| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
#81
It wasn't long after Joe had the engine running in the car that it was time to take it for a drive. Keep in mind, he started with an engine that had nothing attached or installed and a bunch of boxes with brackets, nuts, bolts etc... nothing labeled! Today, the engine compartment looks like the day it came off the lot in Arizona. Joe called me up on a Sunday afternoon and said, hey Jim, you better come over! He had been out terrorizing his neighborhood with #202! There were tire marks on the street! His description was that it was "wicked fast"! He had temporarily hung the cats under the car so it was louder than with the complete exhaust. While it ran awesome, it was smoking quite a bit. It turned out the original Rayjay had a bad seal and it was leaking oil. We did some research on rebuilding the turbo charger. Unfortunately, we didn't have a lot of luck in finding parts or a business to do the rebuild. In the mean time, an exact match showed up on e-bay that had been purchased and never installed. Best of all, it was for sale by a local vendor here in Kansas City. I won the auction and picked the new unit up 2 days later! By now the car was back at my house and I swapped out the original unit for the new one. Then I had my son follow me to a local muffler shop to have the exhaust completed. My first time to drive #202! The new system consists of a pair of NOS pancake GM catalytic converters (this is how #202 was originally because I have the original cats) that go into pipes out back, completed by new side splitter tips!
I am working on a list of projects this winter that include refinishing the trunk, getting the lighting system functional, getting the e-brake (rear disc axle) functional, and then finishing the dash wiring, stereo installation. The car was painted in the early 90's but moved from garage to garage and getting bumped and scraped along the way. I have hopes of refinishing the body next summer! Thanks for interest! |
| The Following 2 Users Say Thank You to 78Macho For This Useful Post: | ||
#82
I wish i had purchased one of those kits back in the 80's when i was looking at them. It was cheap back then, but expensive to a kid in high school, which i was.
#83
Stock everything including the original tires and no traction aids: low 13s (13-teenish) at about 104MPH with about 6-7PSI boost through stock exhaust including cats. Stock engine (W72), but open turbo downpipe, slicks, slide-a-links, stock posi-rear (3.23?), shift kit: high 11s (11.9X) at 115MPH at 15psi boost. No other "high performance" car of the era could touch it. As a matter of fact, most muscle cars from the late 1960s couldn't touch it, even with comparable traction aids and open headers. Wicked fast for sure. |
| The Following 3 Users Say Thank You to Craig Hendrickson For This Useful Post: | ||
#84
I am posting these pictures for 78Macho. This is his motor prior to being installed. I am sure most of you would agree with me when I say it is a beauty and it definitely will serve as my inspiration as I work towards my TurboForce install.
| The Following User Says Thank You to dreamn69 For This Useful Post: | ||
#85
Really, really nice work!
BTW, there's nothing wrong with the "version-2" (welded) air bonnet pictured, it flows about as good as the "version-3" (fully cast) and a really nice job was done making it look super! When the owner raises the hood at a car show, jaws will drop. |
| The Following User Says Thank You to Craig Hendrickson For This Useful Post: | ||
#86
I really like those pix. It gives me ideas and inspiration as to how I will plumb my own setup.
That setup looks almost like a bolt on kit, like the Ford/Chevy guys enjoy!
"...ridge reamer and ring compressor? Do they have tools like that?" |
#87
Awesome!
That's the way Pontiac should have done it in 1977! Wonder how things would have developed if Pontiac did the turbos on the 400 instead of the 301? It may have even passed then current emissions/MPG requirements, so no need to abandon the 400?
#88
http://originalho.com/TFReviveWhat.html Of course this kit is no longer available, so don't even ask. |
#89
That looks GREAT!!, IT WOULD EVEN LOOK BETTER IN MY 1981 TURBO TRANS AM. A matter of fact , I have a 428 short block, a '77 W72 400 4 Speed with trans and a Solid roller cammed 455 with #16 heads. Heck I will even throw in my #48 heads all for that engine.
I know, no deal, wishful thinking on my part. I wish that kit was still available. ![]() |
#90
#91
BTW, what is the function of the throttle shaft pressurizing plate thingy?
It's cool you guys did it with the q-jet. Everybody seems to do the Holley double pumper mod. How tough was it to get the qjet tuned properly?
#92
The Holley has fewer escape paths for boosted air & fuel than a QJet, hence it is easier to seal the Holley under boost than a QJet. Once you get the QJet sealed properly AND are using a pressure bonnet (hat) like the one pictured, the QJet doesn't need additional tuning. But, I always ran them a little rich in order to protect the engine from lean detonation. |
#93
I planned on converting a DP Holley, but I have a 72 Buick 350 Qjet that I could play with. Might be worth some tinkering! This qjet used a divorced choke, so I shouldn't have to mess with sealing off choke stuff as much.
The bonnet just covers the big hole and the bowl vent, correct? I gather you used check valves for the vac ports. On your kit back in the day (forgive me, I was in 4th or 5th grade when you created this setup) how did you address ignition timing? Specifically, did you limit or eliminate vacuum advance or mechanical advance? I am guessing you set timing somewhat conservative? - I didn't think that there were digital timing retards like MSD makes nowadays to pull out timing proportional to boost. I apologize for my newb-ness! The linked literature stated stuff that I am hoping for: "You will not know a turbocharger is installed until you put your foot down."
#94
Don't feel bad about being a newbie. We all were once. I will answer your questions in order asked.
#95
Craig check with clarks Corvair parts. It looks like they have the retard cannister.
http://www.corvair.com/user-cgi/cata...OS&page=NOS-12 |
#96
Bruce: Thanks for the lead, but of the couple of boost-retard units they have, they want $119 plus S&H! When I bought one in 2005, it was $50 and I thought that was outrageous, but paid it anyway. Back in the day, I'm sure H-O paid less than $10 per. Ken Crocie mentioned to me that a certain Cadillac model had a retard feature, but I don't remember the details or even if that is available.
#97
Wonder what the pre computer turbo buicks used?
#98
BruceWillkie
Anybody know? |
#99
She has a '14 Mustang, so she does possess a sporty side.Thanks for the answers. I really enjoy the simple tech. I guess that the Holley carbs must use a different throttle shaft concept. None of the Holley conversion discussions I've seen have ever touched on any kind of throttle shaft pressurization. The shaft pressurization is cool. I work in the semiconductor biz on high vacuum machines, and I thought to myself "Hmmm... like a vacuum differential seal, just backwards!"
#100
Amazing!
FREEBIRD |
