73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 09-19-2014, 04:34 AM
Default Need to know ??
I just got a carb that by the numbers I know it's a 73 Pontiac that came from a 400 or 455 & an auto. The number is 7043262. I can't seem to find this number in my carb CD. I have a CD that has almost everything you woud want or need to know about carbs but when I punch in tis number to find out what it belongs to it comes up can't find ... The number by the break down is 73 Pontiac with an auto but I need some one to verify this for me & tell me what It may be worth. I have it in my card cleaner right now to get it nice & clean but need some info on what it's worth. Thanks .
Old 09-19-2014, 09:24 AM
77 Canamman's Avatar
1973 455 Auto 49 state
About $125 max. They are a very common carb.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 09-19-2014, 10:52 AM
Try my site:
Carb Number Search
Old 09-23-2014, 01:31 PM
Alvin's Avatar
Alvin Alvin is offline
Thumbs up
Try my site:
Carb Number Search
TY for the reminder heads up, worked like a champ with the OP carb number.
Search result here:
You Searched For:
Part=7043262
1 Matches Found (displaying 1 to 1)
Part No. Year BBLs CI Trans Make Model Notes
7043262 1973 4 455 A PONTIAC - -
Old 09-23-2014, 11:23 PM
Grand73Am Grand73Am is offline
Got one just like it sitting on my shelf.
Steve F.
Old 10-23-2014, 03:51 PM
Kbars CanAm Kbars CanAm is offline
Default Looking for a Carb
My mechanic has advised me I should start looking for a carb for my Can Am. He rebuilt the present one when I bought the car 7-8 years ago. He said it is worn out he has babyed it along. Anyone have a good one for sale for a Can Am? Maybe look on e-bay and give me the number of one that is on there for sale that will work. I know nothing about this kind of stuff, so any help is appreciated.
Old 10-23-2014, 04:31 PM
Is this the original carb for the car?
Might be better to have Cliff Ruggles check it out and see if it's rebuildable?
Old 10-23-2014, 10:06 PM
The throttle shafts commonly wear, and bushings are available to remedy this. The only thing that makes a Q-Jet unusable are stripped inlet threads, and warped main bodies due to over tightening.
Old 10-24-2014, 11:17 AM
carbking's Avatar
carbking carbking is online now
Generally, stripped inlet threads are repairable.
(1) 1/64 inch oversize tap and fitting
OR BETTER
(2) installation of a heli-coil
What does generally ruin the body is when Dr. Goodpliers (the evil twin of Mr. Goodwrench) installs one of the self-tapping fittings; as the self-tapping fitting removes so much metal that insufficient metal remains to do a proper repair.
Jon.
Old 10-24-2014, 04:30 PM
Default Carb
My mechanic has been working on Pontiacs since 1975 having got his first job out technical school working at a Pontiac dealership in Littlerock, AR. He worked on my first Can Am I bought new in 1977 and this is my second one and is the original carb. He has worked on many Trans Am's and has rebuilt a many a quadrajet carb over the years and knows a lot about them. So when he says I need to be thinking about finding another I take his word for it. However, I will print this out and ask him about these. The main complaint I hear him say is that he can't get the car to idle the way he would like it to and it cuts out when you jump on it from a dead stop. Thanks, Kbars
Old 10-25-2014, 08:38 AM
The idle fuel feed tubes must be removed during an overhaul. A lot of crap builds up in the idle circuits, and they can't be properly cleaned without removing them. Also, the size of the tube's orifice is pretty small for a '77, so opening them up a couple of thousands of an inch will give you more idle fuel. The mixture screws will still allow for a proper mixture. Cliff Ruggles book goes into great detail on how to do this.
Old 10-25-2014, 10:03 AM
Would putting larger idle feed tubes in the q-jet help acceleration at all? I rebuilt a 76 Pontiac q-jet and put it on the Pontiac 350 in my 75 Lemans. I did pull the tubes, but put the stock size back in. It's a bit sluggish on take off, and other than being an original low powered engine with 2.56's, I think it should still be a little snappier on takeoff. Just wondering what the tubes affect. Otherwise, the idle is great and it runs fine once it gets going.
Steve F.
Old 10-25-2014, 12:11 PM
Larger idle fuel feed tube orifices might help an off idle lean stumble. Once off idle, the main metering circuits come into play. The power piston spring, APT, and metering/jetting take effect.
Old 10-25-2014, 12:17 PM
Okay, thanks!
Steve F.
Old 10-30-2014, 10:25 AM
I have been told that the quad jets if there has ever been a backfire that this causes a warping of the choke plates and throttle plates. I don't think those can be replaced can they? And when this has occurred then you never can get the carb to idle right. I am told this is what has happened to mine. If I am misunderstanding, please explain it to me.
Old 10-30-2014, 10:08 PM
Never heard of that. Warping of the air horn and main body is common when the tightening sequence isn't followed.
Old 12-23-2014, 05:29 PM
Default Looking for Pontiac quad jet carb for my Can Am
I am looking for a q-jet carb for my Can Am. Let me know what you have and how much. Even if it needs to be rebuilt is OK as long as in good condition. Thanks, Kelly You can e-mail at [email protected]
