Old 03-26-2014, 11:20 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Originally Posted by RA462 View Post
I make my own but it looks like this one on ebay
http://www.ebay.com/itm/1982-1987-G-...155bcd&vxp=mtr
I also picked up one of these chrome moly cross-members last year.
http://www.maliburacing.com/iceman/
You don't have an extra 2+2 front end laying around do you?
Todd, thanks for the links. That driveshaft safety loop is just what I'm looking for. The chrome moly crossmember looks to be a nice weight saver, unlike some other big heavy after market ones. I don't have an extra 2+2 front end. Back in 87, G.M. had to replace my 2+2 nose piece. Because the upper corners next to the top of the fenders were cracking. Now I wish a had tried to get that nose piece from the dealership.
Old 03-27-2014, 07:59 PM
Now that I've got the tranny crossmember done. I can route my rear brake line. Last year I broke down and bought a hydraulic flare tool. Anyone who has used a manual brake flare tool knows how difficult it can be making the correct flare. I figure after the third car the flare tool will have paid for itself. Also as is the case with this project. I can't use a stock brake line kit and expect it to fit. Especially with some of the custom frame work that I did. Here's a photo of the flare tool kit and a finished brake line flare.
Name:	2+2 frame brakeline 005.jpg
ID:	358413   Click image for larger version
Name:	2+2 frame brakeline 010.jpg
Old 04-22-2014, 06:50 PM
I just finished putting in the the fuel pump and a pre pump filter. I have also added a fuel shut off at the tank. The first time I went to change a pre pump fuel filter, I didn't have a shut off valve. Needless to say it only took one time for me to understand the benefits of a fuel shut off valve.
Name:	aero coupe fuel pump 002.jpg
ID:	361231   Click image for larger version
Name:	aero coupe fuel pump 003.jpg
ID:	361232   Click image for larger version
Name:	aero coupe fuel pump 001.jpg
Old 09-28-2014, 07:58 AM
Been a while since I've posted anything on the wife's aero coupe. I have been able to pick at it some. Summer's over, maybe this car can see pavement before the years up. I have run some fuel and tranny lines. I pirated my Moroso fuel log off the 65 to complete this system. I've also moved the oil filter higher on the firewall. I was worried that it was to close to the front tire and could make contact.
Name:	fuel log aero coupe 001.jpg
Old 09-28-2014, 08:14 AM
I have quick release connectors on my tranny lines for the 65. I feel they are worth the added cost. I used Biondo connectors on the 65. I elected to go with the Jiffy-tite connectors on the aero coupe. The Jiffy-tite connectors are more compact hopefully they are as durable as the Biondos.
Name:	Crsvl kruse Sept,2+2 015.jpg
ID:	377408   Click image for larger version
Name:	Crsvl kruse Sept,2+2 016.jpg
Old 09-28-2014, 12:12 PM
pontiacjeff pontiacjeff is offline
Hey Mike, there is a 2+2 front header panel on a scrappy 85 GP in a pull-a-part here in Atlanta. I'm going back tomorrow (Monday, 9-29), do you want me to grab it for you? It's a nice piece would be a good spare. I have a picture of it, but it's on my phone and I can't upload it here, I could text it to you if you send me your phone number privately.
Jeff Ianitello
  #287
Old 09-28-2014, 06:18 PM
Jeff, I appreciate the heads up. I'll private message you. thanks Mike
Old 10-07-2014, 04:30 PM
I ran into an issue with my rear upper adjustable control arms. I adjusted the arms to their smallest size and couldn't get my initial pinion angle even close to 0 degrees. I did put a 12 bolt rear in the car, so I figured that the mounting point was different. I measured the factory upper brackets and they measured 11 1/4". That was about the middle of the adjustment for the adjustable arms. So they were correct for the G-body. The design of the adjustable control arms allowed me to shorten them without being a major operation. I removed 1 1/2" from the threaded tube. I then had to locate a shop with a 1/2" reverse tap. Now the upper control arms will work.
Name:	Crsvl kruse Sept,2+2 012.jpg
Old 10-07-2014, 04:38 PM
The pinion angle should be approx 4° negative (down) when measured off/compared to the driveshaft. This is the ideal angle to allow for rear axle wrap-up.
Jeff Ianitello
  #290
Old 10-08-2014, 09:22 AM
Thanks Jeff that's good info. I now have enough adjustment in my control arms to be able to reach 4 degrees negative.
Old 10-08-2014, 10:23 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Default Cool build
I just found this thread, It's real cool. My best friend is doing an Aero too, 400 Pontiac, 4 speed. did a frame off. He used a Grand National rear they are stong and bolt in.
Very cool build I will watch the rest of it and share it with him. Will you let the wife drive it when its done? LOL
  #292
Old 10-09-2014, 11:09 AM
Alvin's Avatar
Alvin Alvin is offline
Congrats to your talents, vision and progress Mike!
I just reverse read this (your) thread from page 15 back to your start @ pg 1. Impressive on many levels, including the crusty Aerocoupe that you started with.
Looking forward to the final shakedown and completion pages.
  #293
Old 10-09-2014, 01:55 PM
Nice to hear that another Aero Coupe is being upgraded. Sneak us a picture or two of it. We all love pictures. And will I let the wife drive it? Of course I will.
Old 10-09-2014, 02:04 PM
I appreciate the compliments for sure. I'm now able to put some time back in the car. She's getting pretty close. I'm hoping to run some power through her pretty soon. I hope the wiring work and repair I did doesn't slow me down. I ordered a Hurst automatic shifter. It's been on back order for a month so far.
Old 10-09-2014, 03:21 PM
JSPONT's Avatar
Next time I'm over there Ill take some photos!
  #296
Old 10-10-2014, 12:29 PM
I'm putting the ignition box and coil in the glove box. In place of the glove box insert I put a flat piece of aluminum. I welded a couple small tabs to the glove box support area and fabricated a bracket to support the aluminum next to the firewall.
Name:	10 3 14 008.jpg
Old 10-10-2014, 08:02 PM
Here's the ignition box and matched coil mounted in the glove box. The box is one of the early Summit boxes. I believe the box is actually a Mallory Hyfire. This unit has worked fine for me when in my 65.
Name:	aero coupe ignition 002.jpg
Old 10-11-2014, 09:29 AM
Transporter Transporter is offline
Glad to see you are getting close Mike, it's gonna be a great looking car, think it will get at least a test session in this year?
Don't even ask about my Tempest, got waylaid on some other projects, lol
  #299
Old 10-11-2014, 01:50 PM
Good to hear from you Stan. Same here, other projects getting in the way. Gotta take advantage of the open windows when we get them. Doesn't look good for running on one of the local tracks before they close for the season. But I do have the car insured and tagged I'd like to think that I can at least street drive her before the years up. The Hurst shifter is on back order right now. We'll see if it gets shipped on the projected ship date. So far two missed dates. Hopefully the winter season will let you get back on your Tempest.
Old 10-13-2014, 04:17 PM
Having the ignition coil in the glove box requires a firewall connector for the coil wire. Here's what I put in. Next will be the Lokar tranny tube.
Name:	2+2 firewall coil plug 002.jpg
ID:	378830   Click image for larger version
Name:	2+2 firewall coil plug 004.jpg
ID:	378833   Click image for larger version
Name:	2+2 firewall coil plug 005.jpg
