Old 10-31-2014, 10:26 PM
Brewster's Avatar
Brewster Brewster is offline
Kinda late in duh season to be thinking about eggs, right. Went through three water pumps before getting that date dead nuts on. Engine will be on the dyno with Dan to confirm and adjust. Will post final numbers upon receipt.
Its the car thats been neglected due to work but hopefully I can get something done over the winter???
  #2222
Old 11-01-2014, 06:25 AM
Held for Ransom's Avatar
I looked at the pictures and couldn't read the date code. Were the ones produced on that date better than all the rest?
  #2223
Old 11-01-2014, 07:14 AM
RamAir's Avatar
RamAir RamAir is offline
I'm late to the water pump date code party. My understanding is it's a Jillian code and application is determined by the casting number.
  #2224
Old 11-01-2014, 08:17 AM
165th's Avatar
165th 165th is offline
There may have been different manufacturers, and one using Julian and one using month/day/yr. Here's the pump for Adrian. A072 There's another member here who has a March built TA with the same date coded pump.
Hmmmm..... I better get this pump painted before November 22
Name:	A072 waterpump.jpg
  #2225
Old 11-01-2014, 08:25 AM
165th's Avatar
Just kidding... there's plenty to do but painting the engine isn't one of them,
Name:	adrian 110 IMG_4748s.jpg
  #2226
Old 11-01-2014, 09:55 AM
And what does the date code read now that everything is bolted up? It's the same, you just can't see it. Which is why I found it funny one would go through three to finally find thee one to use. Never noticed the Julian date coding on a water pump. Maybe earlier than '72?
Pictured are '72, '73 and '75 water pump codes. Can't find the picture of the '74 one.
ID:	380547   Click image for larger version
ID:	380548   Click image for larger version
  #2227
Old 11-01-2014, 11:39 AM
Brewster's Avatar
Its a thing I have and I am seeking therapy. Looking good Greg and sorry I'll be missing that show. Hunting is more important that time of the year. Wish you the best though!
HFR, what would be the correct two letter code for the early build Power Steering Pump??
  #2228
Old 11-01-2014, 12:02 PM
Brewster's Avatar
So what are the correct application for these two then???
ID:	380562   Click image for larger version
  #2229
Old 11-01-2014, 01:55 PM
Dates don't tell the entire story. Gxx0 and later dated '71 waterpumps were the "138". the 138's were cast up into the end of Dec poss early Jan of '72 and also used on many early to mid '72 engines. I started pulling original "138"s in the early 90's, have a good stock of cores and have had nearly two dozen rebuilt over the years. The first " 296" casting waterpumps were cast in Nov of '71, there seems to be some overlap as both "138"s and "296"s were both being cast for aprox 2 months. The "296" has a different bearing in it and required a different cartridge rebuild kit than the earlier "138"s and "124"s. During the '71 model year, Pontiac put out a service bulletin focused on introducing these cartridge rebuild kits. The cartridge rebuild kits never made the master parts books, have ck'ed multiple sets dated in '71, 72, and 73. Some dealers ordered these kits & their service depts used them, others preferred to source new GM or rebuilt pumps. One local rebuilder I do biz with with had a booming business in the early 70's with many of his company's pumps going to new dealers. Little need for the cartridge rebuild kits today, though it would be nice to have extra correct impellers.
On the "296" casting pumps, there are several different cosmetic styles, both the small casting number style and the big casting number style. In the attic, in it's replacement's GM box, I have the original pump off my early '80 turbo SE. Replaced it in 1985 with a new GM pump I sourced from local dealership. the new GM pump that is still on the car today, has the Julian style dating. the original pump with under 25k miles would have made it many thousand more miles, if I was not so ignorant, getting carried away with running the alt belt so tight after I removed the a/c brackets and swapped to a two groove pulley.
In examining thousands of original Pontiac casting waterpumps since I started pulling them as specialty cores in the early 90's, what I've deduced on the "296"s, the very last versions that Pontiac central foundry cast were all Julian dated. Before that, from the first original use "296" casting pumps, all the way through the '70's into those early '80 builds like my '80 turbo T/A, the dates were alphanumeric. Another thing about the "296"s, the late 70's early 80's 301-265 usage pump used an impeller with very short vanes. That style impeller will work fine in a 400 or 455 that has been partially hard blocked, but otherwise is not a smart choice for use in rebuilding a correct dated pump for a normal water jacketed 400 or 455. A smart longtime rebuilder should know that, but so many times, it all becomes a blurr. Last Spring I went through several 5 gal buckets full of loose impellers at my rebuilders shop & not a single one was correct for a "138" casting that had picked up a stamped impeller over the years. Given enough boneyarding, will come up with some more 138's that are cosmetically horrible, and have their original impellers.
