chaz069
