WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Exterior Tech
93-02 Exterior Tech Hoods, Stripe kits, T-Tops, Convertible, Ground effects, etc...
Old 05-13-2014, 04:38 PM
brad cox's Avatar
brad cox brad cox is offline
Default 96 firebird to 98-02 trans am
Trying to figure out what all I would have to change to go from a firebird to the newer trans am look. I know I will need a hood and nose but what else would I need. any help would be appreciated. Thanks
Old 05-14-2014, 11:21 AM
eric_cspan's Avatar
eric_cspan eric_cspan is offline
Administrator
The hatches changed, doors, bumpers, tail panel.
You'd need to do a lot. Might just be easier trading.
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
Old 05-14-2014, 02:31 PM
brad cox's Avatar
Ok thanks
Old 05-14-2014, 04:53 PM
David Holmberg's Avatar
On a Trans Am, if you changed the front end and the tail lights, no one would notice the rest on the outside.
Old 05-15-2014, 09:28 AM
eric_cspan's Avatar
Administrator
True. Really the hood and tail lights are the giveaways
Old 05-15-2014, 12:40 PM
brad cox's Avatar
Do you think it would be worth it to buy a body for about 150 dollars all it is the body I would need to buy everything else including wiring,dash,rear end engine trans pretty much everything I also plan on making it a drag car like the engine will be an ls and the rear will be a built 9 inch
Old 05-15-2014, 04:02 PM
For a drag car it would depend on your abilities. The Engine/trans/rear would need to be replaced anyway. The wiring could be very easy or hard depending on what you can do. The interior would be gutted in a drag car anyway.
The trade off is if you buy a full roller you'll have more to work with, and parts to sell off. That could be a good or a bad thing.
Good luck, 4th gens make great drag cars.
Featured Vendors
Advertising Info
