Old 01-13-2014, 03:26 PM
DSMTiger's Avatar
DSMTiger DSMTiger is offline
Default Recommendations for 1966 Rally 1 wheels and tires
I am getting close to completion of my frame off restoration of a 1966 GTO. The restoration is pretty much back to factory original. I will be driving the car probably 2000-3000 miles per year so I want good tires and wheels. Will be buying new Rally 1's and radial redlines. Don't want any issues with tire/wheel clearance. Chassis is completely rebuilt with all new springs and suspension components so I don' expect the body to be sitting low. After talking with others, I think I have decided to get Diamondback tires. Haven't decided whether to go with 6" or 7" wheels. Any thoughts or recommendations for wheel and tire size based on your experience would be welcome. Since I will be spending some pretty good $ for this, I want it to look right and drive right. Thanks!
[SIGPIC]1966 GTO, Tri-Power, 4 Spd, #'s matching. PHS documented.
Old 01-13-2014, 10:47 PM
squidtone's Avatar
squidtone squidtone is offline
DSMTiger,
since you're asking, here are some of my thoughts:
Are you thinking of a stock look, or a slightly custom look? Do you mean the DB red lines?
For stock 14" diameter look, keep in mind subtle differences in wheel offset can make a big difference in look. Stock 14 x 6 Rally I wheels had a narrow exposure of rim (offset) and indeed they need a narrow trim ring (which is hard to find for original Rally I wheels). But,last I knew, you can still get aftermarket 14 x 6 Rally I wheels, and the offset is close to original. And, the aftermarket wheels slots are slightly smaller to allow the use of normal, easily obtained trim rings. In my opinion, the narrow offset with accompanying narrow trim ring look is perfect for 64-67 cars.
If you go for a wider aftermarket Rally I wheel, with a wider trim ring, like a 14 x 7", or the 15 x 7" wheels, they have a deep dish look that (in my opinion) really changes the look of the wheel/trim ring/centercap combo. The six slots in a deep dish aftermarket Rally I wheel look lost to me.
It's personal preference!
Another thing too, you have a cool 66....1966 GTO's came from the factory with red-painted brake drums if ordered with Rally I wheels. You might want to paint your drums red....
Good luck on you decision.
Dave
http://www.squidsfabshop.com/?
(updated January, 2013, Pypes exhaust installation)
The Following 2 Users Say Thank You to squidtone For This Useful Post:
Old 01-14-2014, 06:44 PM
TheCirque TheCirque is offline
DSMTiger--
I myself have been searching Rally 1 options. I'm not trying to do the perfect resto as mine is a driver. I think I've settled on the after market 15" Rally 1's simply because I can get a few more brake options behind it.
I really wish someone would do a 17" like they did with the Rally II's (more tire and brake options) but I'm guessing the market is quite a bit smaller. Post pics whatever you end up with!!
FUEL IS FREEDOM
Experience: What you get when you don't get what you wanted.
Old 01-14-2014, 07:33 PM
nodwyer's Avatar
nodwyer nodwyer is offline
Do a search on wheel and tire combos lots of them in here.
Old 01-15-2014, 12:52 AM
GT182's Avatar
GT182 GT182 is offline
DSM if you're not going totally concours, go with at least 15x7" wheels. Maybe even 15x8 or 8.5 in the rear.
I have 15x8.5s on the rear of my 66 GTO with 255/60 BFG TAs. For now 14x7s up front with 215/70s, but going to 15x7 or 15x8s. Car is a lot more stable with the wider tires. I might even run a full set 15x8.5 '79 WS6 Snowflakes once I convert to front disc brakes.
Also running airbags in the rear with airshocks, and a 1 1/4" swaybar up front. With the wide tires and the rest, she will corner flat on the tightest on and off ramps at 40mph. The car rides pretty good and is rock solid on the highways.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 01-15-2014, 09:18 AM
Tempest's Avatar
Tempest Tempest is offline
Since you asked, I would certainly go with 15 X 7 inch wheels over any 14 inch wheel. I think the 15's fill the wheel well better, and you have a greater selection of tires at 15 vs 14.
Also, I don't know if this will be noticeable, but your rpm's will be slightly decreased with a larger tire circumference, so there may be some savings there, and less tire wear. I know these are very marginal advantages, but they do favour the bigger wheel.
