#61
The purpose is as 71HOT/A said.
The same reason they put that metal 'spring' thing on the cowl for the Formula hood.
#62
This thread has become a learning experience for me....
#63
Like I always say: "I'm not a failure, I am just an excellent bad example."
I guess I am glad afterall, to have started all this insanity with my shake-enstein resto. ;-) |
| The Following 3 Users Say Thank You to njsteve For This Useful Post: | ||
#64
Didn't mean to devalue anyone's cars or parts here...But I will probably get another air cleaner form the parts bin and weld tabs on it to hold the SR shaker on the car. that was a great suggestion. Orig air cleaner and shaker will go to storage. I"ll fab up a GP air cleaner to do the trick. And if a chance to fix the SR comes up, I'll change them to Shake-enstiens! |
#65
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
| The Following User Says Thank You to 2manyT/A'S For This Useful Post: | ||
#67
Ok now I'm confused? W66 is a Formula (that part I know). So you meant non RA? So if that is the case isn't a dual pre heat needed for TA? So then a modified W66 air cleaner with tabs added and another heat riser needed for a 71-72?
Just trying to learn here....
Mike/Illinois |
#68
I mentioned this earlier...has anyone seen the curved front,no drain shaker?...had to be the prototype...and I will have mine, shaker,not stirred...oh, and think of how much they saved when 72 used the accelerator kick down switch...and in 73 even more when they deleted it...I don't buy the engine drive by noise...thoughts?
#69
You got it.....any 70-72 Formula dual snorkel with the mods you described will work.on a T/A...
#70
and I have the tabs.....
#71
Off topic..not shaker parts...but relevant,I believe....
I think there is a market for these & should be simple to make....
#72
Ok what is it
#73
#74
is that the ground strap used on the rear tail panel?...if so I need one, mine is mangled
#75
![]() Tag light ground strap. They are almost ALWAYS rusty,mangled or missing....
| The Following 3 Users Say Thank You to 2manyT/A'S For This Useful Post: | ||
#76
OK so who has a relatively junky formula air cleaner? Just needs to work since the orig stuff goes on the shelf.
any other applications, like chev Camaro or whatever? then again maybe I can make one by adding the deep drop to another air cleaner. Can't be more complicated than hanging quarters on a GP... |
#77
Anyone try the repop air dual snorkel that is suppose to be for TA RA IV and 455 HO with tabs and lid?
Mike/Illinois |
#78
Unfortunately, no other applications, the snorkels are positioned differently than a '69 GTO or '70-72 GTO/455 GP dual snorkel aircleaners. Have repaired & restored a bunch of factory dual snorkels.
| The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
#79
Depends on what ones building/restoring, they fit, but many differences in details of the repro drop base aircleaner.
#80
The Keith application: For driving it, and keeping the OEM on shelf?
Mike/Illinois |
