Old 02-03-2014, 05:59 PM
Old Goat 67's Avatar
Originally Posted by boostmaster View Post
My CORRECT divider plates arrived the other day from ILT.
On the package it says it's galvanized and zinc plated. Does this mean I can forgo the green primer?
I would put them in just like that.
  #82
Old 02-03-2014, 06:56 PM
GT182's Avatar
GT182 GT182 is offline
As Charles said. If you keep antifreeze in the system they should be fine. But if you use very little antifeese they will eventually rust. I only said about the primer as my originals look like they have that olive green zinc chromate coating on them. They had to have been coated when they were initially made. Mind you mine are rusty, but not bad enough that I can't use them. You should be safe with them as is.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #83
Old 02-05-2014, 10:12 AM
boostmaster boostmaster is offline
Good news. I will use them as is. This car will be a garage queen and frankly, after this winter, I'm 99.9% sure we'll be heading somewhere warmer (ie: no snow- ever!) here in the near future. Car will run antifreeze and maybe some RMI-25. http://www.rmi25.com/
So, is there any update on the CORRECT Cardone water pump part number yet?
  #84
Old 02-11-2014, 08:49 AM
I was hoping that we might have an update on the correct cardone part number.
Any news?
  #85
Old 02-11-2014, 09:28 AM
Not on my end. No answer from email yet.
  #86
Old 02-12-2014, 11:53 AM
Ok. No Problem. Just checking. I guess I'll wait to see if you post up and maybe check back in a few weeks... (My project is on hold but I want to make sure I get the correct part)
  #87
Old 02-12-2014, 05:00 PM
GT182's Avatar
No answer yet from my contact up there in Philly. As he told me, he has some important things on his plate that must be done before the end of February. So it could take a couple of weeks more before I hear and answer fron him. Besides that, he has to get the people in the Dallas warehouse out searching for the correct pump.
Don't fret... I'm not giving up even if I have to up there and knock on his door at the plant. Hey, maybe they'll give me a ride in their corporate jet down there and I get to go looking for it myself. LOL
Gary
  #88
Old 02-12-2014, 05:28 PM
That would be fun.
  #89
Old 03-21-2014, 05:52 PM
Here is the explanation I sent to cardone earlier.
Maybe it will help you to understand better.
Does that help?
Charles
Was there ever a final determination as to what the gap between the impeller and the plate should be? This one measures 1/4 inch.
Got this core from a friend. Has both original plates and all. Im sending it out to Arthur Gould for rebuild. Its for the 400 that Im building.
I had the one I mentioned earlier in this thread rebuilt. It came out beautiful but the impeller fins were for a 64 and very short. I sold it to a friend building a 64 motor.
  #90
Old 03-21-2014, 06:27 PM
george kujanski's Avatar
My opinion is the gap should be as small as you can make it. Check out Old Goat67's thread about the Cardone pump. He has a really good pic of his assembly.
George
  #91
Old 03-21-2014, 10:06 PM
GT182's Avatar
Still no word from my contact up at Cardone in Philly. The parts store where I hang out for coffee in the morning said they'd call up there and see what they can find out. Maybe that's what it'll take to get them looking.... or a good spark injecter.
Gary
  #92
Old 07-29-2014, 03:35 PM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
I just got my Son's '66 GTO started last weekend. Ive been working on this thing for a couple of years now in my spare time ever since it had an engine fire that did a lot of damage to it. One of the several problems it had on start up was that the water pump seemed to be leaking once the engine got hot & the pressure built up. The leak seemed to be coming from the bottom of the pump, maybe from the hole in the snout. Anyway I may be needing to replace the thing & was wondering if any progress has been made either with Cardone or finding the part number of the right impeller. I have an old pump in the garage with a cast iron impeller but I can't tell if it's the good one or not. Any help on this would be appreciated. Jerry.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
  #93
Old 07-29-2014, 03:59 PM
arbys's Avatar
arbys arbys is offline
I'll bet if took a picture of it with a straight edge laying across the top either Gary or Charles could inform you as to originality. If it's original I would contact Gould pumps in NY to rebuild it.
http://arthurgouldrebuilders.com/about/
  #94
Old 07-30-2014, 10:24 AM
Satyr1966's Avatar
I'll try and get a good picture of the pump I've got & the part number of the impeller. I'll post them later this week if I can remember to get out to the garage with a camera. They say the memory is the first thing to go & I forget what the second thing is. Jerry.
  #95
Old 07-31-2014, 11:19 AM
Satyr1966's Avatar
I took some pictures of the old water pump I was hoping to rebuild if it has the right impeller. It looks like it was leaking from the hole at the bottom of the snout. Anyone else have that problem? I think that's where the one on my Son's car is leaking from too. I'm looking for someone in the know to tell me if my impeller is the right one to use or if I need to look for a better one. Thanks in advance for any help! Jerry.
  #96
Old 07-31-2014, 11:29 AM
That appears to be an original pump. Is there a stamping on it?
I had great success with Aurther Gould. Im running one they rebuilt in my car right now. They do it fast too. Highly recommend it.
  #97
Old 07-31-2014, 02:06 PM
Satyr1966's Avatar
I took pictures of the markings but they don't seem to want to load. The impeller looks like SM5 stamped over 9793124. The pump itself has a GM2 stamp & a part number of 9782482. Jerry.
  #98
Old 07-31-2014, 03:04 PM
Thats a factory pump alright. Rebuild it then get the divider plate from Inline Tube.
  #99
Old 08-01-2014, 08:23 AM
That is NOT a factory pump.
This is.
http://forums.maxperformanceinc.com/...d.php?t=752911
Send your pump to The Flying Dutchman. http://www.fdrbp.com/
He has the correct impellers to put on them.
Charles
  #100
Old 08-01-2014, 08:32 AM
67Twistytee's Avatar
67Twistytee 67Twistytee is offline
It may still be worth rebuilding Charles given the cast impeller height in that photo. As stated here, good pumps are hard to find. Don't order a Cardone Jerry. I just tried this route from Rockauto and it came with a stamped impeller. I ended up using a reman from Napa that looks similar to your photo.
Another rebuild source (from Charles) - the Flying Dutchman
http://water-pump-rebuilders.com
Andy
North Carolina
1967 GTO SG over Parchment / mom original owner / sold in '78 / found 35 years later
