Old 12-10-2013, 08:06 PM
Originally Posted by cgeise View Post
Im not claiming to have the definitive answer, And I am the first to embrace inovation. All I am saying is I think there needs to be line where it is either a Pontiac -- or its not. Kinda like the athlete that wants to compete as a women ----- but tests as a Man. George, your condition that if it bolts to a Pontiac block its a Pontiac, what if the lifter bores are moved - additional head bolts are added and it has a one off type crank to make it all come together, and you bolt some Sonny's semi hemi heads on that bad boy - Is it a Pontiac ?? And Tom, lets face it, there are way more index or bracket class racers than there are heads up -its just the reality of it all, so is the absolute ultimate combo needed to be able to compete in those classes needed--No. Its the same in the Chev camp -- is a 5.3 in bore space 11.2 in tall deck really a chevrolet when it sports symetrical aftermarket heads ??
They are porpous built race engines -- far and away from Chev's. And if you bolted a set of stock RA V heads on that block -- is it a Pontiac ?? Its very convoluted to say the least.
Curt, Using George's definition of a "Legal Pontiac Engine" I could easily bolt these SOHC Ford 427 heads on an All Pontiac Block (Lowering the center lower head bolt drilling .375"). Bore spacing for the Ford 427 is with-in .005" inches of the Pontiac block.
I could call it a legal Pontiac Block and Heads using George's theory (All of the parts are available today new)
Tom Vaught
Name:	66 Ford SOHC Head_timing_chain_and_cam.jpg
