Old 02-02-2014, 06:18 PM
VAB5 VAB5 is offline
Default Ames Firm Ride Rear Springs
Has anyone used the Firm Ride Rear Springs from Ames Perf? If so, do they raise the rear ride height any? How firm is firm?
The springs on my '69 LeMans are original, and they have seen better days. I'm looking for a bit of a firmer ride, plus a little less sag in the butt.
Paul
Old 02-05-2014, 04:53 PM
I tried a set many years ago, I ended up removing them since they made the car sit too high. There was no noticeable change in ride characteristics between them and the regular springs. I suspect they are just cargo coils designed originally for towing and encyclopedia salesmen.
Old 02-05-2014, 05:07 PM
marxjunk marxjunk is offline
whats an encyclopedia?
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 02-05-2014, 07:13 PM
How much higher was it sitting? I'm looking for a little lift from my saggy stockers.
Old 02-05-2014, 07:45 PM
a paper version of Wikipedia that had researched facts instead of anonymous opinions.
I don't remember exactly but it was at least 1" higher than stock. i.e. if new stock springs gave you 8.5-9.0" (bottom of rocker molding to the ground) these were 10+" and typical tired stock springs are 7.5" or lower.
The factory R&H springs added about 15% spring rate but they were shorter so the ride height was unaffected. If you looked at NOS springs in a box the R&H version are about 1.5 to 2" lower than the regular ride springs.
Old 02-05-2014, 07:50 PM
a paper version of Wikipedia that had researched facts instead of anonymous opinions..
potassium
Mark..
The Goat whisperer
Old 02-07-2014, 05:27 PM
potassiums periodic table letter is K..so when i said potassium..i also said K...in a nerdy way...i crack myself up..
Mark..
The Goat whisperer
Old 02-08-2014, 12:59 AM
android 211 android 211 is offline
I put a set of Moog Cargo Coils I got off a junk '67 Lemans HT on a '67 Lemans convertible and the ride height was exactly stock and it was very firm.
Old 02-08-2014, 09:43 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
android 211 how do you like the springs? Can you post a few pics of your car at different angles?
Thanks!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 02-09-2014, 04:36 AM
http://ultimategto.com/1967/67_00153_1.jpg
Its not mine; it was a car I helped a friend with. I robbed my stash to get it on the road. He painted it at home. (ex bodyman). 45,000 mile Kansas car sat from 1979 to 2004. I know what kind of springs they are because the tag was still on them. The fronts were "Moog Heavy Duty"
Old 02-10-2014, 03:35 PM
GT182's Avatar
GT182 GT182 is offline
Air shocks will firm up the ride and raise the rear too. Far easier than changing out the rear springs. But that's just my . I'm running airbags and airshocks on the rear of my 66. I love the ride and the way it handles with the 1 1/4" front swaybar added.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-10-2014, 08:50 PM
Gary, I've considered air shocks, but as I understand it, they take the pressure off the spring mounts, which are reinforced and built to take such a load, and put it on the shock mounts, which are not built to take the load. It can lead to breaking the shock mounts.
Anyone with more input?
Old 02-11-2014, 08:57 PM
gtohunter's Avatar
gtohunter gtohunter is offline
Moog Cargo Coils X2 ...settled down about an inch after awhile, but sit's just right as far as i'm concerned. Fairly soft ride, but will stand some weight without squatting too much.
Jimmy M
68 GTO
Old 02-23-2014, 01:56 AM
tryconcom tryconcom is offline
Thumbs up Ames firm ride springs
I bought a set approximately 2 years ago for my saggy rear ended GTO. It brought the butt end up approx 1/2 inch above the rear tire, improved the ride and handling measureably and the car looked great. I would highly recommend the addition of a set of these springs.
