Old 10-27-2013, 03:03 PM
31 B'ville's Avatar
31 B'ville 31 B'ville is offline
I got a complete wood kit from autowood.net to replace all of the original wood in the body. I told them the amount I was chopping the roof and they made the wood to match that dimension. What you see in the photo is the new wood.
  #102
Old 10-27-2013, 03:12 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
I hope you are going to add a lot of steel reinforcement along with the wood. I thought about saving the wood in mine but after talking with a friend who did a 31 Chevy I decided I didn't want to have his nitemare with wood he bit a similar car to mine with a healthy v8 replaced all the wood with new wood and no extra steel.hr drove it a lot for a couple years the started to notice that all the body panels were getting loose his final wood problem came after a day at the strip when the wood across the top of the door opening cracked and the top sagged causing the doors not to close anymore. I think the wood is fine in a stock resto but once you add in modern drivetrain and suspension it causes a lot of problems as the original car only had 60 hp. I priced the wood kit and was able to go all steel with labor for about 1/4 the cost of just the wood the only wood I left was in the doors and around the trunk and they both had some steel structure added
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
  #103
Old 11-07-2013, 10:04 AM
GTOWAGON's Avatar
Had the body stripped yesterday with the dustless blasting method came out better than I had hoped basically no body damage and only a couple pinholes to fix. It only took them an 1 1/2 to do everything. Dropped it at the painters to get it primed
2015 GMC Yukon SLT
  #104
Old 11-07-2013, 10:52 PM
GTOWAGON's Avatar
All in prime
2015 GMC Yukon SLT
  #105
Old 11-25-2013, 02:02 AM
GTOWAGON's Avatar
Frame is together should have engine and trans in next weekend
2015 GMC Yukon SLT
  #106
Old 11-25-2013, 04:32 PM
blueghoast's Avatar
Talk about a clean body Daaaaaaanng!!!!!!!!!!!!!!!!!!!!!!!!
GT.
  #107
Old 12-01-2013, 04:18 PM
GTOWAGON's Avatar
Dropped the drivetrain in the frame today
2015 GMC Yukon SLT
  #108
Old 12-02-2013, 03:27 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Lookin' really good!
  #109
Old 12-03-2013, 07:37 AM
Jeff Hamlin's Avatar
Thumbs up
INDEED.
  #110
Old 12-04-2013, 11:10 PM
Drag Star Le Mans's Avatar
This is going to be so cool when finished!
DragStarLeMans
  #111
Old 12-13-2013, 01:07 PM
GTOWAGON's Avatar
Made a grill insert last nite out of stainless lock crimp mesh I was afraid it would unravel as I cut it but it held together fine looks just like the original material
2015 GMC Yukon SLT
  #112
Old 12-19-2013, 11:24 PM
GTOWAGON's Avatar
good day today got the trunk and interior floor primed and the underside primed and put on the bedliner
ID:	346964   Click image for larger version
ID:	346965   Click image for larger version
2015 GMC Yukon SLT
  #113
Old 12-20-2013, 07:20 PM
GTOWAGON's Avatar
Nothing is easy if your not working on a ford example rear view mirror on a ford you just lamp it onto the door frame on the pontiac the frame does not have an edge to clamp to so an hour later after drilling through the door then countersinking a hole in the outer skin now I have a clean mounted mirror. It might need an extension and a larger head but I am very happy with it
2015 GMC Yukon SLT
  #114
Old 01-15-2014, 02:17 PM
GTOWAGON's Avatar
Headers and pipes came back from jet hot today very happy
2015 GMC Yukon SLT
  #115
Old 01-15-2014, 08:51 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
They look great!
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #116
Old 02-16-2014, 07:27 PM
GTOWAGON's Avatar
Still waiting for paint so today I thought I would test fit the sliding ragtop
2015 GMC Yukon SLT
  #117
Old 02-16-2014, 07:28 PM
GTOWAGON's Avatar
Pic
2015 GMC Yukon SLT
  #118
Old 02-18-2014, 01:40 AM
Before I forget it- Thanks very much for building such a great rod out of a '31 Pontiac!!.
  #119
Old 05-04-2014, 05:35 PM
GTOWAGON's Avatar
Dropped the body at the painters this morning
2015 GMC Yukon SLT
  #120
Old 05-04-2014, 08:49 PM
Old Goat 67's Avatar
Can't wait to see it!
