I bought a set of the repo stacked gauges off Ebay a few years back and I have got them installed and all of them are pegged. The lights for the pods all work well and all all dash lights work. Fuse for gauges is good. I ran a wire from the ground on the back of the WT gauge directly to the body..... no change
Gas Gauge * New Sending Unit * Checked all wiring and grounds * Grounding out the tan wire in the trunk does not make it move * Test light attached to tan wire and ground has no power * Sometimes with key off the needle will drop to half tank otherwise pegged to the right Oil Pressure Gauge * New sender unit * Blue Wire has power at sending unit unit * Gauge is and has always been pegged to the right Water Temp Gauge * New sending unit * Disconnecting alt has no effect * Pegged to right This was supposedly a new set with the circuit board, tach, and gauges. Nothing appeared to be burned or even installed. Is there a way to check the gauges without pulling them back out? Any help appreciated
73 Trans Am Red/White #'s match 4spd...... sold 69 Firebird 400 conv #'s match AT Blue wht/wht 06 Vette conv Red/Red/Blk |