  #2230
Old 11-01-2014, 03:49 PM
'ol pinion head,
This picture is of a water pump on a 72 Firebird with a 350. I believe it is the original pump to the car, but I'm not 100% sure. This one has a "72" cast into the pump, and I assume that indicates 1972. Did the 296 pumps always have the model year cast into them? Did it change year-by-year?
Name:	water pump2.jpg
  #2231
Old 11-01-2014, 04:16 PM
Originally Posted by eaglesan13 View Post
'ol pinion head,
The 72 "moniker" is on quite a few "296" casting pumps. On '72,73,74 dated pumps, I've seen the small '72 casting. Don't believe I've seen any other small year "moniker". On the "296"s I've usually paid little attention to them, if they were the later style numbering, as they're the most common original casting. In my lrge belt bag, have a little wire brush, shaped like a tooth brush along with a plastic dental mirror & a small flashlight. Have used these to ck the dates even on pumps with grease/dirt covering the date code.
  #2232
Old 11-01-2014, 06:11 PM
Brew, it would have been coded HG, like your '73-4, however I don't know what kind of decal it used.
oPh, I believe the large casting number will have '72' cast also. '74' had the smaller number.
eagle, the date is late (Sept. '72, might even be '73. J15?). Doubt it's original.
This '76 unit has no '7*' casting.
  #2233
Old 11-01-2014, 07:52 PM
... oPh, I believe the large casting number will have '72' cast also. '74' had the smaller number... This '76 unit has no '7*' casting.
Mike, may be so on the casting number style, need to bring in & examine the straggler (later date) "296"s that I've pulled off partscars I've hauled in & cut up. Have those unsorted pumps at the warehouse along with a bunch of original 8 bolt pumps. In the garage, have all of my stock early 11 bolt style pump cores organized 3 to a box, the early ones have always sold well & just easier to get to when have them boxed & tagged. I prob need to pay more attention to the pumps that were used on '75 & 76 Pontiacs. Just have never sought out dated pumps for those two years, very little demand, once get into W72 build range, have pulled those as well.
  #2234
Old 11-19-2014, 08:29 PM
Father&Son73T/A Father&Son73T/A is offline
Thumbs up
Originally Posted by Brewster View Post
Almost ready for paint and looking good. Will post some after pictures to compare.
Enjoy,
Brew
Looks good bro,so that's what you did with that silver lookin thing huh?
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #2235
Old 11-20-2014, 04:10 PM
bluebird455 bluebird455 is offline
Default 72 trans am on ebay
Has anyone seen this one?
comments?
http://www.ebay.com/itm/Pontiac-Tran...US_Cars_Trucks
  #2236
Old 11-21-2014, 12:59 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
well 2V67 isn't a TA vin, so what is wrong?
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #2237
Old 11-21-2014, 07:17 AM
njsteve's Avatar
njsteve njsteve is offline
comments?
What the heck does this mean?
"This engine is listed as a Super Duty Engine in the Classic Industries catalog."
  #2238
Old 11-21-2014, 10:16 AM
2manyT/A'S's Avatar
Now THAT'S pretty funny................
I had a quick look at the pics and two things really jumped out at me......
The repro Formula wheel looks TERRIBLE....and the dash bezel appears to "out of focus".......?
Both those items would not be a part of ANY $70.000 car I'd be buying.
Eye Candy......garage band?
Go full screen & turn it UP!
  #2239
Old 11-21-2014, 04:12 PM
comments?
Quite a bit of removing incorrect parts & replacing with correct ones on this T/A. ton of detailing work needed to get it anywhere close to a strong #2. All adds up to extra $$$$. As it sits, its a nicely painted overpriced mid 40K driver.
  #2240
Old 11-21-2014, 04:38 PM
Transamric's Avatar
Is he referring to the "X" in the VIN? Odd!
