#101
Bob, have you looked at the block to see when it was cast (probably Kxx7)? '79 W72 engines were trying to use up the rest of the blocks sitting in inventory. Repop decals vendors must not know the applications.
Thanks HFR, I had hoped you would weigh in on the air cleaner. I haven't checked the block date code. No excuse on that one. The heads were Feb '78 and the intake Dec '77. I'll check the block this evening.
#103
![]() Hint: Most manuals will tell you for Blower motor replacement to "cut out the circular stamped recess for blower R&R..." Or something Like that. Don't do it! I'd only replace it if it is inop, and if needed do the same procedure used for htr core...IIRC, may have to remove squirrel cage inside fender recess to remove...?
#104
My heater core went out when the car was 18 months old.
![]() If anyone out there finds a Y88/WS6/W72 auto with a patched seam in the pass side wheelwell, it might be my old car. JK fixed it for me and made an L cut to get to the bottom clamp rather than remove the bottom bolts. Also from the factory, if you lifted straight up on the drivers side rear spoiler cap it would lift off. All you had to do was put it back and it stayed, never came off on its own. Strange Y88 things.
#105
HFR - the casting date on the Block is H237 - August 23. 1977. Almost a 6 month spread on block and heads. The block VIN matches.
#106
Mission creep has arrived....My family and friends hate to help me with anything because upon the completion of any job or task I always say "Just one more thing...",
Well maybe a few more than one. My Pal Dave was feeling a little left out of the heater core project so he came over tonight and we did a few more things. The rear sway bar is off the car for bead blasting and bushing replacement. It's pretty cool - the remnants of the factory sticker is still on the rear bar. We also got the dash bezel removed as Randy Combs is putting a new, old one together for me. The center dash vents were busted up and new replacements are now in place. I'll try to yank the gauge lenses sometime this week and polish them to remove the scratches. Lastly, we removed one section of the body side molding. It sure looks like it was installed at the dealer based on the aging of the attachment screws and the visible paint fading. Happily, at least on the section removed, it was attached so securely that the paint was not scratched underneath. Hopefully this will hold true on the longer sections of molding. Regardless, there are screw holes so new stick on molding will be installed. If anyone wants the original dealer installed molding it will probably be available. Here's a few pictures... ![]() ![]() ![]() ![]() ![]()
#107
I'd love to know if some of the 79's shared the same casting date - old stock.
Somebody's finger needs some Bactine!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#109
It's funny how the fuel/volt guage lens always seems to "fog" and not the main cluster lens.....
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
#110
The body side molding has left the house.....
Well, the dealer applied body side molding has officially been removed. Gone, finished, abolished from all future duties. It's amazing how little damage was done to the finish by this molding. After removing it, I went through a two step buffing process to remove the built on grime, residue and abrasions, and there is almost no trace of it having been on the car. Almost is the key word. What remains are the multiple 3/32" screw holes....Were it not for these I would be home free. I really like the way it looks without the molding, but molding it must have to cover the holes. I'm looking forward to getting the new factory style molding applied, but first the heater core has to get finished so the fender can be buttoned down, and the hinge roller needs replace on the drivers door to make sure the alignment doesn't change. I've got several trips over the next 10 days so it may be a while. we'll see... ![]()
#111
No doubt, You'll enjoy this next part: instead of screws ours is installed w pop-rivets! ![]() |
#112
DAMN!
On the bright side, your doors, fenders & quarters aren't all dinged and chipped from years of doors banging into them. There were 8 spots on my 79 that had to be messaged by the paint-less dent guys!
#113
Alvin - they are yours at no charge. I appreciate all the help you have provided and am happy these parts will find a good home. PM your address and I'll get them moving your way.
#114
I would venture a guess that some later 78 W72's had Jan '78 castings...be nice to know... NO '77 engines were used in 79 that I have ever heard of. In '78 there was 4,112 Std shift W72 made ( red book)
" Long may we DRIVE !" |
#116
What's the "Red Book"?
#117
#118
Or, an original...
#119
If anyone wants a copy of a page or 3 let me know...
#120
Now don't go getting all excited........The Red Book is a decent reference guide,but there ARE some errors.......
Off the top of my head,some of the 72 #'s are just transposed from 71....AND... 4112 stick 78 Trans ams for 78 is NOT the gospel....according to John Witzke
