Nope, it's an original gasket. GM Part # 9790081. It also has another part number on it of 3401. The other gasket I was thinking of must be for a 350, because it is too big also.
I found a Mr.Gasket head gasket from Summit
Mr. Gasket Ultra-Seal Head Gaskets 5810G. Head Gasket; Ultra Seal; Head Gasket; Solid Steel Core; Laminated Outer Facing; 4.205 in. Gasket Bore; 0.038 i The profile and material content sound like it is the correct one but has a larger than expected Bore size. Might be because of the cutouts on the inner sides of the bore. Has anyone used this gasket with success?? |
Based on what "gtofreek" mentioned about the 3401 stamped on the head gasket he has, I found the "Victor Reinz #3401vc" that has good reviews. It was tough to locate but I found it at DavesDiscountParts for a reasonable price.
I built a 326 a few years ago too- the owner also wanted to use the stock heads too, but when I heard his power expectations we both knew better heads were needed. We opted for KRE D-ports milled to 58cc and fitted with 2.05/1.66 valves. The chamfers did need to be repositioned to work with the KRE heads, but it was well worth the effort.
Cam selected was a Comp cams XE 268H- it has your typical lopey Comp cams idle, but it still works with the power brakes. Stock Sealed Power pistons were used for different reasons, but 4340 H-beams were used along with the stock crank to help the rotating assembly balance without Mallory metal. The block was also decked and SCR was set to 10:1. We also used the Victor-Reinz 3401VC head gaskets. The 326 was finished off with a port-matched performer, Holley 750 Vacuum secondary, and Hooker Comp headers. So how did this build turn out? The owner loves it, and has trouble convincing people it's only a 326 and not a 400. Imagine what this little 326 could do with some head porting and a roller cam. The 326 has alot of potential most Pontiac owners never realize.
326 was a good little engine in its day and a rebuild is fully justified to maintain the value and originality. but for any other reason a 400 makes better sense
DONT LISTEN!!!! LOL!!! ![]() Seriously you will not be unhappy with a 326. They run cool and last forever! If you were closer, I would unload the wagon and take you for a hell ride. You would swear its bigger and has more power then a 326. Did you actually get a tracking number for those head gaskets? If so I need the phone number as I am ordering what they have left!! Thanks Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
I actually just received a REFUND notice from my Head Gasket order . Back to square 1. |
I knew it! I will help out and see if I can find some.
| The Following User Says Thank You to 1967Tempest For This Useful Post: | ||
OUT OF STOCK
I've got a set of the 3401VC gaskets. Not sure what they are worth, maybe $40? I know they were hard to find when I needed them a couple years ago and somehow I ended up with a couple sets. Current project is a 400 so won't be using these. Steve
Daryl Here are the pics.
| The Following User Says Thank You to helmerrock For This Useful Post: | ||
I have someone I can ask tomorrow if I get chance.
| The Following User Says Thank You to goatwgn For This Useful Post: | ||
Ill bite. Make 326/350 gaskets PY!
Hello,
I've been following this thread because I too am rebuilding a 326 right now. I was hoping to clear something up regarding the head gasket discussion. The nicely contoured 350 specific gasket is just that, a 350 gasket. The combustion chamber and "notches" in the bores are offset to the outboard side on the 326 and that 350 gasket would be a big no-no on a 326. It would be nice if someone made a more contoured gasket for the 326 as I hate giving up the compression using the #8518 but it will do the job as mentioned previously. Here's some pics of mine showing the off-center chambers and notches. Just trying to help, Ron.
Last night on my way home from work I stopped by my local machine shop (JB Auto Machine Shop in Baltimore County) to see if they had any left over Victor Reinz head gaskets but no luck. I ended up buying a set from a member on this forum. Thanks Steve. We also discussed having work done on my 094 heads to improve performance. ... milling(about 0.020) to increase CR, hardened valve seats on the exhaust ports, replacing rocker studs to screw in type. I'm going to do the porting work myself. That should be about it for the head modifications along with a new flat tapet VooDoo LUN-10510701 cam, new cam bearings, hydraulic lifters and new springs. |
