#121
Willing to bet if you did not show the "chock" in a picture most would not have got it.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#122
The whole point of your thread was to show the power increase in an "apples to apples" test by your standards by switching intake manifolds. Now how can it not be by using a differant carb for testing and flipping around the scenario with the spacers and still swapping out intakes? Maybe that can be round #3 .
Illinois Outlaw Gassers 6.27@107 9.97@131 |
#123
#124
Bill I can easily get the customer back in and remove the E carb and throw a Q-jet on and test it or remove the high rise intake install cast iron pos intake back on and install Q-jet if you are curious what would the results will be for round #3 if that what you're implying, BUT the main thing would be here is the critiques will still cry at this point further again cause the Q-jet isnt built to a one book standards......OR and create further critisim in any nature. Rest assured that i will post something else further down the road as has been very appreciated by most forum members for my time & testing and we"ll see if history does't repeats itself.
http://www.youtube.com/watch?v=3FfKVVZW1-Y Last edited by harry k; 12-29-2013 at 12:53 PM. |
#125
Sure you may get some comments like "Wow, that motor is pretty low/high on HP or TQ" relative to my on motor, experince, etc., but no one can dispute the gain or loss relative to the baseline if you changed nothing else. Last edited by NeighborsComplaint; 12-29-2013 at 01:11 PM. |
#126
As i said earlier: we will have critiques and on top of it some to tell me what to do(its like my 1st time in rodeo
further In order to satisfy some, we need few UNBIASED witnesses to be around. |
#127
Your dyno graphs are gone. How can unbiased people engage in an intelligent conversation when they cannot see the comparisons?
Is there any that you can repost them? |
#128
Harry- straight up, unbiased question for you.
Do you believe that running the Edelbrock carb into the factory iron intake is an efficient set up?
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
#129
Well without any baseline test with matched componets , to me this is about the hp lost not gained
#130
What other baseline are you refering to?
#131
Keyword is matched. Do you think any of the hp gain was the result of no adapters?
#132
yes indeed they are gone now, refer to my post #1 in the bttm and thats what happened. |
#133
Better flowing intake.
http://www.youtube.com/watch?v=3FfKVVZW1-Y |
#134
Did you miss my question? It is a simple yes or no question.
#135
Back again to real world track testing- if square bore carbs with an adpater are so bad on a factory intake why did my car pick up et and mph over a pretty dialed in Qjet carb?
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#136
HarryK, thank you for taking the time to show your unbias dyno results with the parts on hand and even taking the time to explain the limited testing you did to pompous adults that can never understand it. You are a hero in my book, keep it up.
Steve |
| The Following User Says Thank You to p4msi1 For This Useful Post: | ||
#137
Karl
#138
HIS
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
#139
Glad to hear your customer may welcome a revisit: a Q-JET on the (repainted Iron). that data run will get a few thousand views. Hmmmmm, is interesting.
We all know good things take time. |
#140
I KIDD not: this last Norwalk, we put a "junkyard dog" Q-jet (dry-sat for 10 months, threw in my trunk for giggles at norwalk) onto a 17.4 ET "69 firebird" with an "aftermarket carb" and ( no other changes) dropped 3 seconds on the ET. Some talk/coach on the excitement took another 0.5 sec off the ET. Therefore 17.4 to high 13s from a carb change. Relevant to the issues in this Thread. The fella took my Q-JET home like a newborn! giggles indeed. JUNKYARD DOG: a 1973 chevy truck Q-JET where the Top-plate NEVER came off. Accel pump rod on inner hole, installed BE Sec-rods. power-trimmed the Air-damp valve per the loaded 20 MPH pulls in 3rd gear. That proofed as-is for 12.2 ETs on my 68 GTO (the 1050 has since been on with equal ET, +0.5 MPH). AFTERMARKET carb: some dumb Squarebore <\= 750 cfm, or at best an AFB. 69 FIREBIRD: some clapped-out 69 bird (68?) that they bought curbside on the way to Norwalk, put on the "just in case" trailer, and after a few beers and gutting the interior (in the pits) decided to run it. Fairly rust-free floors i might add. NEWBORN; well the fella enjoyed the Q-JET a few months, and mailed it back to me. 3.5 seconds dropped in ETs: Time slips by a capable driver with all systems go. No spins, oops or butts. I've since trew the "j-dog" on a 500" Caddy engine that all of a sudden idles well, and throttles real well ( that (hehehe) had a (heheHAH) a Predator carb). just a dumb carb that works properly. HIS
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct Last edited by Half-Inch Stud; 12-30-2013 at 12:14 AM. |
