Old 04-06-2017, 04:21 PM
I use that same color for most of mine also.
Old 05-11-2017, 09:22 AM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Ta_man, have you been running 1.65's on the intake and exhaust? Theres been talk on this site the with good flowing heads, 1.65 may be too much on the exhaust side especially with a split pattern cam(like OF) . Something about over scavenging? May possibility pick up with 1.5's on the exhaust?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 05-11-2017, 01:47 PM
ta man ta man is offline
It may be possible..but I'm pretty sure Dave has done enough dyno testing.I trust his judgement when he is the one porting and setting up the heads and supplying the cam.
Old 05-18-2017, 03:55 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Do you know what springs he's using? Mine have a polished, smaller diameter spring than the 99893's that have similar tension but are much lighter in weight.
Dave said he's had excellent results so far. I only have 4 dyno pulls on mine but there was no sign of valve float.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 05-18-2017, 06:03 PM
I'm not sure,he did mention lighter retainers and keepers.
Old 05-18-2017, 08:21 PM
Steve C. Steve C. is offline
Some might be interested...
Exploring Rocker-arm Ratio and Cam-phase Tuning – Project Pure Poncho
http://www.hotrod.com/articles/hppp-...-phase-tuning/
Brings up the subject of less rocker ratio on the exhaust side. Keep in mind here Pontiac factory iron heads are in use. The exhaust-to-intake flow ratio of aftermarket cylinder heads might be a all different ball game.
Old information here:
Old 08-01-2017, 09:57 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Wonder if Dave would advocate using beehive springs?
Old 05-11-2017, 11:51 AM
71 T/A 71 T/A is offline
What are specs on OF2?
Old 05-12-2017, 10:08 AM
leeklm's Avatar
leeklm leeklm is offline
Dave is not publishing full specs. On the surface, it is the OF with higher lift, and slightly more duration.
Sent from my XT1585 using Tapatalk
Old 05-11-2017, 06:33 PM
My ported round port E heads liked 1.8 on the intake and 1.65 HS (1.71 actual) on the exhaust the best.
Old 05-11-2017, 07:14 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Hi Skip, what happened when you tried more ratio on the exhaust?
Go fast, see Elvis!
Old 08-01-2017, 12:07 PM
Paul I did not see your question back then-I only bought enough to do the intakes as they are pricey. I did have the 1.65 HS on both intake and exhaust and it picked up with just the 1.8s on the intake.
Old 08-01-2017, 01:29 PM
hal101's Avatar
hal101 hal101 is offline
good luck sounds like you are dooing great
Old 08-02-2017, 08:45 AM
I think 10.78 at 125 and possibly better than that.
Old 08-02-2017, 09:04 AM
leeklm's Avatar
You should be close. I need to add more weight to keep my boat at 11.5, even in marginal air!
Old 08-02-2017, 01:00 PM
71 Goatman's Avatar
71 Goatman 71 Goatman is offline
ta man, I noticed you are running a nice cast aluminum valley pan. Just in the process of freshening my 462 with some KRE heads, after seeing yours am thinking of getting one. Do you run a PVC with that valley pan or did you connect it somewhere else?
71 Goatman
Hot Rods & Horsepower.......A diease for which there is no cure.
71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
Old 08-02-2017, 01:11 PM
AG's Avatar
AG AG is offline
How are you allowed to run sub 11.50 w/o the required safety equipment?
Old 08-02-2017, 01:22 PM
Easy tech on testntune nights.There are usually quite a few newer cars especially the Mopars running in the 10's.I do have a SFI balancer,flexplate,proper lugs on the axles.I've been torn between putting a rollbar in this one or find another roller that is setup.
Old 08-02-2017, 06:35 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Engine looks great, you are almost there!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 08-03-2017, 01:52 PM
71 Goatman's Avatar
Thanks take man I am going to pick one up, like the idea of not bending, looks great too!
71 Goatman
