Old 09-12-2014, 12:24 PM
Peter Tillman Peter Tillman is offline
Default Manual antenna 1966
Hi,
I am about to install a manual antenna on the right front fender on my LeMans 1966.
I have an original style antenna with the correct base, designed to be attatched to the fender flange with a small screw.
I understand that I have to remove the fender, but I cant find any information of the correct location of the holes.
Can anyone help me with this?
If it is hard to get exact location or a template, I would apprechiate a few close up photos from a correct installation.
Best regards,
Peter Tillman
Old 09-12-2014, 05:35 PM
BOB VIDAN BOB VIDAN is online now
You don't need to remove the fender if you have the right adapter. Open the door and you should see a fairly small drilled and taped hole, that's what you're wanting.
Practicing social distancing for 65+ years
Old 09-13-2014, 03:22 AM
OK, thanks
The problem is that I have to drill a hole in the upper skin of the fender for the base and it has to be in the correct location, otherwise the antenna would be in wrong angle
/Peter Tillman
Old 09-13-2014, 07:27 AM
Jeff Hamlin's Avatar
Don't have any loose fenders at the shop, but these may help.
The Antenna body will dictate the location based on the mounting tab location.
Once you get a center hole I would then use a step bit to slowly enlarge the hole.
Gasket & escutcheon allow for some hole "adjustment"
Old 09-13-2014, 07:59 AM
Thanks Jeff!
This will make it a lot easier.
Regards
Peter Tillman
Old 09-13-2014, 05:44 PM
ChuckG's Avatar
ChuckG ChuckG is offline
I used one of these to make the hole and it cuts a very clean and neat hole:
Greenlee 7211BB-1/2 Slug-Buster Knockout Punch Unit, 7/8-Inch