Please post pics once you have made your selection.
The Following User Says Thank You to Tempest For This Useful Post:
Old 01-15-2014, 04:39 PM
DSMTiger's Avatar
[QUOTE=GT182;5108266]DSM if you're not going totally concours, go with at least 15x7" wheels. Maybe even 15x8 or 8.5 in the rear.
I'm not going to be concourse correct since I will be running radials but I want the look to be very close to original.
Old 01-15-2014, 04:46 PM
My thoughts exactly.
Old 01-16-2014, 01:19 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
What is the best 14 inch red line radial and rally 1 combo to get? I use to want to put 15 inch tires on the cars, but have now changed to keeping it close to original look like DSMTiger. Would still like to have a radial tire though. I would like to change out the 15 inch wheels/tires on the 66 which are 70's rally 2's.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 01-16-2014, 12:33 PM
GT182's Avatar
DSM, I'm running Cragar SS wheels from the 70s and 80s with the oblong holes. Period correct for aftermarket wheels and they look good on the car.
Gary
The Following User Says Thank You to GT182 For This Useful Post:
Old 01-16-2014, 06:11 PM
DSMTiger's Avatar
Those do look good! What size are the wheels and tires?
Old 01-16-2014, 08:37 PM
geeteeohguy's Avatar
The best 14" for me is 225/70/14. Great looks, fills the wheel well, great handling, and best of all, stock tire height so the speedo stays accurate. Been running them since the '80's.
Jeff
Old 01-17-2014, 11:51 AM
michaelroy's Avatar
michaelroy michaelroy is offline
Default Tires/Wheels
These are Diamond Back 215/70/15's Radials. Purchased in Jan. 21 2008. Paid $164.00 each then. Had them shipped.
They are on my 65. They have been great and I like the taller tires. I tried shorter wider tires w/ poverty caps but didn't like the shorter tires. I also had the redlines w/ poverty caps, that was a cool look.
Mike
ID:	349653   Click image for larger version
ID:	349654   Click image for larger version
Old 01-17-2014, 11:57 AM
arbys's Avatar
arbys arbys is offline
I couldn't really tell in the third picture but I really like the looks in that 1st picture.
The Following User Says Thank You to arbys For This Useful Post:
Old 01-17-2014, 12:18 PM
george kujanski's Avatar
I've heard tire choices in the 14" size are limited, and probably getting worse in the future, hence i went with 15" wheels.
george
Old 01-17-2014, 02:14 PM
GT182's Avatar
Wheels up front are 215/70-14 Firestone radials on 14x7 Cragars. Rear are BFG 255/60-15s on 15x8.5 Cragars. I'm going with 15x7 Cragars up front if I can find any good ones with no rust. That's why I'm going to Kowtown in the spring to look. I missed a set there 2 years ago.Ya gotta get there real early. Early Friday is best, but Saturday real early can be ok.
Like George says. 14s are disappearing from the suppliers and getting scarce.
Gary
Old 01-18-2014, 08:00 AM
Jeff Hamlin's Avatar
"I want it to look right"
"I want the look to be very close to original''
If the above mentioned is what you're after then anything wider isn't it;
http://www.cokertire.com/775-14-fire...line-tire.html
Old 01-18-2014, 11:38 AM
DSMTiger's Avatar
Thanks for your thoughts but as mentioned in my original post, I will be driving the car and want to do so on radial tires. I have also decided to use Diamondback tires based on comments and experiences of others. The Coker tire you show is very close in appearance to the original U S Royals but I believe that I would sacrifice ride quality and handling with that tire. For a "trailered" or lightly driven car, the Coker tire might be a good selection.
Old 01-18-2014, 04:19 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
For the Diamondbacks, ask them to use Firestone Indy 500 cores. They're a better looking and higher quality tire than the Dayton Daytonas they usually use.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, next project
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
The Following User Says Thank You to ron cozzo For This Useful Post:
Old 01-20-2014, 09:12 PM
DSMTiger's Avatar
Just thought I would show you guys what an original U S Royal Redline looked like. This is an original from my car. The Coker Firestone is similar but there are differences in the sidewall.
ID:	350279   Click image for larger version
ID:	350280   Click image for larger version
