Old 03-18-2014, 10:21 AM
Chris Uratchko Chris Uratchko is offline
Default Is anyone making 1000 hp, naturally aspirated
With a pontiac on straight 93 octane pump gas?
Uratchko Racing Engines
www.ure-racing.com
Old 03-18-2014, 10:33 AM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
I dont think there are any at that mark, on pump gas, unless it's like the pump gas drag's 98 octaine pump gas from a drum.
Aleast none that post it, but I have been wrong before.
I would love to know about them, if they exist.
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
Old 03-18-2014, 10:34 AM
Interesting...
www.ure-racing.com
Old 03-18-2014, 10:44 AM
john marcella john marcella is offline
1000 hp pump gas is in the bag!
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 03-18-2014, 10:48 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
I wish I could come up with some high quality questions to pick your brain a bit.The pump gas thing just isn't my thing but I think it's freakin sweet if someone has done it in the Pontiac world!
And don't worry about the "bashing" the way I view it this is nothing more than some bench racing/chit talking at the track(among family members)that just happens to be on The internet.
I'll say this we all like our pontiacs and it's obvious the stupid amount of time we spend playing with them kinda makes us proud of them.......as for the direction you take a thread or your comments on a thread I personally will value your statements and I hope to learn more from you.So thanks for hanging out over here for a bit!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
Old 03-18-2014, 11:51 AM
dci dci is offline
I don't think that anyone is even close with real 93 octane pump gas, but It would be way cool to see someone try.
Chris what do you think it is going to take? Not trying to put you on the spot. Just trying to get some idea's. I know you work with allot of different brands and could probably come up with a Chevy or Ford combo that would.
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Old 03-18-2014, 11:54 AM
mike leech's Avatar
mike leech mike leech is offline
He will come up with a Pontiac combo that will. mark it down.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 03-18-2014, 12:04 PM
dci dci is offline
I really hope so!!!! We need the engine builders and racers from the other brands to start coming over to help us traditional Pontiac hopefuls. If that starts happening, our level of performance will expand tremendously. It's who you hang out with that determines your destination in life. Good or Bad!!!!!
Don Johnston
330-850-5050 shop
330-628-3354 cell
Old 03-18-2014, 12:14 PM
I think it's obviously going to take cid. The bigger the better. I'd probably want 540 min.
Then it's down to the rest.... proper open and close events and a lot of valve action.
I think I need a 480+ cfm head.
The more I think about it the more I'm starting to like it better than a BBC for this application. I have runner length on my side with a Pontiac where the conventional bbc does not. Just some initial thoughts.
www.ure-racing.com
Old 03-18-2014, 12:22 PM
mysticmissle's Avatar
Slow bird on here has be over 900. Not sure how much over but a 511 cubes and 4500 ish kre HI ports rubbed on by barton
Car has backed up the dyno numbers too
Old 03-18-2014, 12:32 PM
Sweet any pics or other details? This was 93 octane?
www.ure-racing.com
Old 03-18-2014, 06:45 PM
cfmcnc cfmcnc is offline
892HP with a Tiger at 440CFMs,The newest port should get to 4 digits on pump petrol.Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
Old 03-18-2014, 08:08 PM
slowbird's Avatar
slowbird slowbird is offline
Ran 9.05 @ 147.5 weighing 3380lbs, 496ci HP head flowed 420ish. A 540ci and 480cfm Tigers or ProPort heads and you're there. It's completely doable just needs to be done.
Old 03-18-2014, 08:36 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Does PUMP = E85?
Old 03-18-2014, 08:49 PM
mike leech's Avatar
Originally Posted by ponjohn View Post
Does PUMP = E85?
no.
EHTTFMF!
Old 03-19-2014, 05:45 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
What would the cam specs approximately look like? I have a fresh built 537 with 440-450 cfm tigers, current cam is 264-270 790 lift, 12 to1 compression 185 cranking compression. I feel like I am a little under cammed but does drive good on the street.
Steve
Old 03-19-2014, 05:54 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Steve
Wow! That's one hell of a street car
Would love to drive that s.o.b or maybe not
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 03-19-2014, 07:34 PM
J.C.you's Avatar
J.C.you J.C.you is offline
what kind of numbers did Kaase do with his EM pump gas poncho years ago?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 03-19-2014, 07:35 PM
67Beast's Avatar
67Beast 67Beast is offline
I am over the 4 digit mark NA but not pump gas. However compression is at 13.5 : 1, 535 CID.
Member of the NA 4 Digit Club!
Old 03-19-2014, 07:49 PM
SLICK1 SLICK1 is offline
Thumbs up
Nice to hear that you've considered the possibilities and have a Goal in mind, best of luck, and keep us informed!
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
